Question about Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome...
Trying to get the handle off a single handle moen kitchen faucet
Because i d like to change the washer but after using a wrench to loosen screw i still can t get th handle off. can u help me?
    Scholar:
  • 68 Answers
Hi adelinette,
Pry the cover off the top of the faucet with a little screwdriver. Under the cover you will find an allen head screw. Sometimes a little upward pressure with a screwdriver will help. Unscrew it and start disassemblying. Pay attention to part location as you take the faucet apart. you will be replacing a stem and not a washer when you get into it.
Good Luck and please rate this response, Phil
Posted on Jan 06, 2009
Can someone help me and tell me how to get the handle off the Chateau 7600 series moen one handle. I used to have the old version with the cover that you pop off and the screw is underneath, but I can't figure this one out. Thanks
Posted on Jan 14, 2010
What size allen wrench do I need to tighten a moen (annabelle) single handle kitchen faucet?
google manufacture or go topumbing supplier and they should help you
Mar 02, 2015 | Moen Plumbing
How do I replace the cartridge in my Moen 7065 Vestige Single Handled kitchen Faucet?
first the water needs to be shut off, then with an allan wrench if i remember it should be 1/8. the allan screw is located in the handle. remove the screw completely and under the handle should be a nut, with a crescent wrench remove the nut and the cartridge should be ready to be removed. it is going to be difficult to come out with out the proper moen tool but vise grips will help as you have to pull straight up. if you find a plumping wholesale and give them the model # they should be able to give you the right cartridge. or if you call moen the will ship you one either way it should be free as that is a warranty item.
Aug 26, 2012 | Moen 7065 Vestige Single-Handle Kitchen...
Do not know what seris of Moen facet I have. The house was built in 1984. I have got water lines off underneath but can not get faucet it self off. Took out the screw and the ring screw and base ring screw...
If it is a single hole faucet, there should be a single nut on the threaded brass piece underneath the sink. You may need a basin wrench to get access to it if you cannot get to it with an adjustable jaw wrench. This nut normally clamps against a U shaped washer that is against the underside of the sink.
Mar 10, 2011 | Moen 87440 Single Handle Kitchen Faucet...
I have a single -handle Moen Torrance 87480 kitchen faucet that needs the cartridge replaced. (I had Moen ship it to me.) My problem is, I can't remove the single handle using my 3/32 allen wrench. When...
Should be coming out if head not stripped or threads inside at set screw aren't stripped. Can you tell at all with perhaps flashlight if set screw is turning at all? Look like it backing out?
Jan 30, 2011 | Moen & Replacement Cartridge
I have a single lever Moen faucet where the handle is very loose and there is no button on the back side that would reveal an allen key, so I cannot tell how to tighten it back up. What should I do?
On almost all moen single handle faucets there is no allen set screw to hold handle on. They are secured by a screw located under Moen emblem in the center of the faucet on the top. You usually can get to the handle screw by prying cover off with small blade screwdriver or point of knife blade.. Tighten screw and hopefully this will fix your problem. Thank you.
Nov 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Cannot remove handle. Allen wrench receiver is stripped. Are there any other options? Thanks!
There is a home cleaning product called the The Works which will loosen the corrosion around the screw. Then use a screw extractor tool. You can find one at most hardware stores and home centers.
Another solution would be to call Moen Customer Support and ask for a new handle and repair parts for free. The faucet should have a lifetime warranty. When you have the new faucet parts in hand, literally cut the handle off the faucet with a hacksaw or drill the screw out to remove the handle.
Sep 07, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Moen kitchen faucet spout
there should be a removable "button" on the faucet base below the handle. under there, there should be a set screw. loosen the screw, remove the handle. now u can adjust the base, collar, etc. to ur liking...don't forget to reassemble everything the same way u removed them.
Dec 13, 2009 | Moen 7310 Legend Single-Handle Kitchen...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
Moen 87135c - cant take apart
On handle of faucet you will see a red/blue plug button, under that is a set screw. loosen and this will allow you to remove handle.
Oct 03, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome... Logo
1,049 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
