Question about Sewing Machines
I need a cutting blade for a florabest cordless branch cutter PRC 9.6 KH 3127
New cutting blade wanted
3 Suggested Answers
  • 55 Answers
SOURCE: Cutters on Elna 744 serger won't cut
is there lint or thread caught between blades preventing them from meeting?
scott
Posted on Jul 27, 2009
SOURCE: When I cut 2 layers of towel fabric together .it
it would be better to buy new ones,,try sewingpartsonline.com or sewforless.com
Posted on Nov 22, 2010
Rabbit HX 720 Vinyl cutter plotter cutting blade will not lower to cut
Since this is a sewing machine category, it is unlikely there will be a good answer.
Aug 31, 2017 | Sewing Machines
How do I change the blade in a White Speedylock 1634
Not sure about that model, but likely it needs a Phillips screwdriver. The cover opens up and if you can find the cutter then you may be able to loosen the screw holding it.
Make sure you carefully observe and memorize the exact position of the knife so the new one can be placed in the proper position.
Moses
Sep 01, 2014 | Singer White Speedylock 1634
My thread cutter(automatic trimmer) is making a bad noise before it cuts the thread. Is there a place to look to see what is going on or to change the blades if needed??????
New noise? My F-600 has always made a sort of growly/gear noise just before cutting the thread. If it's a new noise, don't use the thread cutter until you've taken it in for service.
Mar 12, 2014 | Juki Sewing Machines
I replaced cutter blade on Elna PRO DC 5. New blade won't cut fabric. how do I adjust it?
All sergers have 2 blades. Just like scissors. Only 1 blade of scissor is sharp = not good cutting.
Feb 14, 2014 | Elna 1010
Changed cutting blade now blade will not stay stable in position to cut
did you get the cutter release knob back in the right place or position?
is the horseshaped bracket damaged in any way?
Mar 07, 2012 | White Sewing Superlock 1934D Mechanical...
Pfaff embroidery cutting blade
do you want a cutting blade?? have found a site that has spare parts for Pfaff machines - hope this will help
Parts For Embroidery Machines ... Edge Cutter Attachments ... We carry new and used machines from Singer, Pfaff, Durkopp Adler and many more. ... We stock a wide range of rotary, drag and tangential blades, sign blade holders and blades, ... www.sloanmachinery.com/
Feb 28, 2012 | PfaFF Sewing Machines
The selective thread cutter not cutting thread.
You need a new blade in the cutter. It is a simple repair job, but needs to go to the repairman for it to be done.
Feb 28, 2010 | Husqvarna Designer I
scott
Jul 26, 2009 | Brother 929D Mechanical Sewing Machine
Husqvarna Sapphire - thread cutter not working
Does the metal arm come out to grab the threads to cut it? Is there a blade in the metal arm that cuts the tread? I think a standard utility knife cutter blade is the same size (just like the one that cuts the bobbin thread when you put in a new bobbin). What happens when you activate the cutter is the arm comes out, grabs the threads, brings them to the blade which cuts the threads, the velcro by the cutter holds the bobbin thread in place for the next stitch. Otherwise the thread may end up on top and the top thread would not be able to pick it up for the next stitch.
Good luck.
Jun 27, 2009 | Husqvarna Viking 1
My simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
Mar 18, 2009 | Simplicity Serge Pro SW432 Mechanical...
Sewing Machines Logo
43 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
