Can you help me to solve my samsung tv model no cs-29z40mq dead set but you can heard the oscillation sound inside near the power supply.
This problem is not consistent happening some other day have power but some other day no pwer.
    Genius:
  • 1,212 Answers
It is likely to be a failing capacitor on the power supply board. If you do open it up, check for any bulging capacitors (small round metal cans with a plastic label.) or any that may be oozing material out the top or bottom. Those that show such stress should be replaced with High Ripple Current types of the same working voltage or slightly higher.
Posted on Oct 30, 2012
  • Emerson P. Mante Nov 02, 2012
    Hi John,I open my flat panel samsung television I am very excited to see a bulging or oozing capacitor near the power supply is there any solution to fix my samsung picture tube type TV? Thank you.
    Sorry I don't see any bulging or oozing capacitor..
SOURCE: Protron PLTV-3250 fried
A possible solution would be to obtain a schematic for the power supply. If we're technicians, this should work out for most of us.
Keyword on schematics....OBTAIN! John
Posted on Jul 24, 2008
  • 257 Answers
SOURCE: samsung lcd tv le40r8. tv will not switch on.
The problem is the mainboard tried to turn on TV but failed due to internal circuit problem. Normally, the power supply board is malfuntioned.
Posted on Aug 13, 2009
SOURCE: ETEC 50" PLASMA TV MODEL #PH-50FB31. NEED: POWER SUPPLY
I have this part for sale!! If you haven't found a solution, let me know. The only problem, is i'm in France. Depends how bad you need it i guess!
Ps it's a new item
Leon
Posted on Nov 30, 2009
  • 9 Answers
SOURCE: I have no piture and no sound the pwer indicator
I have the same television and the power supply was bad, I had no lights on the front at all so I tried replacing the capacitors on the power supply thinking that would fix it. That did not fix it and I was told that not only do the capacitors go bad but sometimes something else on the power supply board goes bad and is very hard to diagnose without the proper training, so i bought a new power supply board. I put the power supply in and I then had all the lights on the front but the red led light on the power supply was blinking and the lcd would just show the polaroid picture on the screen and would try to light the back lighting but would immediately turn off.
I took a blow dryer and slightly warmed up the 5 blue capacitors that are on the main processor board "not the power supply board". 3 of these capacitors are 470uf @ 50 volts and the other 2 capacitors are 470uf @ 25 volts. It appeared that once the warmth did it's trick, it took a few minutes after warming them, the Tv now turns on. I am going to get these five new capacitors and change them on my main processor board (not the power supply board). I am guessing that either one of these capacitors or maybe all 5 are starting to malfunction, 2 of these capacitors do appear to have a slight bulge and crease on the silver top.
Watch your screen from behind the tv when turning it on, if you see the backlight turn on for about 2 seconds when the polaroid screen appears and then turn off you may very well have the same 1-5 capacitors malfunctioning on your main processor board. With that said if you feel that the power supply board is functioning as it should be and it sounds like it is then if you do not feel comfortable changing these five blue capacitors on the main board then you could always try replacing the main processor board with a new one. I believe that www.discount-merchant.com or www.shopjimmy.com has this board. Just get the part number directly from your old board and look that number up on their website. It is heart breaking almost using process of elimination when you have to spend money buying boards to accomplish this but I can tell you this, "electronics repair just for checking it out = $100 or more and then the price of the boards so you will reach well over $200 i would think" replacing the power supply cost me $78.00 and even if i have to replace my main processor board that will cost about $60.00 so I am still only at about $138.00, a new LCD tv of this size would cost about 350.00 or more. Now this information is only good considering that you feel comfortable enough changing the circuit boards yourself, be very careful of what you touch and try to touch only the outer edges of the boards.
Posted on Dec 08, 2009
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
Can u tell me how to get a service manual of this samsung tv model no. cs-29z40mq?
you can try writing Samsung or emailing their customer service (refer to the web for "contact" details under Samsung's website), or possibly on eBAY...
Sep 11, 2014 | Televison & Video
The tv is a plasma TX-P50S21B Panasonic.After pressing the power on button,the power indicator flashes green very fast 30times then the power relay clicks of.The power indicator then flashes 7 times...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem....
Aug 01, 2011 | Televison & Video
Sanyo tv model no. ST-21G1 power indicator is just blinking it does not oscillate the horizontal output. what is the possible problem or parts to be replaced?
Check if Horizontal ouput is shorted.Check if you have B+ (135VDC) power supply and secondary supplies working(12VDC, 5VDC) and check if you have horiz. drive pulse from drive transformer.
A common fault for dead set is the capacitors in the power supply (secondary of transformer) - no 12VDC supply.
Oct 22, 2009 | JVC AV-27950 27" TV
SAMSUNG T.V MODEL; CS-29Z40HE This T.V buy on JULY 2007 PROBLEM; No power; total dead; no red led stby; have beep sound...tick...tick...like not enough power when power on (maybe sound come from relay)....
Check the PTC parts,the primary AC power supply board.Disconnect the power supply board,measurement the capacitors and power tranzistors,measurement the output voltage(155V),connect on the output on 60W electric bulb,if it light the power source is ok and the problem in the horizontal driver parts(trafo,power tranzistor...).
Sep 27, 2009 | Samsung Televison & Video
Samsung lcd tv le40r8. tv will not switch on. power into set red light flashing on and off. clicking can be heard from inside tv, near mains plug
Aug 13, 2009 | Televison & Video
TV will not turn on. Clicking noise heard from inside.
These sets use what is called a "switch mode" power supply. In order for them to work there is a capacitor that "kick" starts the process. If that cap goes bad, the power supply will not start up. Also, there are other caps inside that maintain the oscillation required for the power supply to work. There are 2 options for you here.
1) Replace the entire power supply module.
2) Repair the existing one.
Sicne these types of power supplies are not the easies to diagnose or repair, I would suggest that you replace the power supply module. That should resolve the problem.
Please note that there are other causes of the reported problem, but hte power module becoming defective is the most common.
Dan
Feb 10, 2009 | Akai PT5492S 54" Rear Projection...
Panasonic
check the following, at the w/shop
power supply transistor,zener diodes, fusable resistor, line transistor, near line transformer,
your tv is not oscillating so even the ht voltage of 90-110v from power supply be checked.
Nov 13, 2007 | Sony KV-36XBR450 36" TV
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Nec tv dead set
ok ur tv has no second oscillation check all oscillation circuit. check the horizontal output! check the switching transistor around at the chopper supply.
Sep 06, 2007 | Jensen TS2750J TV
Samsung txe2745 just quit working -- has an internal "clicking" like a relay trying to close
First of all greetings from Belize mike your set is an old set but you can still get some life out of it please be inform that going into a tv could cause you self injury if you are not qualified to handle an electronics set.the problem with your set is in the power supply there is a 10mf cap situated in the power supply just close a transistor replace it along with power requlator and associated diodes.that will solve your problem.but make checks in the power supply.if you cannot do it yourself take the set to tech.good luck.
Nov 21, 2006 | Samsung TXE2745 TV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
