Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
The freezer door on my ge side-by-side refrigerator won't open
The freezer door won't open. Should it be locked? This fridge is in a new home to us, and we don't know much about the appliances. Any ideas on what to do and how to get it open?
  • 38 Answers
It sounds like door may be frozen shut. Unplug and let thaw out until you can open it. There are no locks on the doors.
Posted on Mar 12, 2009
GE Monogram series side by side model zisw42em I had a "de" defrost system alarm and both sides (refrigerator and freezer) were warmer than usual. I manually rotated the defrost timer which...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The opening should be at the top probably behind the plastic removable cover.
Aug 07, 2011 | GE Monogram ZISx420DR 42-inch Side by Side...
My brand new Beko frost free fridge freezer makes a loud gurgling noise and sounds like water trickling inside every time the fridge door is opened then closed again, regardless of how long its open for....
mINE IS DOING EXACTLY THE SAME - I'VE HAD IT ABOUT 2 WEEKS BUT ONLY STARTED MAKING THIS SOUND TODAY AND AS YOU SAY ONLY WHEN THE FRIDGE DOOR IS OPENED AND THEN SHUT!
Oct 08, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
GE refrigerator freezer water dispenser failure GSH25JFTA
Some have said that if you are fridge is still making ice, then your water line may be frozen. So you need to let it thaw out by leaving the freezer door open. Figure out somewhat to try and keep the cold air in by using plastic sheeting or something, until the line thaws. You can't dispense water with the door open, so reach up press the button that makes it think its closed and try to dispense the water..or just shut the door to test it out. I am going to try this when I get home today, because I am having the same problem on my GE model# GSH25JFTA BB.
Mar 02, 2010 | GE GSH25JFT
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Water dispenser keeps running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE fridge doors open and close
Raise the legs up on front till the machine tilts slightly towards the wall. The weight of the doors will then be shifted towards the machine instead of away from it. Only a slight adjustment is needed and should have been done by the delivery guys. A $5 tip would have gotten that done, you must be a cheapskate.
Source: I used to deliver them before I learned how to fix them. LOL
Mar 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Ice maker works but water won't dispense
There is a know defect with the freezer side door. read more at http://www.houstongofarappliancerepair.com/Refrigerator.html
Also, If you call and haggle GE they may send you a new freeezer side door. Or, You may actually try turning fridge off, leaving door open for about 4 hours and then try it again. As strange as this sounds it has worked for some of my customers.... When "air-bubbles" get into that line it can freezer inside the door a small section of water line because the insulation in freezer side door isn;t thick enough... More can be read on this problem at http://www.houstongofarappliancerepair.com/Refrigerator.html
goodluck...
Dec 01, 2008 | GE Profile PSW26P Stainless Steel Side by...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side door not locking shut
Mine has been doing this for over a month. Then on Friday it started making a clicking sound a CONSTANT clicking sound. I get home from a marriage retreat for families getting ready to be deployed and gee ALL my food in the fridge is BAD!!!!
My model number is ssh25kfrfww Please give yours. Also my door NEVER locked from day one. As my children are older I didnt think it was a big issue till today.
Apr 14, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
70 people viewed this question
Top Refrigerators Experts
KJ4QOB
Alan Moore
Level 1 Expert
Gerardo Ahuactzin
Gerardo Ahuactzin
Level 1 Expert
