Question about Mophie PowerStand for iPad 3 / iPad 2 - Aluminium
Mophie Powerstand The stand will not charge or sync my iPad 3 to my computer while connected to USB 3.0 or wall adapter. Anyone know how to fix this or had this issue before?
Won't reload on my ipad
Connect to wall outlet Uses the USB power adapter and USB cable included with the device. If it is a third-party accessory, check to see if it is Apple Certified . Then follow these steps:
  1. Connect the iPhone, iPad or iPod touch to the Lightning to USB connector cable or the 30-pin to USB connector cable .
  2. Connect it to one of three power sources:
Wall outlet
Connect the charging cable to a USB AC adapter and connect the USB AC adapter to the wall outlet.
Computer
Connect the charging cable to a USB 2.0 or 3.0 port on a computer that is not in sleep mode. Do not use the USB ports on the keyboard.
Power supply
Connect the cable to a powered USB hub, docking station, or other Apple-certified accessory.
When the device is charging, you will see a lightning bolt next to the battery icon in the status bar or a large battery icon on the lock screen.
Aug 12, 2017 | Tablets & eReaders
How do you connect ipad to computer
To help you connect your ipad to the computer, please follow the step-by-step instructions given below:
- Turn both the computer and iPad ON before connecting.
- Plug the iPad's docking port into the appropriate end of the dock connector-to-USB cable.
- Plug the USB end of the iPad's dock connector-to-USB cable into an open USB port on your desktop. If iTunes doesn't open automatically, open the program to sync files and apps between the devices.
- Do not disconnect while the iPad is syncing or the sync won't complete.
- Remove either end of the cable to disconnect your iPad from the PC.
- After the first connection, you may choose to connect the two via Wi-Fi so you don't need to use the cable.
- Using iTunes, you can sync your audio, video, photos, apps and documents. This lets you transfer important files and apps you use for your business between your iPad and computer.
GuruAid.com
May 15, 2016 | Tablets & eReaders
The iPad doesn't charge with USB connection to the computer?
usb at computer have too weak current to charge ipad, you need wall charger.
Mar 26, 2015 | Tablets & eReaders
My apple ipad is not reponding when iam charging it how do i reset it
If you charge your iPad on a power adapter, the iPad should respond while charging, except if your iPad battery is so low the apps need more power to run.
If you charge your iPad on the USB port of your computer, it is normal you cannot use your apps as the iPad is not only in battery charging mode but also in synchronizing mode with iTunes in the computer. You should lose the habit to charge the iPad on the PC and use a dedicated power adapter instead, as dedicated power adapters charge the iPad battery 2 to 4 times faster than the USB port of most computers.
USB port power: 2.5 Watts in general (5 volt x 0.5 A = 2.5 Watts)
iPhone charger: 5 watts
iPad charger: 10 or 12 watts
Jul 26, 2014 | Apple iPad 32 GB WiFi Tablet PC
My i pad will not turn on
First steps: Make sure you're up to date
  1. Verify you have installed the latest version of iTunes.
  2. Verify that you are connecting iPad to your computer using a USB 2.0 port.
  3. Make sure your iPad software is up to date: With your iPad connected to your computer, click "Check for Update" in the Summary section of iTunes.
  4. Charge your battery: Using the USB power adapter that came with iPad, charge iPad for at least 20 minutes before further troubleshooting. If necessary, refer to "Charging the Battery"
Jul 07, 2014 | Apple iPad Tablets & eReaders
Why wont my ipad charge
To charge an iPad you have to connect the USB cable to iPad power adapter (12W in power and is bigger in size compared to iPhone's). If you connect it to iPhone power adapter you might see that the iPad is not charging, but will take a very long time to charge. The same goes with connecting directly to computer.
Also, there is always a chance that either your cable, or adapter or the iPad itself has gone bad.
May 28, 2014 | Apple iPad Tablets & eReaders
Ipad 3 will not charge
To get Ipad to show as charging download Asus AiCharger from web and restart computer after install.Plug in usb from Ipad and should now show charging.
Nov 05, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Adding music to iPad
You can add music to the iPad by directly downloading from the iTunes app or by importing your music into iTunes on a computer. Once your music is imported/downloaded into iTunes on a computer, you then just need to sync the music by connecting your iPad to a computer.
Oct 15, 2012 | Apple iPad 32 GB WiFi Tablet PC
How do I charge the iPad battery.
USB hubs typically don't generate the 10 watts necessary to charge an iPad when it's connected to your computer. This basically means you can't use your laptop to recharge your iPad.
Apple recommends finding an AC outlet and using 10-watt power adapter that came with your iPad.
Jan 08, 2012 | Apple iPad2 WiFi 64GB
Mophie PowerStand for iPad 3 / iPad 2 - Aluminium Logo
179 people viewed this question
Top Mophie Tablets & eReaders Experts
Are you a Mophie Tablet and eReader Expert? Answer questions, earn points and help others
