Question about Sony HVR-A1U Camcorder
Manually eject tape
No power
Eject the tape on Hitachi VT-FX695. It stays on for about 45 seconds and will not eject and then powers off.
hi,
the door mechanism is may be gripped because of a small kick...
did you try to open the door with a full charged battery and with the wall plug connected too ? help it with a toothpick or the corner of a credit card...
if this doesn't work, it may be the motor that is dead, do you ear any little noise when asking the ejection ? if yes, it is the mechanic, if not, it is the motor or the motor driver that is dead.
cheers,
mich
Nov 06, 2014 | Hitachi DZ-MV550 DVD Camcorder
VCR won't eject tape or play & powers off
It sounds as though it's jammed. If you're mechanically inclined you can unplug the unit, take the cover off, and manually eject it. Just look for the motor that drives the load basket and manually spin the shaft. The guide-posts should retract towards the tape and the basket will then lift and eject. Just be aware that whatever bit of tape that's out of the cassette won't spool back in. You will have to do that bu hand once it's out.
When you're done, plug it back in and let it cycle then put an old cheap tape in and see if it works. If not, take it in for repair.
Nov 08, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Vhs tape stuck in vcr
Disconnect power, open VCR cover, free tape if wound around posts, turn eject motor manually (usually located towards the right front) to slowly eject the tape.
Nov 14, 2013 | Televison & Video
Hi, I have a JVC HR-J658 VCR that doesn't eject tapes.
You mean a tape is stuck inside? Disconnect power and open up the cover. If the tape is stuck around the posts, free it and by manually turning the loading motor you can slowly get the mechanism to eject the tape.
Nov 05, 2013 | JVC HR-670 VHS VCR
Will not eject VHS tape
Disconnect power, open cover, free tape if jammed, rotate the loading motor manually to eject tape slowly.
Oct 05, 2013 | Mitsubishi Televison & Video
I have hp surestore DLT1e drive. Tape cartridge stuck!
For that you can try to press and hold the eject buttonfor 30 seconds if the tape doesn't came out then reflash the drive firmware revision.
After all that is the issue persists you can try to:
manually remove the tape by removing the top cover
Locate recessed thumb wheel
Rotate thumb wheel counter-clockwise until you feel resistance. Wheel may spring back when you release it. This is OK.
Locate hole in bottom of drive. Insert #10 Torx driver and rotate clockwise until tape ejects. If there is a lot of tape on the take up reel, this could take some time.
Rotate thumb wheel clockwise to eject the tape.
Apr 08, 2010 | HP Computers & Internet
Canon Elura 100 won't eject tape
I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
Apr 04, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Removing dv cassettes manually
open the unit and look for a small motor that ejects the tape through a series of mechanical gears, slides and hinges. Now turn this motor by hand.
Jun 06, 2007 | JVC GR-D270 Mini DV Digital Camcorder
Code 32:11 will not eject tape sony tvr67
The mechanism got stuck. Open the cassette compartment screws and apply external DC to the Power input and eject the tape. If this is not possible refer to a skilled technician. If you need the service manuals and mechanism for replacement write to us.
Dec 07, 2006 | Sony Handycam CCD-TRV67 Camcorder
Sony HVR-A1U Camcorder Logo
26 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
