Fisher & Paykel C 450 Refrigerator wiring diagram
SOURCE: I would like to receive
Hi
Thanks for using FixYa. Before you begin to replace your defrost thermostat, makesure you disconnect the appliance's power supply. The easiest way to do this isto unplug the unit from the wall. Alternatively, you could trip the appropriateswitch in the circuit breaker panel, or you could remove the appropriate fusefrom your home's fuse box.
Please check your refrigerator's defrost thermostat in this picture--
Click on the image to zoom in. It is located under the floor of the unit. The thermostat is wired in series with the defrost heater, and when thethermostat opens, the heater shuts off.
The cover plate over the coils needs to be removed. Now remove the freezer door, and then the screws so that each side of outer fridgecover is detached. This will to enable cover plate to slide out. (Outer walls have to be pried out alittle). Defrost thermostat is located behind coils.
Also check the Defrost Timer which is located at bottom offridge frame next to compressor. A couple of screws and unplug and plug in new part. There are two wires leading from the thermostat. They areattached to terminals with slip-on connectors. Gently pull on the connectors torelease the wires from the terminals. You may need to use needle nosed pliersto help you. Do not pull on the wires themselves.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
SOURCE: Noisy, Chattering fan with fisher & paykel fridge.
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.....
SOURCE: fisher paykel e522bre active smart refrigerator
you need to have the defrost element replaced !!
SOURCE: I have a Fisher & Paykel Refrigerator. The
Hi! The refrigerator has dual valve with two coils at the back and the ice side may have gone bad thats why it doesnt make ice. YOu will have to have it replaced to get your fridge back to its normal working condition. Hope this helps and have a good one!
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
