Question about Cannon Office Equipment & Supplies
Canon i960 yellow lights blinks 5 times and printer does not print.
    Genius:
  • 1,142 Answers
Try to reset the printer to the factory settings.
Posted on Jan 03, 2009
  • 1 more comment
  • Maanita Chadha
    Maanita Chadha Jan 03, 2009
    Solution:
    Reseat the print head i950 / i960
    1. Confirm that the printer is powered on.
    2. Open the paper output tray and top cover.
      Note: Gently open the paper output tray while holding it.
    3. After confirming that the print head holder has moved to the center, open the inner cover.
    4. Remove all ink tanks.
    5. Raise the print head lock lever and remove the print head.
    6. Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
    7. Insert
      the appropriate ink tank into the slot at the right end and push down
      on the PUSH mark on top of the ink tank until a click is heard. Install
      the other ink tanks in the same manner.
    8. Close the inner cover and top cover.
  • Maanita Chadha
    9. Properly install
  • Maanita Chadha
    Solution:
    Reset the printer
    Resetting the Printer
    By
    resetting the printer's power, the print buffer is cleared and certain
    sensors are reset. If there is invalid data in the buffer, or sensors
    are stuck in a particular mode; errors may occur.
    Follow these steps to reset the printer:
    1. Turn the printer off with the Power button (if available).
    2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
    3. Unplug
      the printer's power cord for approximately 10 minutes, and then plug it
      back in. If troubleshooting a communication issue, reconnect the data
      cable (not applicable to WiFi, Bluetooth or Infrared).
    4. Turn the printer back on.
Won't respond to computer, light on printer alternates flashing between green and yellow
  1. Start with the printer OFF
  2. Hold down RESUME button and then hold down POWERbutton
  3. release RESUME button
  4. press RESUME twice, then release POWER
  5. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Press 2 times for EEPROM reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Jo
Feb 19, 2011 | Canon i850 InkJet Photo Printer
Printer does not print. yellow light blinks 5 times
Printer does not print. yellow light blinks 5 Problem with the Canon i9900 InkJet Photo Printer
Aug 03, 2010 | Canon i9900 InkJet Photo Printer
I960 resume light flashes yellow 5 times 1 green
Five yellow flashes indicate that the printer doesn't recognize the print head, or thinks that the wrong print head is installed. You can try to remedy this by opening the cover, removing the ink tanks, then removing the print head (lift the locking lever). Check that the copper contacts on the back of the print head are clean, then reinsert the print head, lock it in, and reinstall the ink tanks. If you still have the error indication, the print head may be bad and need replacing. Contact Canon for your options on this.
Feb 05, 2010 | Canon Office Equipment & Supplies
Light flashing green and yellow will not print
Hi this is only a try it may work
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Jan 14, 2010 | Canon i850 InkJet Photo Printer
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Cannon i960 blinks 1 green , 3 yellow etc... Won't print sayas pa
Canon i850, i950, S600
2. release RESUME
3. press RESUME twice, then release POWER
If I could be of furtheme know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Cannon Canon i960 Photo Printer
My canon i950 waste ink absorber is almost full
3. release RESUME
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
Mar 17, 2009 | Canon i950 InkJet Photo Printer
Canon i950 won't print
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
3. Release RESUME
one by one
Jan 25, 2009 | Canon i9900 InkJet Photo Printer
Canon i550 cannot print
Try the below procedures maybe the error of your printer is the waste ink counter.
Canon i550, i560, i850, i950, i960 (May work with i860, i865)
3. release RESUME
Apr 10, 2008 | Canon BubbleJet i550 InkJet Printer
24 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Iqbal Husain
Iqbal Husain
Victorman
Victorman
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
