When tv is turned on it has lines on screen only
Multi colored lines or pixels on screen
  • 14,337 Answers
Here's a link on how to fix,I had the same problem and went to this link and got it fixed.http://www.samsclub.com/sams/vizio-65-led-1080p-240hz-smart-hdtv-w-theater-3d/prod7870079.ip?sprodId=prod7870079
Posted on Oct 30, 2012
SOURCE: video problems with my westinghouse LTV 32 W 3 HD
This seems to be associated with the overheating of some component. On my set I need to check that the backlight is set to a low level. On reset it automatically adjusts to a level above maximum and the green screen will appear in a few minutes. I took the back off and that helped some.
Posted on Feb 01, 2008
mistersony
  • 320 Answers
SOURCE: Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
Posted on Oct 18, 2008
  • 30 Answers
SOURCE: SONY KDF E50A10 vertical multi-colored lines across the screen
bad Q box, need tech to replace
Posted on Aug 09, 2009
  • 441 Answers
SOURCE: just cracked the 52 LCD screen playing with WI.
Sorry "wii" damage like that will run to much, look for other units on ebay with the screen intact and that would save some cash
Posted on Nov 17, 2009
Testimonial: "Thank you for your immediate feedback. I thought the cost of repair would be expensive and you have just confirmed it. Thank you again. Regards!!"
SOURCE: Vertical colored lines on left half of screen.
I had this problem on a 37" Viewsonic LCD. Pulled it apart and through a process of elimination, I traced the problem back to a small board with several flat white ribbon cables coming out of it. The board was near the top center of the screen and under a ton of other equipment requiring almost a total disassembly.
This small board was clean but I noticed one of the rubber standoffs had slipped down and was making contact with one of the outputs running to the LCD. It also happened to be the output running to the section of the screen with the problem.
I postulated that the sticky glue on the rubber standoff may have just enough conductivity to cause a problem. Moved it so that it was no longer touching anything electrical and then reassembled the TV.
Afterwards, I turned it on and was pleased to see the problem has gone away! If you're having the vertical line problem, then maybe this could be your problem too, especially if you have a Viewsonic since it could be a manufacturing defect.
Posted on Mar 22, 2010
How to diagnose my led tv issues
You most likely had a capacitor let go, they make a pop when the go out, inspect the PCB for a burned mark.
Oct 12, 2016 | Toshiba Televison & Video
Dell Latitude D505 half of screen is black with colored vertical lines.
Sounds like you have a section of dead pixels. This can happen if the laptop has been dropped a lot or stepped on or some type of impact on the laptop. This is a hardware issue. You will need to have the screen replaced. In my opinion, by the age of the laptop, its better off getting a new one.
Oct 01, 2014 | Dell Latitude D505 Notebook
I have a 42 in Sanyo DP42647. If there is something like a logo or words that stay on the screen for more than a few seconds it looks like it is burned in. It eventually fades but by the time one fades...
Cause of screen burn typically is pixels are no longer showing full range of color. Typically a shop would cycle screens or blocks of very bright colors alternating colors to unstick any pixels not showing full range of some color. Setting tv back to factory default then adjusting could help also turning up brightness. Change color settings from cool to warm could help. Could also be a refresh rate. Verify tv is set to display at same rate as input device like cable box set to output 1080i while tv native is 720p. Just because there is a pic doesn't mean they are synced.if tv has to convert signal from 1080i to 540i then resize to fit 720p tv it may slow refresh rate tv is trying to display progressive scan image but not enough data is coming in so it redisplays previous image on every other line.and new data on every other line.
solution is check output video settings of source to match native resolution of tv. Hd cable box this is common as tech sets output to high resolution 1080i most inexpensive tv are 720p
Mar 14, 2014 | Sanyo 42 in. LCD TV
2006 powerbook G4. my screen will get glitchy and i can see multi color squares and lines randomly on the screen. when i move a window the pixels chase and outline my movements. any ideas?
sounds like the video card is dying. I was able to hold off on one dying by downloading a fan controller that kept the machine cooler, but with the age of the G4, it's likely damaged. Consider replacing or the fan controller.
Jan 19, 2014 | Apple G4 Computers & Internet
TV showing color pixels but no picture and no sound
Well at least you didn't pay for the TV. Your panel is defective. Cheaper to buy a TV than to fix.
Mar 20, 2013 | Televison & Video
The LCD on my A590is camera doesn't work. When I
if the lcd is flexible then mostly the problem is with lcd connector.if you have a v cable then connect it to tv and see if picture is coming, if it comes then connector is faulty for sure
May 28, 2010 | Canon PowerShot A590 IS Digital Camera
Dell 42" Flat Panel TV....Multi colored lines on screen...twinkling colors
your flat panel set was hit by something causing the pixel lines. from physical force. sorry to tell you this but the display panel has to be replaced. call a service shop for verification.
Mar 09, 2010 | Televison & Video
Samsung hdtv, purple pixels and trouble turning on
probably the power supply is going out.common problem.
Oct 27, 2009 | Televison & Video
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
Electro Med Services...
