Question about Acer X1160 DLP Data Projector, 2,000 ANSI, 2,000:1 Contrast Native SVGA - 800 x 600 res Projector
The projector lamp does not light, but indicator lamps(of POWER and Lamp) light and the cooling fan rotates.
SOURCE: acer projector
My Acer PD125projector was working perfectly but has been out of use for 6 months. When I connect it now, I get:- 1. "ACER - Empowering People" screen, then 2. After a short delay the message "The Lamp is approaching the end of its useful life at full power ........." is displayed for a short time, then 3. The initial screen returns, together with a "No Signal" message. After this warm up none of the controls on the actual machine nor the the remote controller, except for the power button, will do anything. What can I do about this?
Posted on Aug 11, 2008
SOURCE: Acer PD525
Same thing happen to mine..Power supply went bad and these is not one to be found anywhere. Peace of JUNK
Posted on Aug 25, 2008
SOURCE: I need to reset the
Found reset in menu. the first time I turned it on after replacing bulb it would not let me reset, but after I turned it off then back on I was able to do it. Not sure if this was a fluke or not.
Posted on Jan 08, 2009
  • 22 Answers
SOURCE: Cleaning the X1160 Projector
Dust it with clean cloth, & carefully blow it with can of compressed air every so often. Do not frequently disasemble it just to clean it.
Posted on Jan 09, 2009
jcarlton214
  • 105 Answers
SOURCE: Acer pd120 projector
get a bottle of canned air. blow out unit. take bulb out and clean everywhere every time you change bulb. let it sit for a while so it warms back up prior to plugging back in.the air gets cold
Posted on Jun 07, 2009
I got a viewsonic pjd5111 projector used . it power on for aleaast 30 sec and shut down immediately temp light red and lamp light green . i hv tried everything .help
Check if there is a cooling fan. Is it rotating?
It is also possible that the filter is dusty and needs to be cleaned/replaced.
(all projectors have a cooling fan and a filter to prevent dust from reaching the lamp. A faulty fan or a reduced air flow may cause an overheat problem)
Aug 16, 2016 | ViewSonic Office Equipment & Supplies
I just bought a used NEC Multisync MT 840 projector with just over 600 hours on the lamp counter. I live in Japan. After about 4 or five minutes of working, the projector turns itself off and won't...
hi,
Possible problem is the faulty lamp cooling fan. Check the lamp cooling fan of your projector. if the RPM of fan is low then the lamp can get over heated. May be its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
i have added a video how to oil the fan for make it easy for you.
ok
May 08, 2011 | NEC MultiSync MT840 Multimedia Projector
My pt-ae900u wont turn on. the lamp light is flashing red..and the motor or fan is making a soft scratching noise. I never got any warning on the screen saying the bulb was in need of replacing..but its...
First of all check the remove the lamp and check the same. if it found burned you have to replace it. Remember one thing you have to reset the lamp hour After replacing the lamp. You can see the option in the menu.
resetting procedure.
1. inset the new lamp.
2. power on the projector.
3. Press menu and select OPTION.
4. Press enter button and the select LAMP RUN TIME.
5. Press and hold MENU button for 3 seconds.
6. Lamp reset , power off message will display.
7. power off the projector. this will reset the lamp hour.
Also Check the lamp cooling fan of your projector. may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
ok
Mar 10, 2011 | Panasonic PT-AE900U Multimedia Projector
I have a dell 1209s projector and the temp symbol flashes. I dont know if I need a new lamp or what? Help me? thanks
Check the lamp cooling fan of your projector. maybe its has some problem. its not running at the correct RPM. that's why the lamp get over heated and the temp lamp flashes.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
Also try to reset the lamp hour of your projector. you can see the option for reset the lamp hour in the menu. Please not one thing lamp reset is recommended only after replacing the lamp.
ok
Mar 10, 2011 | Dell 1209S DLP Projector
We have Toshiba TDP-T05 projector - recently replaced the buld - projector starts then does not work red indicator on Fan and on button - looks like Fan bad. Can this be fixed or better to buy new.
Before going to by a new one just try to do the following
First of all try to reset the lamp hour of your projector. For resetting the lamp hour do the following.
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on,
Otherwise Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projecto and watch.
ok
Mar 07, 2011 | Toshiba TDP-T95U Multimedia Projector
I have a model and swapped the T45U projector lamp, the projector turns on, but in a few seconds it shuts off, and turns on the LED "Temp" what can this be?
hi,
First of all check the lamp hour . Reset the lamp hour and try again. It is recommended that reset lamp hour only after replacing the lamp. No matter, just reset the lamp hour. If problem doen't repeat the try to replace lamp.
Another possible problem is the faulty lamp cooling fan. Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
ok
Feb 12, 2011 | Toshiba TDP-T45U DLP Projector
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo Projector PLC XU83 lamp is replaced 1 everything is fine 2 projector turned on and reset the counter 3 projector switch off and normal 4 Next time imposible to power on the projector After ...
Check the cooling fans. If they are not rotating the Projector will not start.
Did the lamp explode? If it did a bit of glass has lodged in the cooling fan and stopped it from working.
Hope this helps.
Nov 15, 2010 | Televison & Video
Projector's lamp won't light up.
Change thermostat and service it.Then solve your problem.
Dec 12, 2009 | BenQ PB8220 Multimedia Projector
I got a Toshiba tlp650u projector broken on ebay. It works fine but after about two minutes turns itself off and then the fans come back on and the two power and lamp lights come back on red, which the...
Make sure the air intake filter has been removed, dissassembled and cleaned. Reset the lamp timer after replacing the lamp. Confirm allo fans are operational, and don't forget to allow for the cool down time after the unit is turned off. AC must remain connected for the unit to cool down the lamp after the unit is turned off.
Sep 17, 2009 | Toshiba TLP 650 Multimedia Projector
Acer X1160 DLP Data Projector, 2,000 ANSI, 2,000:1 Contrast Native SVGA - 800 x 600 res Projector Logo
37 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
