Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Hard Drive Dropped
I have accidently dropped my 250GB Seagate external harddrive from approx. 5 inches. My PC do not pick up any data storage devices when I plug it into the USB port of my PC. I have opened the casing to make sure that the 'USB Convertor PCB' was stil connected properly, which it was. Please help my on this matter, it would be much appreciatted
  • Dataless Jan 28, 2009
    Mine is a Seagate 160gb. I have a similar problem. The only thing is I'm not sure if it was the drop or (as strange as it may sound) the fact I accidentally clicked the uninstall ceedo software at the same time the drop happened. The disk is still spinning, thought the computer it was connected to and my other computer cannot see it at all while connected. There is no recognition at all. The light comes on, but there is nothing indicating its comm. :( Help.
  • Deboo Geek May 11, 2010
    Did you try connecting it to any other PC? Does it get recognized?
    There are some free hard disk tools available that can help in case it still is not getting recognized. Reply back and I'll get back with some urls. I do not remember them offhand.
    But first please check if the disk is spinning or not. If it is, then there are good chances of getting the data back atleast.
  • 3,051 Answers
Hi there
You may want to try going to add new hardware and see if scanning for hardfware change will let it recognoze the device if not uninstall it under device manager and have it reinstall the device upon start up of the pc
Posted on Feb 16, 2009
How can I retrieve data on a dropped/malfunctioned seagate portable expansion drive?
Not a DIY task. You need a professional with data recovery skills. There are few good ones around.
Jul 07, 2014 | Seagate Expansion 1.5 TB USB 2.0 Portable...
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
Hard drive clicks, fails to read but powers up. Approx 100GB of music files held and needs recovering. Laptop initially picks up drive on connecting to USB port but then drops out due to read failure.Drive...
Inside that plastic external case of the Hitachi XL 1000 external harddrive, is a regular desktop computer sized harddrive.
It is a SATA type of harddrive.
It is 3.5 inches across in Width. (3 and a half inches)
1 TB in size.
Looks similar to this example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5589521&CatId=2459
On the back end of the Harddrive is where it's power cable, and data cable are attached.
Inside the case of the Hitachi also is a small circuit board. (PCB or Printed Circuit Board)
The SATA harddrive is connected to this small circuit board.
The small circuit board, or Interface PCB , is attached directly to the Harddrive.
Or cables (Wires) are used to connect it to the Harddrive.
The Interface PCB is connected to the computer, via the USB cable that is attached to the Interface PCB.
It is this small circuit board that usually goes bad.
(Unless the external harddrive was on, and dropped. Then the problem is the Harddrive)
There are two solutions;
One, buy an 3.5 SATA external enclosure, and use the Harddrive as an external harddrive again.
Two, install it as a Slave drive in a desktop computer, and retrieve all your information. Burn to disk/s, or flashdrive/s.
When using a SATA harddrive as a Slave drive, there are NO jumper pins to mess with.
DO NOT change any jumpers on the back of a SATA harddrive.
(These are for the factory)
This is an example of a 3.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
There are no guides to open a Hitachi XL 1000's case, to my knowledge.
It isn't something the manufacturer wants stated.
However opening the external enclosure (Case) isn't that tough. It falls under the same as this model,
http://www.youtube.com/watch?v=hQ_vjyvK28A
Here we see at 3:00 through 5:00, that the Harddrive is attached directly to the Interface PCB.
Just remove the Harddrive from the chassis, and unplug it from the Interface PCB.
Regards,
joecoolvette
Oct 02, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
I've dropped my Western Digital 250gb hard drive & now its not working. The light on the device does light up & the computer recognises that something has been connected but you cannot see the...
I've similar problem with Samantha_500, i inadvertently dropped internal Harddisk (Seagate 80GB) with external case (M-Tech), the external case was broken into pieces (only the parts with plastic), the Harddisk is not working anymore, it detects by windows XP as a device connected in USB, but no drives detected in windows explorer. is there any way to recover this harddisk? thanks for the help in advance.
Dec 26, 2009 | Western Digital Passport WDXML800UE...
Seagate 1.5TB dropped from office table... TWICE.
the drive is damadged internally, you have to phone or email a data recovery centre to get your data back, that can cost $1500+ because of the size of the disk.
Oct 03, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
I HAVE A SEAGATE EXTERNAL DOES THE SAME THING
yes the PC will not boot when the external driver is connected, thats cause you dont have any boot files on the drive.
Jul 18, 2009 | Western Digital 250GB MyBook External USB...
Hard Drive Dropped
Turn off your computer and then plug in the FreeAgent external drive. Then try turning your computer on, it should read.  If it doesn't I would go to the Seagate website for troubleshooting.
Jan 31, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 500 Gig External Drive disappeared !
external harddrive turn them selves off after 5 minutes if it isn't being used.
Aug 06, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Lightly Dropped Seagate 100GB External Hard Drive
Your not going to like this, but remember you did ask..
The only way to recover your data is to use a data recovery centre.
You can try this place if you are in the USA
This is not an endorsement of that particular company, but an idea of what you will be dealing with.
For the record, there is no such thing as a light drop when it comes to hdd's. The drive will have recorded the damage as a G-Force that can be read off the controller board at the factory and will not be covered under any warranty either.
Sorry for the bad news.
Apr 30, 2008 | Iomega HDD External Desktop (32660) 80 GB...
Unfortunately, this probably means the read/write heads were jarred and can no longer function properly. That's usually fixable, but it's a very expensive fix because the parts are inside the hard drive and the data surfaces are very delicate... Most people are better off simply replacing the hard drive unless the data is absolutely vital.
Dec 06, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
170 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
