My washing machine does not spin and when it starts to request for water, it stops in the middle and shows E09 on the screen. Please I need help. Thanks.
    Problem Solver:
  • 6 Answers
If you're really in a hurry, can not find a solution, you can ask the customer service hotline, the time to buy some warranty phone, you can call to ask, maybe there will be resolved.
Posted on Oct 30, 2012
SOURCE: WASHING MACHINE FILLS WITH WATER AT START THEN STOPS SHOWING ERROR 5
the carbon brush may be worn out and need replacement(these are a pair of componet that makes contact to the motor. Francis
Posted on Jul 16, 2007
hotuna
  • 288 Answers
SOURCE: Washing Machine stopped through cycle and now will not turn on
Check the wiring harness, connections, contacts, etc. Look for some corrosion and loose connections. Also, check the water inlet for anything that may cause a reduction in water flow.
Posted on Dec 02, 2007
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
kevin_getz
  • 1031 Answers
SOURCE: Kenmore washing machine stops mid cycle
Sounds like a dead Drain Pump.
Posted on Dec 14, 2009
SOURCE: washing machine Samsung Triflow SW65ASP not spinning anymore
I had the same problem it was the pump filter on the back. unscrew it and clean it. That worked for me.
Posted on Jan 31, 2010
How can I correct error e09 f01?
I had the same problem but the reset suggested above didn't work for long. As it turns out, I had a sock stuck in my trap. Gettign to it was a pain because this model doesnt have a convenient access door in the front. I made a video below that can show you how to check the trap.
Feb 13, 2016 | Whirlpool duet Washing Machines
Do washing machine water pumps some how can get that hot from something being already wrong cause the water pump to melt down?
pump running without water will get hot enough to melt plastic .and that would suggest a plugged filter to me
Sep 30, 2015 | Washing Machines
It stops spinning in the middle and shows on the screen E 90. I need help please.
Sometimes if you unplug it wait 10 minutes and plug it back in it will reset.
Nov 28, 2012 | Washing Machines
E09 PUMPS OUT WILL NOT SPIN
E09 ON HOOVER WASHING MACHINE WILL PUMP OUT BUT WILL NOT WASH OR SPIN?
Oct 31, 2010 | Hoover Washing Machines
I have a Kenmore Washer that stops in the middle of the washing cycle. The water doesn't drain or anything. I have to take all of the clothes out and scoop out 90% of the water and than turn the washer to...
Hi
Thanks for using FixYa. Please check the belt and lid switch or a broken lid switch plunger. Also check the lid switch actuator and the timer. Please replace whichever is required to be replaced.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 11, 2009 | Kenmore Washing Machines
Whirlpool washer stops in the middle of cycle does not rinse and
If your washer stops at the same time each wash, you have a dead spot in your timer. It will need to be replaced. .
Aug 15, 2009 | Washing Machines
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
395 people viewed this question
Top Washing Machines Experts
