Question about Car Audio & Video
I removed the battery of my car and the radio and could not see the code.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 32 Answers
If it's not written in the user manual then you'll have to contact the dealer.
Posted on Apr 23, 2013
THE RADIO WENT COMPLETELY OFF WHEN I TOOK THE OLD BATTERY OUT TO EXCHANGE IT
by removing the battery you have activated the anti-theft code in the radio and now you will need that code reinstalled to get the radio working again
Apr 20, 2016 | Cars & Trucks
Turned radio off then battery died, got vehicle fixed but no power to factory radio, all fuses check as good. Is there a trick to getting the radio to turn on again?
when the battery dies or is removed , the anti-theft code of the radio kicks in and the unit will not work again until a special code for that radio is reinstalled
the code could be in the user manual in the radio use section ,or there are sites on the net that may have the code for you
Mar 24, 2016 | 1998 Ford Expedition
Battery went flat radio wont work now.how do i get code?
Search Results
    Car Radio Stopped Working after the Battery Died
    cartech.about.com > ... > Car Radio Components FAQs, and More
    First your battery went dead, and now your car stereo is dead, and it's really ... or charge, and you're lucky, then you may find that your car radio fuse is blown.
    radio won't work after new battery installed - Car Talk
    community.cartalk.com/.../radio-wont-work-after-new-battery-installed
    Nov 30, 2011 - Today the dealership did a tuneup, replaced the timing belt, and put in a new battery. I started my car and the radio did not work. They went out ...
    Another Flat Battery - Radio No Longer Works - Hyundai Forums ...
    www.hyundai-forums.com/.../128744-another-flat-battery-radio-no-long...
    Jul 18, 2011 - Also now the battery has been recharged the redio will not work. .... Mybattery went flat, took it out and went to a battery shop who charged it up ...
    Dead battery..now radio won't work - Honda CR-V Owners Club
Dec 09, 2015 | Cars & Trucks
Had to replace battery now radio is asking for code
The correct radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Removal Info here
www.fitaudio.com
Then post the radio make+model plus all the letters+numbers on any labels,barcodes and a 14 character Serial Number stamped in the metal casing.
This information can then be used to see if a code can be calculated
Radio Code advice always available here (including BMW Z3 radios )
www.ukbookshelf.co.uk
Oct 19, 2015 | 2001 BMW Z3
Please someone give me a unlock code for ford 6000ne car radio.YS4F-18C815-AD. serial M178227
It is only available at a Ford Dealership...Give them your VIN Number & they will give you the code...There is a charge for this service...Now, if you lost battery because you changed or disconnected battery you can avoid this happening in the future...Take a 9 volt battery...Remove the snap top from an old smoke detector...Solder the + lead to positive of cigar lighter plug and - lead to negative of cigar lighter plug...snap on 9 volt battery and plug into lighter BEFORE disconnecting car battery...The 9 volt battery will hold radio up while car battery is disconnected...saailer
Jun 05, 2015 | Ford Cars & Trucks
After replacing a battery the radio doesn't work. why does the radio have to be removed to get the code to fix it?
it has an anti-theft radio that needs a code to unlock it in case it get stolen it becomes useless the to the thief. the code is programed into the radio without removal by using the controls on the face of the radio. you may have to go to the dealer to have re-programed.
Feb 13, 2015 | Acura TL Cars & Trucks
My Lanos radio requires a code to unlock it whenever the battery is disconnected and reconnected. If I install a new radio, will it also require a code?
depends on the radio you bu. If the radio you get has a removable face then the code is stored in the face. If you get a radio that is all one part then it will have a code that you will have to enter every time the battery is removed. If the battery removal is something you do regularly then go to a battery supply shop and enquire about a back up pack that plugs into the data link and maintains all the electronic settings while the battery is out
Nov 10, 2014 | 2000 Daewoo Lanos
Radio won't work. reset battery and it works until you shut the car off, then won't come back on.
May be it needs complete reprogramming.
To reprogram the radio there is 4 digit code. That code has to be inserted, once these code is inserted, your car radio will get into its actual setting where you can set/select your radio setting.
Many a time's radio asks for the code after car battery is disconnected.
On some cases to retrieve the code its mentioned in manual or else car dealer is other option to get car radio code.
For more help on car radio problems, I suggest you to go through these troubleshooting links, these will help you: -----
Click the link below: ---
Cigarette lighter, Remote central locking, and Radio stopped working
http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe mode? VW radio CODE?
http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on 1990 Toyota Celica?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram for 1991 Chevy 1500?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
After Market Stereo wiring for 1999 Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
Chevy car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio on 2005 Toyota Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Lexus rx330 Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Lincoln Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash on 2003 Lincoln Aviator
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
Dec 06, 2012 | 2006 Volvo XC90
Replaced the Battery and my Mercedes benz 1996 C280 CD player is requesting a code, does anyone know if it is unique or universal code, please supply if the code is universal.
Dec 06, 2012 | Cars & Trucks
Radio reset codes
I have a 2001 focus ..radio suddenly stopped playing after being at garage.  I thought that the battery was disconnected and the radio neede reset code, as it has a rad blinking dash anti-theft light.  i went to ford garage and they told me they don't have reset codes on the focus.  Is this true?
Aug 05, 2008 | 2001 Ford Focus
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
