Question about Car Audio & Video
I am wondering how to install neon speaker rings I have 2 10" rings and i cant figure out how to wire them together, can anybody help me with that?
  • 77 Answers
The speaker neon lights can be wired in directly from the negative and positive speaker wires by simply splicing them. in most casses this also causes the lights to pulsate with the music. in most 12 volt applications the positive and negative wires are generally transferable and do not cause damage when hooked up in reverse
hope it helps
ryan
Posted on Feb 18, 2009
Neon sign shuts down
there is a weak connection in the wiring. there may be a back panel that you can remove with a screwdriver to view the wiring
Feb 16, 2013 | Neon Sign Inc Budweiser Neon Jacksonville...
One of the wires from the main speaker got chewed off by my daughters pit rabbit. The speakers are not working due to this and what is the best way to restore functionability to the speakers?
if you can replace the speaker wire would be the best way to repair your sound but if you cant replace the whole speaker wire you might have to replace a section or join the wire together using a soldering iron or a crimper joiner peal at least 2-3mm of the plastic covering the speaker wire separate/spread the wires then intertwine them together to solder them together you must flux the wires before soldering if you use the crimper slide the crimper on to the wire before you intertwine them or you might just join them together intertwine them and place some electrical tape around the join
hope this helps
Mar 27, 2011 | Computers & Internet
Samsung Rant ... Speaker is muted & cannot hear a thing AT ALL!! There is absolutely NO SOUND on the speaker (ear speaker & loud speaker). Phone makes calls out & rings for incoming calls but...
For the time being have you tried using a head set? I think this is due to the way the sound wires have been soldered together. I would not attempt to try and fix the problem yourself. If the headset doesn't work I suggest it's the way it's been programmed. Btw have you tried looking at your settings?
It might work if you put it on vibration. Does it work when it's off muted?
Hope I cleared a few things up Dr Reed
Apr 05, 2010 | Samsung Rant Cell Phone
2001 neon wont start when hot starter, relay and ign. switch have been replaced. Even my mechanic cant think of the problem. Has enough power, turn key all power comes on (lights, stereo, gauges) but turn...
Have him check the resistance in the wiring when the vehicle is hot. It sounds like a wire is heating up too much and not letting current flow through it properly.
Sep 04, 2009 | 2001 Dodge Neon
Traxxas Revo 3.3 engine cooling head
Remove the glow plug wire and there are just a few bolts that hold the head on. Just make sure you install the new head with the head shims like they were under the original head.
Jul 03, 2009 | Traxxas Rc Revo Nitro Monster Truck
2005 Neon SXT Stereo Wiring Diagram
2005 Dodge Neon Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jun 19, 2009 | 2005 Dodge Neon
I can't get any radio reception.. Do i need to hook up the power antenna wire on a 2006 ford fusion?
if you have the model with the antenna that extends itself as opposed to the stationary ones, then you might have to. we're having the same problem with my friends neon, but we cant figure out which wire to connect it to.
if you get a wiring diagram for the car, it might come up as "power antenna/amp" or something of the like. with ford, i believe its a white wire, but i could be mistaken.
Aug 14, 2008 | Car Audio & Video
Blackberry 7105
I cant figure out how to change ring tones and how to change the volume of the rings for incoming calls .
Anybody can help me please?
thanks a lot
Jan 19, 2008 | T-Mobile BlackBerry 7105t Cellular Phone
Car Audio & Video Logo
83 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
