Question about HP LaserJet 1015 Printer
Continusly red green lights on and no action - HP LaserJet 1015 Printer
If the print dialog window indicates that there is a printer malfunction, check the printer for any possible paper jams, then check that the printer cartridges are inserted properly. close the dialog window, and press the blinking button on the printer.
if that doesn't work, restart printer: either press on/off button or unplug the printer. wait 15 seconds, then turn on/plug in the printer.
Posted on Oct 30, 2012
Wrench flashes 6 times then 6 more continuosly
one red light flashes continusly and chair won't charge
Jun 29, 2013 | Electric Mobility Invacare Pronto M41...
It is a Sony model ES48SN1 rear projection When turned on the set hisses for few seconds and then stops. The LED flashes Green-Green-Red continusly. The screen does not do anything
Hello, hope you are well. First, you have displayed the wrong number for the model. It starts with KP. Anyway if you hear a hiss, that is usually an indication of a high voltage leak. If your set has 3 tubes probably one of them is broken. Does it have 3 tubes?
Dec 19, 2011 | Televison & Video
How do i pair up mu htc hd2 with htc bh m300 as i bought new one its not been showing in my device
ok you hold the power key 40 second and you see the power light is stable now you find the device from your phone when you able to find the device you are able to pair the device using 0000 pair key.
Oct 08, 2010 | HTC BH M300 Bluetooth Mono Headset (UK...
I need the code for sharp tv please
Configuring codes:
  1. Turn on the component that you want to set up. In the code listing find the 4-digit code numbers for your component brand.
  2. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  3. Release the component key.
  4. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  5. Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
  6. Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed. Note: If none of the codes turn your component off, try the Auto Code Scan function.
Auto Code Scan:
    The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
  2. Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
  5. Press "0" - "9" The green light will blink as codes are sent.
  6. As soon as the remote turns your component off, press the "action" key. (You have 1 second in which to press the "action" key to save the code.) The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
  7. If none of the codes turn your component off, return to step 2 and start over.
Code Readback:
  1. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  2. Release the component key.
  3. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  4. Press the "enter" key.
  5. Count the number of times the green light blinks. There will be four numbers, separated by a two second pause. The red light will tum off after the remote is finished reading numbers back. Make sure you write the code number below for future use!
Multi-Component Power On/Off:
    The Jensen remote has the ability to turn On/Off multiple components at once. When you perform the following steps, you can turn On/Off the TV, VCR, Satellite, Cable Box and Audio Receiver.
  1. Press the "action" key.
  2. Press the "power" key. Note: This feature does not work for DVD and CD.
Volume Priority Punch-Through:
    When you press the volume keys on the remote they will control the volume on your TV. If you have a home theater system and want the volume keys to control your receiver only, you may set your volume priority to the receiver.
  1. Hold the "RCVR" key down until the green indicator light comes on. The green light should come on after about 3 seconds.
  2. Press "RCVR" key.
  3. Press "Vol+" key. To disable the volume priority you have to set and return to the default.
    To change back to TV priority:
  3. Press "Vol-" key. The volume priority will now default to the TV volume.
hope this helps
Robb
Apr 22, 2010 | Jensen SC-570 Remote Control
WD 62725 timer light continusly flashes green TV won't turn on! Push reset button as soon as you release it ,it starts flashing again. Unplug TV 3-4 Hours No help.
The V26 DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the replacement capacitors and the step by step instructions on CD
Dec 07, 2009 | Mitsubishi WD-62725 62" Rear Projection...
How do you set the timer for an intermatic pool timer? There are two sets of green & red markers, but will not stop at correct time.
Put a green marker at the time you want to turn ON. Put a red marker at the time you want to turn OFF. You can up to set two cycles per day. Make sure the markers are arranged green-red-green-red for separate cycles. If there are same color green markers in a row the second one will have no effect since it is signaling the same action as the marker ahead of it.
Nov 24, 2009 | Intermatic Mechanical Timer Switch - Pool...
TURNS ON OK THEN SHUTS DOWN, GREEN LIGHT STAYS ON
Mine does the same thing try a new lamp I am with what I have read this is the best solution. I have had green screen two fans replaced and now this. The picture was great but with all the problems i would never but a sony product ever again for anyone out there you should tell them sony sucks and send them to this web site for clues. Good luck.
Dec 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony trinatron 36". tv comes on with sound and no picture. red light flashing continusly. after awhile aclick is heard and picture comes. moved tv a nd now hve sound but no picture. advice please.
I may know the problem, but without the model number I can not be sure. Can you please post the model number? Also, when the set is on, does the standby light continue to blink?
Thanks,
Dan
Aug 13, 2008 | Televison & Video
Ionic breeze quadra s 1837
I had a problem with my Ionic Breeze Quadra. Green light would only blink for a second then the red light stayed on. I cleaned unit very good but problem came right back. I blew out the breeze with an air compressor. Not much came out, but now I am green and back in action. I used about 75 psi to clean out.
Mar 23, 2008 | Sharper Image Ionic Breeze® Quadra® Air...
BATTERY CHARGER RADIO SHACK DELUXE 10 CELL
I would go to Radio Shack and have them explain the proper charging procedure as well as inquire about the red and green lights as not all chargers go green when fully charged-Normally red indicates a charging action and if a charger has no fully charged light, then a required charge time period is noted in the instructions. Batteries can be ruined by over charging!
Jan 03, 2008 | Energizer Rechargable Battery with Charger
HP LaserJet 1015 Printer Logo
81 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
