Question about Konica Minolta Copier Toner, for EP-4000/5000, Black
Minolta 4000 copier when we turn on machine is sound at back like tick tick than turn off if i stuck hand on button its work other wise its off
  • Konica Minolta Master
  • 6,696 Answers
Sounds like a relay maybe bad mike want to check the fuses. or have a tech look at circuit boards in the back of the machine
Posted on Dec 27, 2014
Stabilizing image controller not ran
Stabilizing Image control sounds like a Color copier not a analog b/w copier which the EP 5000/4000 is. What is the model of the machine?
Sep 11, 2014 | Konica Minolta Minolta Ep4000/ep5000...
My machine minolta 4000 showing code c0700
DId you open close the front door. if that does not work then take the toner bottle out. turn of the machine then turn it back on with no toner bottle in the machine. let the machine do its thing the machine will then ask to replace the toner at that time install the toner if that does not wok you have a problem with the toner motor and associated circuitry.
Mar 23, 2014 | Konica Minolta Copy Toner, 40000 Page...
Minolta 4000 c520 error
Open the front door then look to you upper left. See a small access cover remove one screw the press the trouble reset button. Machine must be on. If the code come back do not reset you are resetting codes for the fuser the hot part. it could catch on fire and that would ruin a perfectly good day! Have the fuse looked at if the code comes back before resetting the code
Aug 07, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta ep 4000 how to disable the third paper tray
If the 3rd paper tray is LCT (large capacity tray) disconnect the tray electrical connector on the rear side,or not close the tray.
Feb 27, 2013 | Minolta EP4000/5000 CS/PRO Copier
I NEED THE PHONE # OF KONICA MINOLTA CUSTOMER
You can contact Konica Minolta customer care center at below details:
Konica Minolta Business Solutions U.S.A., Inc.
100 Williams Drive
Ramsey, NJ 07446
201-825-4000
If you wish to get the toner cartridge serviced or chnage it fro a new one, you can vist the below link whre you can find the information about their authorized service partner location wise.
Konica Minolta Customer Care
Regards.
Jan 07, 2010 | Konica Minolta Office Equipment & Supplies
I am getting a C004A error on a Minolta 4000 copier.
Optical section fan motor failure.Change the fan motor.To reset open and close the front door or press the service reset button(placed in the left up side).
Oct 07, 2009 | Minolta Office Equipment & Supplies
High Tick over when hot cold is 1500rpm but after its been riden and warm it rases to 4000rpm chock is off lol
take the throttle cable off the arm at the carb end and try pulling the cable and check 4 stiffness maybe a frayd cable other wise all air screws may not be in sync with each other if tht doesnt work get back 2 me on tht 1
May 20, 2009 | 1992 kawasaki GT 750
Minolta EP2030 exposure lamp timing wrong
"Exposure lamp timing wrong" simply means that the lamp is coming on at a time when it should not be coming on. It is not a problem with the lamp itself. It is most likely a power supply problem. There is probably no simple fix.
Just because Konica Minolta no longer will sell you an agreement does not mean that you cannot get the copier serviced. There are plenty of independent repair agencies that would love to service your copier, unless you are in a really remote location.
The EP2030 was one of the last Minolta analog copiers, and parts are still readily available.
Nov 13, 2008 | Minolta EP1030/1030F CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
Konica Minolta Copier Toner, for EP-4000/5000, Black Logo
37 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
