Question about Lenovo ThinkStation S30 Xeon 500GB HD
How to get into hibernation/sleep mode for lenovo s30 thinkstation
How to take out lenovo s30 workstation from hibernation/sleep mode?
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: lenovo thinkstation restart continuously what ido
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps
Posted on Jun 26, 2012
Headphones and speaker recognized as only one device.
usually when you plug the headphones in to the front socket the speakers that are plugged into the rear socket will automatically stop
Mar 18, 2016 | Lenovo ThinkStation D20 4155G8U Tower...
Lenovo thinkstation s20 desktop pc restart continuously what i do
I'd check all the fan, make sure they are clean, especially if there is a video card. I suspect it might get too hot.
May 22, 2014 | Lenovo ThinkStation S20 Workstation...
Change boot order bios key
Ctrl-L "..to get into BIOS requires a very quick trigger finger to catch the right point to execute the CNTRL-L command. " (Taken from http://www.crn.com/reviews/components-peripherals/209903868/review-workstation-workhorse-lenovos-thinkstation-d10.htm )
If it's asking for a BIOS "key" or password to enter the BIOS, and you didn't set one, this article should help:
http://forums.lenovo.com/t5/ThinkStation-Knowledge-Base/How-do-I-reset-the-BIOS-and-or-password-on-my-ThinkStation/ta-p/542883
Oct 31, 2013 | Lenovo ThinkStation D10 Workstation...
Cant get power saving mode off
Step 1:
Sleep Mode b> Sleep mode is primarily used with home computers (desktop computers). Sleep mode is designed to save the current work, programs, and settings of your computer using your computers memory, while using very little power. b> Hibernate Mode b> Hibernate mode is primarily used with laptop's. Hibernate mode is designed to save your computers current state on to the hard disk, then turn off your computer to stop using power completely. This mode is usually used when you do not plan on using your laptop for an extended amount of time. Benefits b> Using Hibernate mode is more power-efficient, but files may become fragmented over time by using this mode frequently. Sleep mode does consume more power, but the advantage that Sleep mode has over Hibernate is that it does not take as long to resume your computers former state when you are ready to continue using it.
Feb 23, 2013 | Lenovo 3000 Computers & Internet
No audio device installed
The same model ThinkStation can have different types of network, video and audio drivers and unless you know exactly which one is installed in your ThinkStation, you need to download all the drivers and install each driver until you find the right driver. When you download the drivers, write down the device driver and it's file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive. Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows device drivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
Jan 20, 2013 | Lenovo ThinkStation S10 Workstation -...
Windows random freezes
Follow these guidelines to fix the problem instantly:
  • Remove unused programs
  • Install and run antispyware software
  • Free up wasted space with Disk Cleanup tool
  • Defragment your hard disk drive
  • Delete Temporary Internet Files
  • If problem still persists then use system utility tool Reginout for an instant fix
Jan 17, 2013 | Lenovo ThinkStation D10 Workstation -...
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Lenovo IdeaPad Y510 screen will just go black like it is going into hibernation while working on. Turned off all hibernation and sleep modes but still does it. Has anyone else had this problem and do you...
I recently worked on this exact problem.
We updated the video drivers to the most recent release.
I thought this fixed the problem but is re-surfaced a few hours later.
Then we flashed the BIOS to the most current version and reviewed the BIOS settings to ensure they were set the way we wanted them.
The problem appeared again the very first boot after flashing the BIOS. We re-booted and it hasn't happened again.
We are cautiously optimistic that the problem has been resolved.
Mar 31, 2010 | Lenovo IdeaPad Y510 Notebook
Lenovo ThinkStation S30 Xeon 500GB HD Logo
93 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
