2005 Bajaj Pulsar 180 Logo
zama Posted on Oct 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Carburator screws damaged
Hi, My pulsars 180 ug4, 2009 carburator screws slipped and not able to open it. Please provide some solution
bazzz7071
Level 2:
  • Expert 342 Answers
  • Posted on Nov 03, 2012
bazzz7071
Expert
Level 2:
Answers
342
Questions
0
Helped
138437
Points
692
Hi ok i am assuming you stripped the phillips heads and connot turn the screws to take them off.
2 ways to loosen them 1 mini set of locking pliers or get a small metal punch and a small ball peen hammer try and secure the carb so it wont be damaged and take the punch mak sure the tip is sharp enough on the outside edge of the head of the screw make indentation and hit it in the counter clockwise direction it will come loose then screw it the rest of the way out replace them with new screws when you put it back together.
4 Related Answers
Anonymous
  • 83 Answers
  • Posted on Feb 02, 2011
SOURCE: Can any one provide electrical wiring diagram for
wiring diagram will be found in pulsar manual, that you got from Vehicle. then if you dont have that one, Xbhp is a website that will have pulsar manual. try check it out!
Anonymous
  • 2712 Answers
  • Posted on Nov 10, 2008
SOURCE: Gearbox not smooth in Pulsar 180
Because its one gear front and four as back so it doesnt smooth..
seanpwright
Sean Wright
  • 2045 Answers
  • Posted on Aug 27, 2009
SOURCE: I need a new carburator for pulsar 150 dtsi 2005
Once you find a dealer just simply tell them you need a new carb. they will know which ones it is
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
FirsLonewolf
Greg Murphy
  • 186 Answers
  • Posted on Nov 17, 2011
SOURCE: can i fix pulsar 200 cooling system for pulsar 180
measure the overall dimensions and the mounting brackets, if they are the same it can be used
7helpful
In pulsar200 2009 model, How to increase the pickup,power,Speed?
Check your gasoline filter if there's one, check the air filter, also check or just replace your spark plug(s)...
Most other things that should be done by a mecanic are like maybe cleaning the carburator(s), checking the ignition, see wether there is damage inside the cilinder...
I hope this is helpful, and greetings,
Olivier.
47helpful
11answers
Da price of pulsar 220 headlight
220 mask price is 2000
headlight- 4000
jal- 700
handle ,tee-1300
and easily fit in pulsar150
Top Bajaj Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Bajaj Expert? Answer questions, earn points and help others
