Question about Crown XTI-1000 Power Amplifier
It's sound very low
When i raise the volumn, the still low
  • andrew Nov 23, 2012
    I send it to shop techician, but they say my power amp configuration setting is corrupted and need new setting with the computer. Is there anyway how to do this. Thank for help.
    Genius:
  • 1,212 Answers
Double check the condition of the cables, make sure nothing is shorted or broken.
Is your music source 1 volt peak to peak (or line level)? If not add a preamplifier if input is lower than that or attenuate the input if higher than that. If you have line level input, make sure the input is turned up to an optimal level for output with headphones. See that you are getting correct response on the input LED level indicators. If all are lit up, you need to attenuate the signal before it plugs into the amp.
Check your system presets, check to make sure DSP is "OFF"" at least for now. And then check to see if you have "Briged" "Stereo" or "Mono" selected. If you plugged one speaker in and plugged it into the jacks for the bridged configuration, you are fine, if you plugged into one or the other, or used two speakers, You would want "Stereo" at least for testing. "X-over" would only be needed for Bi-amping a mono imput. And scroll through the other presets to see that limiters are off, and that system is not muted.
Then turn up the amplifier volume.
If you wired 3 speakers to it, that might be why.
Other possibilities are impedance mismatch between output and speakers,
This url has the Manual and specifications you can download
http://www.crownaudio.com/usa/xti-series.html
If the unit shows any signs of having been dropped, there may be broken solder tracks internally. such an event as being dropped could cause some of the issues you are encountering.
Posted on Oct 30, 2012
Where is volumn control located on Mac Book
F12 increases volume. You may need to raise the volume on the browser before you go full-screen.
Feb 15, 2014 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Samsung lcd volumn ok with dvd very low with tv only
What is it connected to when the volume is low? How is it connected
Feb 06, 2013 | Samsung LN-S3251D 32 in. LCD HDTV
The volumn on my elemnt tv goes to 63,it is very low
Look first to see if a DVD etc connected by itself to a rear input on the set gives you normal sound or not--this will rule some possible things out.
Jun 15, 2012 | Element Televison & Video
I just bought a Behringer K3000FX amp and it sounds GREAT with my keyboard. However, just bought a Shure SM48S voice mic and it just doesn't come thru the amp with much volumn...have to turn amp
Greetings! Ok, your amp has an XLR (3-prong) Low-Impedance input on Channel 1 for a Mic. All the other inputs are 1/4" High Impedance inputs, which are for instruments and/or other High Impedance items including low quality High Impedance Microphones. The SM48S is a high quality Low Impedance microphone, so if you use it with a 1/4" plug, it will be in a High Impedance channel, and will be very LOW in volume in comparison with everything else. So, you must use an XLR (3 prong) cable from the Mic to the Channel 1 input on your amp. That will do the trick. Good Luck with your new amp and Mic!
Dec 02, 2017 | Behringer Ultratone K3000fx 300w Keyboard...
Amp will play at low volumn but not when turned up
probably.
almost sounds like your speakers are worn out, and when you turn the volume up, they clip n no sound comes out.
Jul 31, 2010 | Alpine PDX-4.100 Car Audio Amplifier
Water volumn is very low, hot or cold. Barely a
take the aerator off the outlet or spout, it's clogged.
Jun 26, 2009 | Price Pfister Marielle Kitchen Faucet with...
I do not have any volumn control
Open the speaker where the volume control is located then check it if there are lose connections. You can also clean the variable resistor or the volume control with a contact cleaner solution or oil... ^_^
Jan 19, 2008 | Yamaha YST-M7 Computer Speakers
Poor sound quality
This is just a guess but the dolby sound on my system is bad however when I switch to regular "stereo" sound it improves. See if your audio set up has a choice of sound and try them all.
Aug 24, 2007 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Crown XTI-1000 Power Amplifier Logo
Top Crown Computers & Internet Experts
john h
rhodesworks
Are you a Crown Computer and Internet Expert? Answer questions, earn points and help others
