Question about HP TouchSmart IQ504t PC with Intel Core 2 Duo Processor T5750 ; 4GB DDR2-667MHz sys... PC Desktop
Msconfig how do I run msconfig? I can't find the program
  • 17 Answers
Click START, then click RUN, type in MSCONFIG and click OK.
Posted on Jan 05, 2009
Vista only runs in safe mode
1. Press the Start button.
2.
Type msconfig in Start menu or click 'run' and type msconfig.
3.
Open the program. (Click msconfig icon if it doesn't open automatically)
4.
Also, open the command box. Click Start > run > and type cmd.exe and open. (If the above method does not work, using "msconfig", your "System Configuration Utility" program should open on your screen.
5. Click on the "General" tab on the utility program. Select the "Normal Startup" option. Click "Apply" and "Ok" to confirm the change back to normal mode.
6.
Follow the on-screen prompts to restart the computer. Your computer should reboot normally.
7. IF
this doesn't work: Click on the "Boot" tab in " msconfig" > the "Safe boot" option should be unchecked.
IF that doesn't work, go to "msconfig" again and click the Startup tab. Disable all startup programs or, if you know which one is causing the problem, just a single program.
Hope this helps! Godspeed
Feb 06, 2014 | E-Machines Computers & Internet
Schedule record application starts automatically in background when system restats
Try this:
Disabling Startup Programs in Windows For some programs, it's smart to have them start with Windows, such as anti-virus and firewall software. However, for most programs, starting them at boot-up just wastes resources and extends startup time. There is a tool installed with Windows, called MSConfig, that allows you to quickly and easily see what's running at startup and disable the programs you prefer to run on our own after startup as needed. This tool is available and can be used to disable startup programs in Windows 7, Vista, and XP.
NOTE: MSConfig can be used to configure several things other than just startup programs, so be careful what you do with it. If you're not sure about using it, just follow the steps in this article and you should be fine.
To run MSConfig, open the Start menu and type "msconfig.exe" (without the quotes) in the Search box. As you type, results display. When you see "msconfig.exe," click on it or press Enter, if it is highlighted.
NOTE: If you are using Windows XP, open the Run dialog box from the Start menu, type "msconfig.exe" in the Open edit box, and click OK.
Click the Startup tab on the System Configuration main window. A list of all the startup programs displays with a check box next to each one. To prevent a program from starting up with Windows, select the check box next to the desired program so there is NO check mark in the box. Click OK once you have made your choices.
A dialog box displays telling you that you may need to restart your computer for the changes to take affect. Click Restart to restart your computer immediately. If are not ready to restart your computer, click Exit without restart.
Aug 26, 2012 | IBM Lenovo ThinkPad L412 Notebook
Cpu usage runs high
1st Go on your start menu and enter the programs, if you have
Windows 7 : type - "msconfig"
Windows Vista - "run" then type "msconfig"
Windows Xp - "run" then type "msconfig"
("Run" might have diferent names depending on your language)
Here disable every thing that you dont want to start up at the start of your computer here is a short list:
- iTunes - Steam - Windows Live Messenger
- Microsoft Office - Adobe (every one of them)
- Microsoft windows sidebar
you can check where they are under "Command" find the path and stop the programs you dont want to start every time you start your computer.
Personaly i have disabled everything that isn't a windows program or a server program.
here is a guide i made for increasing Preformence:
http://www.fixya.com/support/r10219725-speed_up_computer_windows_7_vista_xp
Aug 25, 2011 | Dell Insprion 1150 (DELL1150) PC Desktop
Angggggggg log kasi ngyun CF! paano ma solve yun?
We have 3 point of failures:
1. Internet Connection.
2. Graphics Issues.
3. RAM
Make sure when you plan CF or Cross Fire no other programs running from the background.
Update your graphics driver.
Make sure no file downloads from the background.
Disable the firewall and antivirus when playing online games.
Disable start up programs from start up tab in MSCONFIG.
To access MSCONFIG:
Win Xp = Start>Run>MSCONFIG
Vista/Win7 = Start> search for MSCONFIG
Jun 01, 2011 | Computers & Internet
HP Product Assistant pops up and I have windows 64 bit
Start>Run>Msconfig <enter>
Under 'Startup' and 'Services', look for your HP Product Assistant, and remove the checkmark.
Reboot your computer.
Hope this helps and please feel free to rate me
Sep 12, 2009 | HP Photosmart C6180 All-In-One InkJet...
How do I change my startup programs the one that show up on the taskbar that start up automaticly. I have tried to go through each program individually, but I know there is an easier way I just dont...
From the start menu, choose run. Type in 'msconfig' without the quotes. Hit enter and when msconfig starts, goto the startup tab. Uncheck those that you do not wish to start at startup.
Aug 15, 2009 | IBM (92P6581) for ThinkPad T40 (92P6581)...
Msconfig won't work
If youre running windows 2000, it doesnt come with msconfig. For a missing msconfig in XP, download it from the internet, copy it to the C:/WINNT/SYSTEM32 folder. The version that works for windows 2000 will work for XP. DONT USE the 95, 98, ME version on 2000 or XP.
Mar 29, 2009 | HP Pavilion a450n PC Desktop
M3plugin.dll
When I start My PC the RUNDLL error occursError loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.  Solve my this problem as soon as possible.
Aug 26, 2008 | Computers & Internet
Error window appears that reads "Can't find resource file". This happens at every restart of Windows.
That usually means that a program that starts when Windows starts isnt functioning correctly, You can test it by clixking Start > Run > type Msconfig and press enter. After that click the startup tab. Here you will see programs that load when Windows starts.
If you recognize the program thats causing the issue, simply click the box to the left of the item to uncheck it and click OK. You will then be prompted to restart.
As the machine restarts, check to see if the issue has disappeared.
If so, great. Be aware that you that you will be prompted with a "System Configuration Utility" dialog that lets you know you are using Msconfig. If you don't want to be warned of this, click the box that says "Dont show this message..." and click OK.
If not, run Msconfig again, and uncheck the next suspicious program and repeat the process until the problem disappears.
Below is a link with information on using Msconfig. It also has other links that include information of some of the programs that you might see in the startup window of Msconfig.
http://www.netsquirrel.com/msconfig/msconfig_xp.html
NOTE:
There's is a "Disable all" button under the startup tab. But I wouldn't suggest using that initially. It is better to uncheck them one at a time so you can see what is causing the issue.
Thanks
Jul 23, 2008 | Computers & Internet
Programs not responding
Hi again Gordon,
Appreciate the update.
1. other than the glitches you posted, was there any significant change on how the programs responded, specifically are they still prone to "not responding". If still, then problem is elsewhere, if no more "not responding" then we simply have to weave out the culprit among the many in msconfig's Startup;
2. Could you please post back a list of the programs that are running in msconfig's Startup?
Jun 09, 2008 | Computers & Internet
HP TouchSmart IQ504t PC with Intel Core 2 Duo Processor T5750  ; 4GB DDR2-667MHz sys...  PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
