Question about Apple MacBook Housing, Top Case with Keyboard Version 2 Mac Notebook
A1181 mac book stuck on grey screen with spinning wheel
shawty-lozzy
  • 151 Answers
SOURCE: Can't boot up my mac book air
hm, try leaving it on over night, sometimes if you turn your laptop of from the power or hold down the power button when allot of programs are running or if you get the program not responding thing happen this can mess up your laptop and will take ages to boot up,
or it might never boot again
so you will need to take the install cd/dvd that came with the laptop, insert it into your laptop, reset it again, then as u hear that sound apples make as you turn it on, hold down C untill it boots into the cd/dvd then go from there.
Posted on Jul 02, 2009
acsmappel
  • 61 Answers
SOURCE: Mac note book stuck on first screen page. cursor
Is it a blue screen with the circle of death? Did you just install leopard???? Then check this out: Leopard Blue Screen of Death.
Posted on Aug 04, 2009
MacAppleTech
  • 206 Answers
SOURCE: Grey Screen Apple Start up issue
It appears there may be a possible startup item or issue with your firmware, which may be causing this issue, so I am going to provide some procedures in order to help you resolve this gray screen issue. But first, let me help you remove that disc first:
font.f1 {font: 13.0px Myriad Pro} font.f2 {font: 14.0px Myriad Pro} Procedure #1 - Ejecting CD from drive
Here are some steps I recommend you try to resolve the issue with the disc not ejecting properly
• Reboot your Mac
• Hold down your Mouse button(s) prior to the Apple Chime
• Keep holding the mouse button down while your Mac boots up
• The disc should eject before you reach your Desktop
• When it does, simply release your mouse buttons.
If this does not help resolve ejecting the disc in your Macbook's drive, you are going to have to take more of a command-line approach:
font.f1 {font: 12.0px Helvetica} -EJECTING DISC USING TERMINAL-
From your Desktop:
•Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
• Locate and open the Terminal utility
• At prompt, type: drutil eject
• Now
press the Return key on your keyboard
(NOTE: If you have a CD/DVD drive with a tray, type: drutil tray open press the Return key on your keyboard )en
• This command line should eject the disc from the drive, unless there are mechanical issues with the drive within your Macbook.
At this point the disc should be ejected from your Macbook. If this is the case, then I will now need to direct you back to Safe Boot mode, but with a little twist, from what you may have tried when you last when to Safe Mode:
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while.
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
Post back to me, if these particular Safeboot procedure does not help. Thanks!
Regards,
-Mactechtrainer
Posted on Feb 02, 2010
  • 3741 Answers
SOURCE: mac book air - spinning
install Istat (google it, get the one that's for the menu) to monitor your cpu temps and fan speeds...when you notice they start maxing out, open up activity monitor and see what is eating up your CPU....you must have something in the background running that is causing the CPU to max out...if that's not the case then you might have a defective logic board. ------- check for start up items. thn check with activity monitor CPU and RAM usage, if its okay then check your hard drive with 3rd party programs to see if its failing. ----- Have you tried resetting some of the low level hardware?
System Management Controller (SMC):
http://support.apple.com/kb/HT1411
PRAM and NVRAM:
http://support.apple.com/kb/HT1379
Other thing to look for might be temperature (install iStat Menu and/or iStat Pro) from iSlayer.com. -----
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Mar 08, 2010
news775
  • 699 Answers
SOURCE: My Apple mac book pro
The grey screen is the bios of your laptop is booting, this is freezing for some reason.
Do 3 things.
Try holding power button down for longer at least 10-20 seconds.
do a PRAM reset, apple symbol, alt P & R keys all held on boot up.
Do a smc reset.
  1. Shut down the computer.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 15, 2011
A1181 hinge broken
Thanks for using Fixya. May I know how old is you Mac laptop?
I can help you with you issue you can contact my using this link > http://www.crossloop.com/RofelLantican
Dec 09, 2013 | Apple (A1181) 133 in Mac Notebook
Macbook will not boot
Could be an fsck (disk check) - how long has it been like that?
Otherwise, boot while holding Cmd+S and post the last few messages that pop up.
Apr 29, 2013 | Computers & Internet
Mac book air to view sonic monitor & I can't find icons or anything just grey screen and mouse...anyone can help?
Go to System Preference on your Mac which is a setting icon (Gear) then go to DISPLAYS > ARRANGEMENT >CHECK ON THE MIRROR DISPLAYS.
You can also set the monitor arrangement sideways or upside down.
Hope this helps.
Mar 06, 2013 | Computers & Internet
Macbook not starting up past the grey screen with spinning wheel. started in command v and have black screen with lots of white writing
Seems like a hard drive problem. You may need data recovery first and then replace the hard disk. Good luck.
We have MacBook for sale for $499. Check it at http://www.computerstar.ca/
Jul 21, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
The Space button is stuck down .. how can this be fixed ?
if its physically stuck, take a flathead screwdriver and pry it up. BE CAREFUL.
Jan 31, 2011 | Apple (A1181) 133 in Mac Notebook
Grey screen at boot up with spinning wheel on macbook
Laptop is looking for a bootup device. Insert your mac operating sustem disc and boot from the disc, then select disc utility from the top header listing and select verify disc, let the system check run and reboot.
Nov 19, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have a Mac A1181 13.3 screen and my Mac screen light won't turn on what can I do should I replace the screen or is it something else? thanks
If your computer works fine with external display, then all you need to replace is "inverter board".
Sep 29, 2009 | Computers & Internet
Stuck on initial screen on power up
sounds like your hard drive died, you should take it into a repair shop unless you know someone that can replace the drive and re-install OS X for you. you computer uses a 2.5" laptop hard drive.
Jan 29, 2009 | Apple Mac mini G4 Desktop
Apple MacBook Housing, Top Case with Keyboard Version 2  Mac Notebook Logo
173 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
