Question about Dell Obsidian Black 15.6" Inspiron N5050 Laptop PC with Intel Core i3-
I cannot unlock the computrace on my laptop - Dell Obsidian Black 15.6" Inspiron N5050 Laptop PC with Intel Core i3-
  • k_b_storer
    k_b_storer Oct 31, 2012
    By "unlock" Computrace, do you mean activate the software on your computer or remove it?
2 Suggested Answers
perkins48
  • 14411 Answers
SOURCE: how do i unblock computrace
Go to your control panel Kevin and click on recovery and set your computer to earlier time listed and it will go away.
Posted on Oct 30, 2012
Cannot view or hear you tube
please i need the licennce key for driver toolkit
Dec 26, 2013 | Absolute Software Computrace® LoJack for...
How do i unblock computrace
Oct 30, 2012 | Dell Inspiron 15 N5050 15.6" Laptop Core...
Deactivate ComputerTrace on my Inspiron 1501
Computrace has nothing to do with adding RAM to the system, it merely enables the theft reporting capability of the system (It basically will call home to computrace if stolen)
Should just be as simple as:
  1. Disconnect power and remove battery, then hold power button 10 seconds to release any stored charge in system.
  2. Install RAM at a 30 degree angle till gold contacts completely disappear into slot, then press RAM down till it latches
  3. Power on and enter setup to recognize new RAM configuration, save and exit
If system will not post with upgrade RAM installed then RAM may not be compatible, or BIOS may need to be flashed to current version before installing upgrade modules.
Feb 21, 2010 | Dell Inspiron 1501 Notebook
Some one hacked my e.mail, i cannot pen my e.mail..and there is msg saying it is locked up
well in this case u need to contact the email provider.They will present you a form by filling which u will be able to access ur account once again.
Jul 14, 2009 | Absolute Software Computrace® LoJack for...
Can turn computer off and on and I will see the windows screen then the screen goes blue with a blinking cursor. I also have a dell.
It is related to bios enabled computrace models. It has happened twice to my dell 1525 I bought it 12/08. The software used to image your recovery partition is incompatible with the two tiny hidden partitions computrace uses. Computrace gets corrupted and shuts you down like you stole the laptop through no fault of your own. All of you data is still there so don't worry. smile.gif
According to dell, you have to remove the hard drive, download your correct bios from their site using another computer of course, and while the hardrive is still removed, flash the new bios and then reinstall the hardrive and it should work fine with all your data intact.
I found this tech update at dell's website this problem goes back to 2005 but the most recent update was dec. 2008 and includes many laptops including the 1500 series.
Computrace freaked out and completely disabled your system. You can send it back or follow the instructions in the update if you are out of warranty.
I am a graphic designer so I needed to finish a project, so I did this to get it running again, backed up my data, and sent my laptop back for a replacement.
I have included part of the update and the Dell web link for you below.
Certain Dell™ Portable Systems Display a Black Screen with a Flashing Cursor when Booting from the Hard Drive
This issue only occurs on Dell portable systems that shipped after Oct. 31, 2005, and have the following configuration:
  • The CompuTrace BIOS feature is supported and has been set to Activate.
  • A system account has been created, and the laptop is registered with Absolute Software.
  • The Altiris Backup and Restore application for local client has been installed.
Affected systems manifest the following symptoms:
  • When the system is powered on, it does not complete the boot process, and the only indication that a problem has occurred is a black screen with a flashing cursor in the upper left corner of the display.
  • The system cannot boot from any media as long as the hard drive is attached. The only way to boot to other media is to remove the hard drive from the system.
Altiris Backup and Recovery software uses an atypical mechanism to hide a partition within the system volume. This mechanism involves hiding valid data relating to the Altiris Backup and Recovery software in marked blocks that the operating system is designed to ignore. The installation process for Altiris also leaves table entries that store directory information for NTFS. These entries are formatted differently than those normally observed on an NTFS-formatted partition. These changes were not anticipated, and we are not aware of any other product that uses the file system in such a manner.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=2A28448CB118EBAFE040A68F5B2854D5&doclang=en&cs=
I hope this helps.
Feb 18, 2009 | Dell Inspiron 1501 Notebook
Lojack
You are unlikely to have Lojack preinstalled on your laptop. In all likelihood, you will have to install Lojack yourself.
Dec 11, 2008 | Absolute Software Computrace® LoJack for...
Dell inspiration 1150 laptop
I hope this helps.
Dec 09, 2007 | Dell INSPIRON 6000 CENTRINO...
Dell Obsidian Black 15.6" Inspiron N5050 Laptop PC with Intel Core i3- Logo
59 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
