Ipads cannot connect to my home Wi-Fi
I have the following Network Adapter and the driver is up to date: Broadcom 4322AG 802.11a/b/g/draft-n Wi-F Adapter. Visitors to my home having tablets or iPads are unable to connect to my Wi-Fi even after entering router key and password.
  • Charlie Sorrells
    Charlie Sorrells Nov 02, 2012
    People with laptops are able to connect by inputting my router password.
Risingsunn
  • 8 Answers
SOURCE: Wi Fi driver downloading
I was just on that link that you sent me and it includes a walk through on how to run it, but from what I understand you are saying after you overwrite the files, it still does nothing?
Ahh.. Now that I downloaded and ran the file, I can see your dilemma. It doens't do what the instructions say it should..
That's ok.. To launch the installer, click on start and go to run. In run type in "C:\cabs\D00464-001-001\setup.exe" (without the quotes) this should launch the installer and put all needed drivers and files on the system for your wireless card.
Lemme know if you have any other questions, good luck!
Posted on Sep 26, 2008
  • 137 Answers
SOURCE: Broadcom 4321AG 802.11a/b/g/draft-n Wi-Fi-Adapter datasheet
that depends on the network traffic to and from your computer..but it will never be 0 once connected..
Posted on Jan 26, 2009
SOURCE: wi fi connection
Try to check on the device manager if the wireless adapter and the ethernet adapters were installed properly. If it appears with a questionmark, uninstall it and try reinstalling it without the ethernet cable connected.
If you are using Vista system, after installing the adapters, go to the network connections and just click on tcp/ip then click on properties. Exit from the window by clicking ok until all windows will be closed for the network connections. Reboot your pc and try if you can obtain a connection.
Posted on Mar 11, 2009
leecom72
  • 4806 Answers
SOURCE: I have an Acer aspire
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
Go to your laptop, right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck
Posted on Aug 03, 2009
HOW do i use wps on my ipad with WNR2000
Depending on your browser, download or display the pdf of the WNR2000 manual ( http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf ). The manual might also be found on the CD that came with the router.Follow instructions Chapter 2 Page 7 to enable/setup WPA2-PSK (AES).Make sure you SAVE/APPLY the settings before proceeding. Follow instructions Chapter 2 Page 17 to Disable Router's PIN. When you do, make sure you leave the box checked to "Keep Existing Wireless Settings".Make sure you SAVE/APPLY the settings before proceeding.Here's a work-around ff the above doesn't fix the issue for you. Sorry I don't have iPad-specific instructions, but I don't have access to an iPad/iPhone at the moment. I've done the following on iPads, iPhones, Android phones and tablets, Windows phones and PC's - it works on virtually all Wi-Fi-capable devices..:
Instead of letting your iPad find the network and trying to connect with the password, try manually creating a new Wi-Fi network connection by typing in your Wi-Fi network name (SSID), selecting WPA2 (AES) encryption and entering the Wi-Fi password your configured in STEP 2 above.Please note: You'll have to forget the Wi-Fi network in your iPad's settings if you keep your Wi-Fi network name (SSID) the same as it is currently.
May 25, 2016 | NetGear WNR2000 Wireless Router
Tip
How to connect your Apple iPad to the Internet
Connecting your Apple iPad to the internet is very simple. When you use a application that requires internet capabilities your iPad will do several things.
-The iPad will attempt to connect using the last Wi-Fi network you used that is available.
-If no network you previously used is available, the iPad will show a list of networks in range. You can then tap a network and if needed, enter a password to join the network. Any network with a locked Icon will require a password. These are secure networks.
-If no networks are available or if you don't choose one, the iPad will then connect over a cellular data network.
What is the difference between a cellular and Wi-Fi network? A Wi-Fi network is generally faster, but covers less of an area. Think of your home wireless network, or a wireless network at a library. It has limited range. A cellular network is generally slower but covers a larger area. Normally, if you are connected to a cellular network you will see a 3G icon or E icon at the top of your device. Also, you normally pay to use a cellular network.
To see all the Wi-Fi networks in range: From the Home screen, choose Settings > Wi-Fi. Tap a network to join it.
-G33k
on May 17, 2011 | Apple iPad 16 GB 3G Tablet PC
Connect to ipad
You don't assign an IP address to your iPad, it has one assigned to it by your router.
Open the Settings app on your iPad. Make sure Airplane Mode is OFF. Tap Wi-Fi. Make sure the Wi-Fi switch is ON, Ask to Join Networks is ON. Your in-home wi-fi network should be visible in the list titled Choose a Network.... Tap its name and provide the network password required by your router.
If you don't see your local router listed, it may not be properly configured.
Mar 10, 2014 | Tablets & eReaders
How to change MAC no of Broadcom 4322AG 802.11a/b/g/draft-n Wi-Fi Adapter on Vista OS........
Open "Device Manager".
Double-click the adapter.
Click Properties.
Select MAC-address.
Change it.
Sep 22, 2010 | Office Equipment & Supplies
Hi experts! I recently purchased HP tx2-1025dx with Broadcom 4321AG 802.11a/b/g/draft-n Wi-Fi Adapter preinctalled. have no idea why my connection (I have cable) is so slow not only home, but at Wi-Fi...
Wireless N is not standardized yet. The design(features & functions) will depend on the manufacturers. It is not advisable to use wireless N products from different manufacturers since they have it designed differently.
To maximize the features & functions of wireless N you need to have compatible devices. Meaning, I you're using let's say Linksys N router you need to use Linksys wireless N adapter.
Jun 08, 2009 | Broadcom BCM5705 Network Adapter
Jan 14, 2009 | Broadcom BCM94306MP - IEEE 802.11b/g...
Zone-Alarm Problems
Uninstall ZoneAlarm, then reinstall. Unfortunately, turning it off won't fix the problem.
Jan 25, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
