Question about HP PSC 1210v All-In-One InkJet Printer
Printer keeps printing the copy over and over and over
I ask for a copy on line and my printer just kept sending the same copy over and over. I shut down the printer and computer, and then rebooted and tried to print another thing and I still get more copies of the first copy.
    Genius:
  • 2,120 Answers
Shut down, unhook the USB cable, turn computer on, shut down, reconnect the USB cable, turn on computer.
Posted on Jan 03, 2009
Attempting to FAX...ErrorCode OxAF8D...cannot find this code in manual.
Where do you initiate faxing - from your computer or using the printer operator panel?
Try the following steps to determine what is causing this problem:
  1. Disconnect the printer from the phone line from the wall.
  2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  3. When the printer turns on, try to make a copy or print from your computer to verify that the printer is working normally without connecting to the fax line.
  4. If copying or printing from computer is working properly, then connect it to the fax line.
  5. Try to send a fax from the printer operator panel.
  6. Try to send a fax from your computer. If error appears, try to update your printer software by inserting the printer's installation disc into your computer hard drive.
I hope this helps.Please keep me posted.
Nov 26, 2011 | Lexmark X5470 All-In-One InkJet Printer
When selecting a printing task,If I ask for one copy,the machine continues to print even after hitting the cancel printing. Second*lets say there are two pages to be printed the first oage will print,the...
Hello. Try to unplug the printer from the power outlet for about 10-15 seconds to refresh itself. If that doesn't resolve the problem, it might be software communication issue. You can uninstall then reinstall the software. If you're computer is running on Windows, uninstall by going to Start Menu > Programs/All Programs > Lexmark Series folder > Tools/Uninstall. Reboot pc. Reinstall software. If your using Macintosh, go in the Lexmark folder and Uninstall. Reinstall software. Hope this helps.
Mar 17, 2010 | Lexmark C533DN InkJet Printer
Laserjet 2420d just keeps printing document repeatedly from XP
check hp for latest driver for your operating system, also check if there is a PCL and PS driver. PS is better for PDF. sometimes an adobe update can cause these issues so if you cannot find a driver update you could roll back adobe to see if that fixes your issue.
Aug 07, 2009 | HP LaserJet 2420 Printer
Color line along side of copies; doesn't always print; error message keeps blinking (no manual),
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
May 27, 2009 | Konica Minolta magicolor 2400 Laser...
Al-1540 only scans, wont print says-data could not be sent to pri
it seems that the computer was trying to send the data to the printer through the wrong port. i went to the control panel in windows xp, and selected printers and scanners. and added a new printer (manually) as al-1540 cs on usb port 2. it alerted me that the software was not signed, i proceeded anyways. it asked if i wanted to keep the original printer , i said yes. and the test page printed away. so i would suggest people with similar problem to keep adding multiple copies of the printer again and again on usb ports 1,2,3... etc till it prints the test page. use the copy no. indicated in the printed test page to do all your print jobs in the future.
Dec 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Color not printing
If you are making copies or sending/receiving faxes Press Black Start or Color Start. Make sure your ink cartridges are fresh. Cartridges remain fresh for up to two years if kept in their original packaging, after that the ink may become clogged. Cartridge expiration dates are printed on the package.
Sep 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printer printing more then what is needed
while uninstalling the epson driver it will ask you for delete the setting or do you want to keep it. if you select keep it, it will happen how many times you install the driver. Check the printer settings in printers and faxes window, select printer go to printing preferences, page layout and check whether you give no. of copies to 2 there.
May 06, 2008 | Epson RX595 Photo All-In-One Printer
HP PSC 1210v All-In-One InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
