Question about Amana NAV5805A Top Load Washer
Amana nav5805aww washing machine won't spin
My Amana NAV5805AWW washing machine doesn't spin -- it agitates instead during the spin cycle. The brake seems to be dragging, as it is difficult to manually spin the drum during the spin cycle. I have installed a new thrust bearing and pulley kit, but that did not help. With the thin 0.032" thrust washer, the pulley barely moves counterclockwise (maybe 1/8") before the shaft rotates -- the cam alignment arrow never gets in between the min and max marks.
  • Steve Frane Oct 31, 2012
    I have also confirmed that the motor spins in both directions -- clockwise for wash mode and counterclockwise for spin mode. Nontheless, it still agitates when spinning in either direction ans seems that the cam is not lifting the shaft to rlease the brake when in spin mode.
    Top Expert:
  • Amana Master
  • 9,472 Answers
You will need to replace the thrust bearing kit. Here is the part to order.
It comes with the instructions and is an easy fix.
Posted on Nov 01, 2012
  • Steve Frane Nov 01, 2012
    Hi, Richard: Thanks for your help. I've already installed a new thrust bearing kit but that didn't fix it. I suspect it's gotta be something else, like possibly the brake or transmission (hopefullly not that!).
  • Richard Roth
    Richard Roth Nov 01, 2012
    You are correct. You will need to replace the brake. It is hanging up on you. Here is a link to the parts. http://click.linksynergy.com/fs-bin/clic...
2 Suggested Answers
  • 274 Answers
SOURCE: Amana washer tub rotates counterclockwise during wash cycle.
The washer has a transmission.why are you openning the top it's a safety.the transmission may need to be replaced,You may be better off getting a new or new used washer,the transmissin is very expensive
Posted on Jul 29, 2010
My Amana washer doesn't aggitate during wash cycle
What is the model number of your unit?
Nov 30, 2012 | Washing Machines
Leaking washing machine
It is so common that the drain leaks in many ways andis the most problematic fault in a washing machine. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that water hasleaked then as the drain hose pump/valve and fittings are located on theunderside of the machine it is important that you look for possible leaks here.In some cases the drain hose would be clogged at the drain end to outlet of thehouse and so there will be back flushing resulting in overflow to the outside.Also the drain pump/valve can be clogged or the drain hose clamps can be looseon the grip which can all cause the leak to occur. Removing and cleaning thedrain pump/valve, tightening of the hose is also very important. Also water canleak if there are gaps on the front door gaskets and must be checked but thiswill happen only during the cycle and not on the drain cycle end.Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html Check for tips on the link below to identify parts andremoval:http://www.espares.co.uk/advice/washing-machines/a/7
Jul 04, 2012 | Amana Washing Machines
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
My nav5805aww is not spinning, what could be the problem?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 28, 2011 | Amana Washing Machines
Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Feb 26, 2010 | Amana NAV3330AW Top Load Washer
Noisey spin
The noise is from the transmission and is usually pretty expensive. You really are better off getting a new washing machine.
Feb 24, 2010 | Amana DLW330RA Top Load Washer
Washing machine will not agitate but it spins.
The brakes are shot,so the tub spins in agitate will also cause it to leak part number R0000014 run about $25.
Look straight up from the bottom pulley you will see the brake assy looks kinda like a clutch plate,look around the outer edge of that you'll see the Pads they have two 3/8 inch bolts in each one,to get the new ones in you'll have to use a screw driver to open the plate.
Sep 23, 2009 | Amana ALW480DA Top Load Washer
Amana Speed Queen (LWS34AW)
Probable gear box fault Regards Engineer
Jul 27, 2007 | Amana LWA40A
Amana NAV5805A Top Load Washer Logo
387 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
