Question about PVC Office Equipment & Supplies
Where can I find the pvc foam board suppliers?
I want to use pvc foam for a fiber glass long board. i plan to purchase more pvc foam board. if anybody know some good suppliers,please recommend to me. Thank you in advance
What is ceramic fiber and how does it functions?
Ceramic fiber board was made by desiccation, machining and refined through vacuum forming or dry process. It's an ideal energy saving material for kiln, pipe and other insulation equipment.
The advantages of ceramic fiber board:
1. High compressive strength and long service life.
2. Low heat capacity and conductivity.
3. Non-brittle materials, good tenacity.
4. Precise size, good flatness.
5. Easy to cut and mount, convenient construction.
6. Good performance at anti erosion.
7. Continuous production, uniform fiber distribution and stable performance
Characteristic of ceramic fiber:
Beside the fine properties of bulk ceramic fiber cotton, ceramic fiber board has hard texture, excellent toughness and strength and good performance at weather-proof. It won't expand when heated. Besides, it has light weight so that it can be constructed convenient and arbitrary shear bending.
The application of ceramic fiber board:
1. The backing insulation for kiln of cement and other building materials.
2. The backing insulation for kiln of petrochemical, metallurgy, ceramics, glass industry.
3. The backing insulation for kiln of heat treatment.
4. The backing insulation for non-ferrous metals industries.
5. The backing insulation for high-temperature reaction and heating equipment. http://www.ceramicfibermanufacturer.com/
Mar 07, 2017 | Computers & Internet
How can I get a replacement for cracked door glass?
Check with a local appliance parts supplier and/or the manufacturer/supplier to determine availability and source.
Nov 30, 2015 | Ovens
How do I fix a hole in the front of a fiber glass boat?
Should be patched from inside and outside,if you haven't worked with fibreglass find someone that does
Oct 06, 2014 | Magellan Marine Fiber Glass Premium Boat...
I own a Maytag Glass top electric range stove. Model # PER5710BAC. The glass stove top cracked straight down the middle, and one of the bigger burners doesn't heat up anymore. Is there any way to repair...
You could try purchasing replacement parts from a local appliance parts supplier and you might be able to get advice on making the repair. The supplier can advise you of the cost, allowing you to decide whether it is economically worthwhile to repair the range. You also have to consider your degree of confidence in your ability to do the necessary work
Sep 29, 2013 | Magic Chef 30 in. 8241RT Gas Cooktop
What is the material snowboard made out of?
The eight main materials in a snowboard are: Rubber Foil; Resin System (glue); Resin System (glue); Metal edges; Fiber glass or epoxy; top sheet with printed graphics; plastic base; steel inserts; wood or foam core. For more info: http://www.abc-of-snowboarding.com/snowboards/materials-and-construction.asp
Jan 14, 2013 | Winter Sports
What are the advantages of foam wrapping?
Fiber, or foam with a fiber wrap will give a softer look and feel sofas and chairs. You'll need to plump and turn the cushion occasionally to maintain the comfort and wear.
Aug 20, 2012 | Furniture
Refrigerator runs loudly - stops when I put pressure on doors
older fridges used fiber glass insulation(didn't carry sound)...new fridges use hard foam(much better insulation but carries sound a lot more)when you push handles you dampen the sound... not to worry it's normal just keep all coils clean
Aug 13, 2009 | Kenmore 73503 Stainless Steel Bottom...
Interior walls cracking...
i don;t think there would be a health issue involve.
the old fiber glass has been replaced with polyurethane foam now a days to replace the more dangerous fiber glass insulation.
if you can replace the plastic part that cracked open, that would much better.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Frigidaire FRS3R5EMB Side by Side...
23 people viewed this question
Top PVC Office Equipment & Supplies Experts
k24674
Are you a PVC Office Equipment and Supply Expert? Answer questions, earn points and help others
