Question about Drills
Ihave a makita 6095d drill. On the reverse switch there is a diode or mosfet - i think to control the speed of drilling. The type on this component is S3V7D. Can you give me any help to indentify what
My email adress is bengielen@ziggo,nl
  • ben gielen Nov 01, 2012
    is there any-one that can identify the component on my reserve switch of the Makita 6095D drill? Is it a diode or fet?Is it for safety or does it influence the speed regulation.?
  • 313 Answers
SOURCE: makita 1420 - 14.4v 1.3Ah cordless drill
try toolpartsdirect.com & go to makita & type in model #
Posted on Jun 09, 2008
emissionwiz
  • 76109 Answers
SOURCE: Dewalt cordless drill
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Posted on Aug 29, 2008
SOURCE: Makita drill 6349D
dont think its http://www.toolbarn.com/product/makita/6349DWDE/
Posted on Oct 05, 2008
  • 9 Answers
SOURCE: drill bit is stuck inside my makita drill chuck
Try using the low torque setting on the drill when reversing and something to assist you getting a better grip to hold the chuck from spinning when reversing. This may help.
Good Luck
Posted on Dec 04, 2008
  • 22 Answers
SOURCE: I have a makita 6095d
set it on the drill setting
Posted on Dec 13, 2008
Variable speed not working, the trigger is either full on or off. speed switch 1 or 2 works
Replace the switch because a power mosfet inside is defect
650583-6 look for that switch partnumber also ferify it because this is for the model in the netherlands but most time its the same by Makita and its not to expensive will succeed to replace succes. but be careful when pulling out the wires using a thin watch screwdriver to push the unlock holes next to the connector contacts.
Nov 01, 2015 | Dewalt Makita Bhp452 18v Cordless 1/2"...
Problem taking batteries out of older Makita drill (6095D) to recharge/replace them.
there is a clamp on the bottom that has to be unlatched and the battery should just pull out of the bottom, unless it is stuck by corrosion and then you might have to "TAP" gently to remove. You can download a breakdown of this tool at makitausa.com to see what I am talking about.
Jun 26, 2011 | Makita Drills
Charger for makita 9.6volt 6095d not working
revisar las terminales del cargador que hasen contacto con las del taladro yestas tambien porque puede ser que esten oxidadas y linpiarlas con limpia contactos y con lija n400 o mas fina
Oct 05, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Drill was working one minute went to change bit after i did this it would not work
Probably a trigger switch, if you wiggle the switch will it power up?
Also if your drilling alot and it slows down and won't restart it could be the motor's brushes.
Cheers
Jan 05, 2010 | Makita 6402 3/8" Drill, 5.2 AMP, 0 - 1,200...
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Oct 05, 2009 | Makita Drills
What is the procedure for removing the chuck from a makita 6095D 9.6v drill?
Most chucks use a tapered shank that allows you to remove it with a good tap on the bottom. Other chucks have slots in the slots in the shaft that allows you to tao it off with a wedge type key. You could always use a dent puller and chusk on the screw.
Good luck, Jack
Aug 21, 2009 | Drills
How to replace forward and reverse switch on a Makita model 6095d cordless drilldriver
If you are mechanically inclined you should have no problems but if not this is involved. First I would recommend going to the Makitatools.com website and on the right side type in your model number and look at a breakdown for this unit. To start with you have to remove the chuck, then the collar with the 2 springs under it and then remove all screws from the housing separating it carefully so none of the parts jump out. The switch is polarity sensitive so make sure of the wiring. If you still want to tackle this let me know and I will go into more detail on this. Good luck
Apr 08, 2009 | Makita Drills
Drills Logo
76 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
