Question about Apple ATI RADEON 9600 XT for Macintosh G5 (p/n 1002843) Graphic Card
Cannot boot Leopard or Tiger
But when I run the Hardware Test on my Tiger Distribution CD I get an error code during the Video Ram test: 2ATI/1/4: 113-A58504-113
The Graphics card is: ATI Radeon 9600, 128 MB
I cannot boot Leopard or Tiger. Boot process stops after screen with Apple and goes no further.
    Problem Solver:
Can you pleasr post more information on when how this was started I had this problem once with bootcamp but now it was resolved. Can you still get in somewhere?
Posted on Jan 04, 2009
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
http://www.computerhope.com/beep.htm
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
My desktop frequantaly booting what can i do
When you say frequently rebooting; Is it randomly rebooting without warning? Do you get a BSOD (Blue Screen of Death) error message? Or does the PC just reboot without any error's other than windows was not shutdown properly?
MOST random reboot issues are caused by Power issues;
-Failing Power Supply
-Blown Capacitors on the motherboard
-Insufficient power to run the system.
These would be a good place to start to troubleshoot if you do not get a Blue Screen Error Message.
-Failing Hard Drive can cause this issue as well but is usually acompanied by a Blue Screen Error of sorts.
-Failing RAM again usually accompanied by a Blue Screen Error.
You can test for failing hardware, by using Hiren's Boot Disk for diagnostic tests on your Hard Drive or Ram.
Hiren's Boot CD 15.2 - http://www.hirensbootcd.org/files/Hirens.BootCD.15.2.zip
You will want to run memtest X86 to test the Ram or Hitachi's Drive Fitness Test or SeaTools to test your hard drive.
This BootCD is not for the typical end user whom may not know there way around the features and options this Tech CD provides.
You will want to burn the Hirens Boot.ISO file to a CD (Burn Image Option) using any of your favorite flavors of burn software.
Hope this helps.
You can also download these diagnostic test individually such as memtest x86 and Hitachi's DFT or SeaTools independently from the Boot CD just by doing a google search. This might be the easier way to perform these tests for people who aren't very savvy with boot CD's.
Dec 09, 2013 | Intel D845GVSR Motherboard
Just bought a 2006 MacBook Pro 2.16GHz, 2GB Ram, 120 GB HD It came with an openly disclosed problem: a consistent "USB Over Current" error message popping onto screen. (yes, I've read relevant...
Hello and thank you for visiting Fixya Support, I will be glad to assist you.
The "USB Over Current" error is a hardware issue. From my experiences with this error,
this issue does not occur due to a software, but the actua USB port on the main logic board of the
Macbook Pro.
This USB Over Current error impacts the USB in different ways. For example, if there has been any liquid spill on the Macbook Pro or there has been anytime of surge, blackout or brownout during the operation of this Macbook Pro, such incidents can cause a short circuit within the main logicboard that the USB ports are connected to.
The best step you can take to resolving this is to take the Macbook Pro in for service at your local Apple Store or Apple-authorized service center and have a full assessment completed to let you know what can be done.
Most times the remedy, is to outright replace the Macbook Pro's main logicboard, but that is such an expensive option, I do not want to even touch on that as a possibility right now.
As a professional Apple technician, I can only provide you viable options in a case like this and so my recommendation is to take your Macbook Pro in and have it diagnosed.
This issue will not go away without hardware repair.
Just for your reference, I have taken the liberty to provide the store locator links to your local Apple Retail store as well as a general store locator for locating any local Apple Authorized Service center in your area.
Apple Retail Store (Genius bar)
Apple Authorized Service Provider
If you have any further questions, please don't hesitate to reply back to this post.
Sincerest Regardsm=,
-Mactechtrainer
Mar 07, 2011 | Apple MacBook Pro Notebook
After i instul windows7 ultimate on partition cthe sond is stoped
Restart the computer and tap the f12 key as soon as it starts to boot up .
2. Select 'Diagnostic' from the boot menu. The computer will run its pre-boot assessment tests (PSA) before Dell Diagnostics starts. During the PSA you will hear some tones through the system speaker (but not through the headphone jack) but this does not adequately test the audio hardware. Dell Diagnostics plays an instrumental piece of music complete with drums, so if you only hear some tones then you have only run the PSA.
3. Dell Diagnostics should open after the PSA tests, or you should see an option to open it. If you have ever reformatted your entire hard drive then Dell Diagnostics will no longer be there as an option. In that case run it from the Drivers and Utilities (Resource) CD if you have one.
4. Select 'Custom', then the audio tests. (At this point - after you have opened Dell Diagnostic custom - if you can't find the option to select the audio tests that is a symptom of a failed audio chip.)
5. The tests will run. Alternate between using headphones and listening to speakers in case only one signal path is working.
The tests will play some audio and ask you whether you heard it.
6. If you don't hear the music during the test it definitely means there is a hardware failure somewhere in the system. In this case Dell will repair the computer if it is still under warranty.
7.If you do hear the audio during the test but not when you boot back into Windows, that almost always means the hardware is okay but there is a problem with the audio driver or with Windows.
8. Error codes: If you answer 'no' to any question that the test asks you, the test generates an error code that can tell a Dell technician that you answered 'no' to that question. The test does not know the exact component that has gone bad. Before answering 'no' to a question, make note of the circumstances at that point so you will know in general what the error code means.
Jun 03, 2010 | Dell Computers & Internet
Video ram error 2ATI/1/4:113-A14404-118 in Apple hardware test Power Mac G5 DP 2,5 ATI Radeon 9800 XT
This one is pretty clear. Your machine is a June, 2004 model. Your video RAM is bad. Video RAM is not user-replaceable on the Radeon 9800 XT, so you will have to replace the Radeon card itself.
Oct 16, 2009 | Apple Power Mac G5 Desktop
Error code 1b63:161b and 1b63:061b
Request to try the steps below;
1. Restart the computer and tap the f12 key as soon as it starts to boot up .
2. Select 'Diagnostic' from the boot menu. The computer will run its pre-boot assessment tests (PSA) before Dell Diagnostics starts. During the PSA you will hear some tones through the system speaker but this does not adequately test the audio hardware. Dell Diagnostics plays an instrumental piece of music complete with drums, so if you only hear some tones then you have only run the PSA.
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Sep 09, 2009 | Dell (8H390) Sound Card
Macbook Leopard 10.5.6 cannot open any applications on hard drive or CD drive. Pulldown menus not functioning. all f keys function normally. Ran disk utility and checkout ok for hardware test, disk and...
could be a hardware problem to be honest. heres what you should try: load a system disk and hit C during boot up and see if you have the same symptoms in disk boot mode. if you do, than it is most likely a hardware issue. if you dont, it could be software related. if that doesnt work: hit V when you boot up and it will go into verbose mode. this will show you all of the background processes that are working during startup. while watching the screen, check to see if you have any stalls during load and note them. also, disconnect all peripheral devices and try removing ram (1 stick at a time) to see if that is a problem as well.
Jun 07, 2009 | Apple MacBook Mac Notebook
Graphics card failure
the error: (Under this test, results show Error code 5300: 0119, which different comments for different parameters) Msg: Detected a failure while writing and reading video memory. (e.g.) Video mode: Dh (320 x 200 16) Address A002Ch, expected to read Oh, but read 1Dh instead *
indicates the video card has failed and need to be replaced.
Apr 14, 2009 | Dell Inspiron 8500 Notebook
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
17" MBP Slow
Depending on the amount of RAM that you have, you may need to add RAM. If you have less than 2GB, you should upgrade the RAM. The other issue could be memory in general since you're running both systems and obviously have a smaller drive than would be available if you were only running one. I would remove the partitions and use one boot drive to see if that makes any difference. Just back your files up first.
Feb 28, 2008 | Apple MacBook Pro Laptop Computer with...
Apple ATI RADEON 9600 XT for Macintosh G5 (p/n 1002843) Graphic Card Logo
249 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
