Question about Alesis M1-Active MkII Main / Stereo Speaker
Alesis mk1 active spear won't turn on
2 Suggested Answers
SOURCE: Alesis M1 ACTIVE MONITOR amp circuitry board is ticking
The flashing blue LED and loss of sound on the Alesis M1 powered monitor is caused by failure of capacitor C8 (220uF, 35V) on the power supply board. It dries up due to its proximity to resistor R4 (47K, 2 W) which gets very hot. This is a design fault.
Remove the power supply board (4 corner screws and 2 mains connector screws) and disconnect the two plugs. Carefully desolder C8 and replace it. Its value is not critical (220 to 470 uF will do) but it should be a 105 deg. type, preferably at 50V.
Remove R4 and replace it with a similar resistor with its leads bent so that it is nowhere near C8, otherwise the fault will return. One end may be connected to one of the existing R4 solder pads (furthest from rear of board), and the other to the top end of resistor R3. Check that you have connected it correctly by inspecting the PCB tracks.
Replace the board and all screws and plugs before testing.
Posted on Nov 28, 2007
My alesis m1 active 320 usb speakers will not turn off even when i turn the knob ALL they way off.
I have the same problem. ┬┐What happened when the problem started? I disconnected them and left them thus for a day or so. When I tried again, the problem happened. Did you find a solution yet?
Apr 28, 2014 | Alesis M1 Active 320 USB Speakers
Alesis Multimix8 started smoking and now won't turn on. If it is a fuse or something how do i replace it?
A blown fuse will not produce smoke. A component failed and probably fried a resistor, which would smoke. That in turn would blow the fuse.Just replacing the fuse will not cure the problem. Your unit needs repair.
Dec 27, 2012 | Alesis Multimix 8 USB 2.0 - 8 Channel...
My Pioneer 1000 MK1 won't change the bpm of a song
Have you read the owners manual on how to work that feature?
There may be an enable switch to keep you from accidentally activating the speed change.
Dec 24, 2012 | Pioneer CDJ-1000 CD Player
Power Supply bad working. Blue led doesn't light.
Hi, I'm having the same problem with one of mine M1 Active 620. Please have you found out characteristics of D5 Zener diode, voltage?
Nov 13, 2012 | Alesis M1-Active-MK2 Powered Studio...
Won't Record From Shotgun Mic.
Adjust Recording Levels.
Win 7Start > Control Panel > Hardware and Sound > Sound > Microphone >Properties > Level.
Oct 04, 2012 | Alesis PalmTrack Handheld Portable SD...
Alesis 620 M1 active no power no light
You just fix the power supply and Brige and check the transformer
May 18, 2012 | Alesis M1-Active MkII Main / Stereo...
Alesis m1 active 520 when powered up the blue indicator light turns red with no input in it.
I I have the same problem. I do not see any visible damage with the power supply and am assuming it's somewhere else. I am talking to Alesis but don't yet know what I'll end up having to do. Have you solved the issue?
Sep 29, 2011 | Alesis M1-Active MkII Main / Stereo...
Blue led problem in alesis mk1 active
I dont think its anything to worry about, if the unit didnt turn on at all or the LED flickered then you would need a capacitor or 2 changing; check here; http://www.neufeld.newton.ks.us/electronics/?p=232
Apr 18, 2009 | Alesis M1-Active-MK2 Powered Studio...
Alesis M1-Active MkII Main / Stereo Speaker Logo
66 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
Ben Armstrong
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
