Question about Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover
I have a Yamaha 1100 2008 waverunner. I am concerned about the water flow at the back. It is rather slow. I check the inlet and impeller and see no obstruction and the impeller turns with no pressure. Help
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Yamaha Master
  • 1,190 Answers
Run on hose adapter and check engine is cooling by feeling the engine and exhaust system ! if ok then check intake water pipe is clear ! 2 or 4stroke?
Posted on Jun 09, 2014
Starts and runs and RPMs are good but it won't go above 5 MPH. Checked intake and I have the rooster tail of water but no speed
you may have to check the pump unit for obstruction
the impellers are known to wear from abrasion from sand in the water and not operate efficiently.
May 29, 2015 | Yamaha 2011 WaveRunner FX Cruiser SHO
What is the thread on coupler to midshaft left or Right? this is on a yamaha waverunner 1200xl limited
Counter clockwise, it has normal right handed threads. The only part with left handed threads is the pump/impeller shaft.
May 28, 2014 | Yamaha 12V Air Pump
Yamaha waverunner
rubbish /plastic bag caught up in the pump inlet pipe or in the impeller of the pump
Sep 11, 2017 | Sport & Outdoor - Others
Waverunner is abnormally slow accelerating initially, but will finally get up to normal speed
Pull your air filter out and also replace plugs. Overtime the filter will become saturated with oil and believe it or not the plugs can cause about a 10 mph drop if there going bad. But make sure your pump and impeller are not damaged also
Sep 18, 2013 | Yamaha 2004 WaveRunner FX Cruiser
2009 Yamaha vx cruiser waverunner used to do 55mph now won't pass 35 mph
Nevermind those other answers, if its running on all 4the cylinders but just real sluggish and missing top speed then listen up, let's first rule out the possibility of a damaged impeller, now locate your airfilter box and remove the filter, just throw it away because last I checked dirt really doesn't settle on top of water, now locate your throttle body and remove the intake tube from it, now take out the 4 bolts that hold it on and find your flame arrestor element. I've dealt with this problem many times only to find out that the geniuses at Yamaha had installed this screen right after the butterfly which accumulates airfilter material and clogs
Jun 24, 2012 | 2003 Yamaha YZ 250
Need Help On A 1994 Yamaha Waverunner 3
Check your pump and impeller, then trace water inlet hose from back to front, possibly have a flush kit thats missing the cap?
Apr 30, 2012 | Water Sport
1996 yamaha waverunner is overheating. has a good water flow. what would cause over heating?
most common problem with overheating when you have good water flow is the thermostat is stuck open replace it.
May 31, 2011 | Yamaha Boating
The water flow from my pump slows to almost nothing after 5 or 10 minutes. I change the filter and it has a great flow for a few minutes then slows to a trickle.
There are screens at the hose connections to the pump and at the inside pool outlets and inlets. Check to make sure their clear. Also be sure your using a New filter not one you have cleaned off.
Jun 25, 2010 | Intex Krystal Clear Model 635 Pool Filter...
I have a 2003 yamaha 700 waverunner. It starts
if u did any modifactions to the air intake than that could be a reason.
Jul 23, 2009 | Water Sport
Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover Logo
343 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
