Question about Invacare Pronto M51 Power Wheelchair
I need a seat for my pronto m6
I have everything else im just looking for a seat.cant find anything to fit on the base
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 104 Answers
Check around at as many nearby DME providers as possible. most have an old seat or two in stock. ask to take an old one off their hands and bargin with them. most have one they'll like to get rid of to make space
Posted on Oct 31, 2012
2 Suggested Answers
wcdoc1953
  • 280 Answers
SOURCE: I NEED A WIRING SCENATIC FOR AN INVACARE PRONTO m6
I assume you need a wiring schematic for an M61. The circuit board schematics are proprietary and not available. The component schematics and interconnects for switches and wiring harnesses are available, as are the parts diagrams and drawings. Please clarify your specific need and issue.
Posted on Oct 24, 2010
I have a invacare pronto m6 electric wheelchair that has not been used in 4 years. bought new batteries and after installing the power would not come on. Is there anything else that needs to be done.
screenshot (16)-rsjrp3ig2lfdn21ja5gptsgl-3-2.png Hopefully the drawing will transfer, Item 8 is a 30 amp reset breaker, make sure it is not tripped, also make sure all connectors are making good contact by unplugging and plugging back in. Also the brushes in motor may be stuck due to years of non use would advise you get electrician to check that problem.
Jan 12, 2018 | Invacare Health & Beauty
How to change battery on pronto m51
The Pronto M51 has two batteries in the base. The seat has to be removed to change the batteries. The M51 has had several methods of removing the seat from the base. The oldest models have a long bolt that holds the seat to a center post that sticks up from the base between the batteries. The next version has a spring loaded red handle just under the right side of the seat. If you have one of these designs you must lift the seat straight up off the center post. If not lifting straight up the seat will not come off.
The last style has the seat frame bolted to the base frame in 4 positions. Only one bolt at each corner post needs to be removed.
Oct 11, 2014 | Health & Beauty
What does 1 red flash followed by 5 green flashes mean on a Pronto M6
1 red + 5 green is left parking brake fault. This is a pretty generic code and can be something as simple as the brake/clutch lever is in free-wheel, or it can mean something more significantly wrong, depending on how it is wired in this model. (We don't work with Prontos a lot here.)
May 02, 2014 | Invacare Supply Group Pronto M61 Standard...
Does maxi cosi cabriofix easy base require anything to be removed from it before fixing it? we cant find where the button is that fixes it to the seat
Hi
Can you clarify - what button are you looking for?
The EasyFix base is fitted into the vehicle using the IsoFix points OR the 3 point seabelt. (Never both) The carseat then clicks onto the base and the metal rods on the underside of the CabrioFix carseat are grabbed by clamps on the base.
May 26, 2012 | Maxi-Cosi Maxi Cosi Mura 3 with Free...
Hi, I have bought a second hand Quinny Buzz 3. The problem is I don't know what years model it is - it only came with one seat unit in a silvery purple colour (possibly purple reflection?). I would...
hi
the new seat fabric does not fit the older model seat frame but
the new model seat unit as a whole(with the metal frame) will fit the older model
that is the only difference between them everything else fits the older model
does that make sense?
Im not sure if the older fabric fits the new frame but it is worth ago if you need the larger seat later on
if you need further info please leave a comment and i will help further
Nov 16, 2010 | Quinny Buzz Jogger
I have a Pronto M6 wheelchair that is not working. I called technical support and they suggested it needed new batteries and that the batteries should be replaced yearly. I installed the new batteries...
Make sure all of your connections are tights and the your fuses do not need to be replaced.
Blinking lights on the controller usually indicates a problem, the number of blinking lights are used to diagnose the problem. Take a look at this website to identify the type of controller you have on your scooter so you can dtermine what the blinking lights are trying to indicate.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Oct 12, 2010 | Invacare Supply Group Pronto M61 Standard...
Oct 10, 2010 | Invacare Health & Beauty
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
May 15, 2010 | Invacare Supply Group Invacare Pronto M91...
Invacare Pronto M51 Power Wheelchair Logo
56 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
