Question about Toshiba E-studio 355 Digital Copier-network Print/scan-practically
Clear maitenance counter es 355
How do i clear time for maintenance on my es 355
    Problem Solver:
  • 12 Answers
Press 0+5 and on the machine
press 2 0 0 and press enter on touch pnl.then wait for two mints and done.restart machine
Posted on Aug 27, 2013
2 Suggested Answers
  • 125 Answers
SOURCE: clear maintenance counter es 162f
Hi:
Press # * clr * then key in main code 20 sub code 01 and press the start button . Then press the function clr button twice to get back in normal mode.
Andrew
Posted on Jul 09, 2012
Clearing maitenance dialta 152
meter count, stop 00 stop 01
depress 3
counters
2, pm counter
Jan 02, 2014 | Konica Minolta DiALTA Di183F Copier
Clearing consumable maitenance
mam/sir
Meter count, stop 00 stop 01
depress 3
counters
2, pm counter
Sharp ar 203e maintenance indicator reset solotion
It is SIM 20-1 for maintenance counter reset.
Press
[Clear] key -> Exposure mode selector key -> [Clear] key -> Exposure mode selector key
to enter to maintenance mode.
Add with UP arrow 20, press Start button, add with UP arrow 1 and press Start button. 000 will flash, exit with pressing Clear key 3 times.
It will only reset the counter, I recomend also replacing the parts (drum, develop, blade,..) and clean it.
Mar 21, 2013 | Office Equipment & Supplies
Clear maintenance counter es 162f
Hi:
Andrew
Jul 07, 2012 | Toshiba Office Equipment & Supplies
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
When i start the car the maitenence required light flashes a number of times and then goes off
The vehicle has either reached the mileage necessary for oil change and other maintenance, or whoever performed the last service did not reset the computer.
May 15, 2010 | 2002 Honda Accord
This is one advise about your MAINTENANCE is soon; or, if you make maintenance, your dealer forgetted eraser this code and reset the counter.
Good luck (remember rated this post).
Mar 29, 2010 | 2002 Honda Accord
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
What is "Maintenance required. Code: AA"
Maintenance timing display The message of maintenance execution timing is displayed when each counter reaches the set value. The relationship between the messages and the counters is shown blow. Maintenance counter AA WhenThe maintenance counters (both of total and color) reaches 90% of the set value of SIM21-1 (When the setting of SIM26-38 is ?print stop?). When The maintenance counters (both of total and color) reaches the set value of SIM21-1 (When the setting of SIM26-38 is ?print allowing?). Enable ? After completion of the maintenance, execute SIM 24-4 (Maintenance counters (total, color) clear).
Aug 29, 2009 | Sharp MX-2700N Color Copier
Toshiba E-studio 355 Digital Copier-network Print/scan-practically Logo
210 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
