Question about Zoom Samson Technology zoom 56K V92V90 Modem (USB Mini External) Model 3095
Wiring digram ramsond air cond 37gwx
Does not heat
Unit is turned on air cond. and heat coils are also on
How can you tell the heat coils are on? Is it just the heat generated during the coolant boil and compression process? Or are you getting hot air?
Jul 06, 2017 | Heating & Cooling
How close to the ceiling can the inside head be
Hello, try at least, 2 inches, because the interior unit takes air from upside.
Sep 16, 2014 | Ramsond 18,000 BTU 1.5 Ton Ductless Mini...
Newly installed, the outside unit will not run but the fan on inside will run
checkto see if your getting 24voltsat the condensers control wire and chech for power voltage
Jan 08, 2013 | Ramsond 12,500 BTU 1 Ton Ductless Mini...
Trying to hook up haier heat pump as cond. only. when in ac mode system is in heat mode. either iam missing something, not right digrams
Hello RRIKE The reversing valve is not energized.At the thermostat check the "O" termnal is used.It switches the valve over to cooling during a demand.
Aug 25, 2010 | Heating & Cooling
Compresser for air cond wont kick on no digram for fuse panel could be missing fuse
The fuse might be there but its burnt out. Change the fuse/relay and see. if nothing happens then it could be the actual compressor itself that is out.
Hope that helps.
May 29, 2010 | 1998 Ford Explorer
2006 Torrent also has no heat. Air cond works
The first thing to check is your antifreeze level and/or strength if low add if old add some fresh
Oct 22, 2009 | 2006 Pontiac Torrent
I have a mobile home with just heat but the air cond come with it
You will now need a 4-wire thermostat as well as 4-wire thermostat cable since you now have cooling in addition to heating. The 4-wire cable should have a red, green, white, and yellow wire. Some cables have a blue wire in place of the yellow wire. The red wire, which is 24 volts hot, goes on 'R' terminal. The green wire, used for the indoor fan, goes under 'G' terminal. The white wire, used for heating, goes under 'W' terminal. And the yellow or blue wire, used for cooling, goes under 'Y' terminal.
Aug 05, 2009 | Heating & Cooling
Zoom Samson Technology zoom 56K V92V90 Modem (USB Mini External) Model 3095 Logo
52 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
