Question about Anycom Aris21 Bluetooth Headset Wireless Headset
Hi--I just want to know how to get calls to go to the headset, and to answer them! Obviously I charged it, and read the directions. I have a 6month old Blackberry Curve and it is paired to the headset. /cry Thanks for your time, Andi Klee www.andiklee.com
    Problem Solver:
  • 4 Answers
If you have paired your headset with your phone then the calls should automatically transfer from your phone to the headset. If you have not paired the headset and phone then that is the first thing you need to do. Here is how...first press and hold the power button on the headset until the indicator light(usually blue) is solid and not blinking. Second, have your phone look for available bluetooth devices. Third, enter in the password to enable the pairing(usually 0000). Your phone will tell you if the pairing was successful. To answer a call, there should be a button on the headset that has a little phone symbol on it or close to it. When a call comes in, you should be able to hear a little ringing from the headset. Press the button with the phone symbol on or near it and doing so should connect/answer the caller.
Posted on Jul 07, 2009
When I put it on the charger the red light flash on off the whole time without stopping and I get no charge on them
To answer a call, Briefly press the call control button.
When you receive a call, your phone may ring before your headset rings. Wait until you hear the ring in your headset before you press the call control button to answer the call.
Good luck from Headsets Direct - 800-914-7996.
Aug 20, 2011 | Plantronics Backbeat 903 Bluetooth...
Charger shows blue light, however after charging for several hours, headset will not turn on. This is a re-furbish headset from eBay however cannot tell if the charger is working or a bad headset, any...
Since you have nothing to compare it to, it's going to be difficult to pin down the culprit. Being a refurbished headset you want to make sure the ac adapter is the right one (the light on Plantronics chargers is green, not blue). You can call them at 800-544-4660 x5 x5538 to get the specs on the charger.
Good luck from Headsets Direct!
Jun 26, 2011 | Plantronics Voyager PRO Bluetooth Headset
Have new headset, why is the base unit keep beeping at me
Here is an explanation of the beeps you are hearing:
• One beep every 10 seconds is caused by a low battery
warning. Recharge battery by returning it to the base charge
cradle for one to three hours until charge light stays lit or
quits blinking.
• Two beeps is an out of range warning. Move closer to the base.
• Three rapid beeps every 30 seconds indicates your mute is
on. Press the mute button once to turn mute off.
• When an optional lifter is connected, three repetitive beeps
indicate a call is coming into the headset. Press the call
control button on the headset to answer the call.
Plantronics CS70 User's Guide
May 19, 2011 | Plantronics CS70 Wireless Headset
How to make auto answer incoming phone (hand free) with LG HBM 570 bluetooth headset in case driving car
Hi, LG HBM 730 Bluetooth Headset Wireless Headset does have the ability to auto answer a call. But it does that automatically (does not need settings for it).
Also you can set auto answer from your cell phone.I don't know the model of the cell phone you are using at the moment. So you will need to use the manual of the cell phone to know how to auto answer calls.
When you set the cellphones auto answer, then it will auto answer on your LG HBM 730 Bluetooth Headset Wireless Headset..
Have a nice day
Mar 02, 2011 | LG HBM 730 Bluetooth Headset Wireless...
The headset on my CS7ON is no longer holding a charge over 3 hours? Batteries are obviously needed. Where can they be purchased? Our headset was originally purchased with Grand and Toy.
Unfortunately, the battery in the headset is not replaceable, but you can buy just the replacement headset that works with the base. Here is a link where you can buy the replacement headset:
Plantronics CS70 Replacement Headset
Feb 08, 2011 | Plantronics CS70 Wireless Headset
I do not have manual for jabra bt160 how do i connect to phone
Wear it how you like it 4
5
English
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2 )
For optimal performance,wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight.In general,you will get better performance when
there are no obstructions between your headset and your mobile phone.(See fig.5 )
Answer a call
Tap the answer/eend button on your headset to answer a call
End a call
Tap the answer/eend button to end an active call
Reject a call (DDependent on your phone supporting this feature)
Press the answer/eend button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (ssubject to phone
settings) automatically transfer to your headset
Activate voice dialing (DDependent on your phone supporting this feature)
Tap the answer/eend button. For best results, record the voice-dialing tag through
your headset. Please consult your phone ’ s user manual for more information about
using this feature
Redial last number (DDependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+or – ) to adjust the volume (See fig. 1 )
How to...5
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing 2 mode
Make sure that the headset is on.
Press the answer/eend button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘ discover ’ the Jabra BT160
Follow your phone ’ s instruction guide. This usually involves going to a ‘ setup,’
‘ connect ’ or ‘B luetooth ’ menu on your phone and selecting the option to ‘ discover ’
or ‘ add ’ a Bluetooth device.** (See example from a typical mobile phone in fig. 4 )
Pair it with your phone 3
English
Turn on your headset 2
Press the answer/eend button to turn on your headset
Press and hold the answer/eend button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
The Jabra BT160 is easy to operate. The answer/eend button on the headset performs
different functions depending on how long you press it.
Instruction:Duration of press:
Tap Press briefly
Press Approx: 1 second
Press and hold Approx: 5 seconds
Getting started
3. Your phone will find the Jabra BT160
Your phone then asks if you want to pair with it. Accept by pressing ‘ Yes ’ or ‘ OK ’ on
the phone and confirm with the passkey or PIN 3 = 0000 (44 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
repeat steps 1 to 3.
http://www.jabra.com/Sites/Jabra/UK-uk/support/Pages/JabraBT160.aspx
It is all in there www.jabra.com
ARTGIRL
Jul 18, 2008 | Lands Phones
Plantronics 520
code is 0000 if that helps, I just bought the 520, I read that it pairs with two phones at the same time and which ever phone gets a call you can answer from the same headset. I am charging unit now to test. I hope it works.
Jun 29, 2008 | Plantronics - Bluetooth Headset Plus Base...
Jabra bluetooth headset
how do I set up the phone to discover jabra vbt185z?
Dec 29, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra bt160
hold the button down for a long time
Apr 17, 2007 | Jabra COMMUNICATIONS BT160 Bluetooth...
Anycom Aris21 Bluetooth Headset Wireless Headset Logo
121 people viewed this question
Top Anycom Radio Communications Experts
eradiostore
eradiostore
Are you an Anycom Radio Communication Expert? Answer questions, earn points and help others
