Question about Nokia 2700 Classic
Nokia2700 battery not backup and heating - Nokia 2700 Classic
My nokia2700 classic is hanging. what will i do?
Just try freeing the phone memory
1. backup messages and delete them
2. move all data from phone memory to external card memory.
then restart.
Dec 10, 2011 | Nokia Classic 2700 Cell Phone
C 5 battery heat also board heat. it only few min switchoff the mobile.
Battery heating =Board problem. Or more radiation. U r running too much application in background. Disable the autostart application.(antivirus) etc download mobileguard application it would help. Www.netqin.com
Dec 07, 2011 | Nokia C5 Cell Phone
I locked my nokia 2700 classic with security code. I forgot that code and tried some other codes, it doesn't work, i have restart the phone and tried again but phone is still locked. Please help me.
Hello CCF,
Switch off the nokia classic 2700 phone. Remove the battery for 30 minutes. Reinsert the battery and switch on the nokia classic 2700 phone. Enter the default code 12345 or 00000. Your nokia classic 2700 phone will be unlocked.
Jun 09, 2011 | Nokia Classic 2700 Cell Phone
NOKIA2700 CLASSIC PHON LOCK
Hello Mahaveer,
Switch off the phone. Remove the battery for 30 minutes. Reinsert the battery and switch on
the phone. Enter the default code 12345 or 00000. Your phone will be unlocked
May 10, 2011 | Nokia Classic 2700 Cell Phone
I forget my nokia2700 phone password,so what requirment break the password.
What is your IMEI number?
its written under the battery on the mobile case
Feb 23, 2011 | Nokia Classic 2700 Cell Phone
Why does battery beep and tells me its on battery power when it's stil plugged to wall. and i have a good power source
Usually that indicates a low battery charge or bad battery. Make sure you do not have the battery backup side overloaded with too many devices. Do not plug inductive loads with motors or heating elements into the backup. Turn the device off and unplug anything that is plugged into the bachup. Plug the battery backup into the wall with nothing attached and turn on. Wait 10-15 minutes. this will charge the battery. If beeping continues after this with nothing attached, you likely need a new battery or the control/monitoring system is bad. If beeps stop, reinstall and do not attach more wattage than the unit can suppluy
Jan 06, 2011 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
Nokia2700 security code forget
follow this but you will lost all the contacts, so try making a backup before proceeding,
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Jan 04, 2011 | Nokia Classic 2700 Cell Phone
My nokia2700 classics keypad is locked and i forgot the unlock code. Can u help me to unlock my phone.? from india, idea cellular service. Rakesh
You can unlock your phone by following the below procedure:
1. Take off the battery of your mobile phone
2. Switch on your mobile again by reinserting battery once again.
3. Goto Settings->phone->Automatic Keyguard->Off
4. Exit
Dec 13, 2010 | Nokia Classic 2700 Cell Phone
Hello!! my boss would like something that will back this up incase the power went out he would be able to use his computer for atleast 2 hours
no that is impossible because inverter transformer is so weak and not able to tolerate the heat and heatsink of mosfet is also very small and unable to dissipate the heat for long time you have to purchase LTmodel(long time backup)ups
Mar 29, 2010 | Opti -UPS PowerES 650 UPS System
Nokia 2700 Classic Logo
104 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
