Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Intek 206 5.5ohv cannot start
I just cleaned out carb. because it had a very poor idle! But now it doesnt start
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Briggs & Str... Expert
  • 133 Answers
Check spark and compression if all is good rebuild carb again sometimes even the best of us have to do it twice
Posted on Mar 12, 2013
I have a 18hp b&s inteck that want idle the govenor goes back and forth
I believe the condition your describing is called "hunting" this sometimes happens when engine has a problem with it's air/fuel mix usually due to a carb problem
id start by cleaning out the fuel tank and filters and then moving on to the carb
Jan 22, 2016 | Cars & Trucks
My mower starts fine and then it idles up and down and up and down and dies? I have changed oil, plugs, fuel filter, air filter
First thing to check would be the base governor setting.This should be done by someone with small engine expertise.Can be fatal to engine and do bodily harm if not done right.Other things to check would be air leaks where carb manifold attaches to heads.Remove air cleaner assembly to gain access to carb linkage and manifold.You will need a can of carb cleaner to perform this check.Start engine and hold throttle at just above idle speed and carefully spray area where manifold attaches to head,do this on both ends of manfold and at carb base,area where carb mounts to manifold,if leak is present the engine will either die or their will be a change in rpm,s.If no leaks are found in these areas have carb cleaned,it is very likely there is dirt in the carb.You can do the same as above,start engine and hold throttle just above idle and spray carb cleaner into carb,engine will try to stall when doing this,only spray carb cleaner in carb while engine is running.If this doesn't help have carb cleaned and adjusted.Info from small engine tech with forty plus years experience.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine is surging when in idle
Sounds like the low speed idle circuit is clogged or the inlet needle tip is clogged in the carb. About the only way to clean these is disassembly.
May 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
18.5 hp intek started this summer when it has
more so a head gasket blown internally causing positive crankcase pressure, & forcing oil out the breather into the carb.
Aug 18, 2009 | Poulan Garden
Intek engine runs poorly under load and when warm
if you have a ohv ajust valves and you might have to rebuild carb.
Jul 18, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Won't run on idle and surging when revived up
Most newer carbs can be VERY difficult to get completely clean. It sounds dumb, but if you will take it apart and boil it on the stove with a couple of doses of cascade or electrasol automatic dishwasher detergent. (powder is best) for 10-15 minutes, it'll be spotless.
Jun 04, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Honda IZY engine hunts. I mean the speed pulses rhythmically!
Just adjust the idle speed control/Fuel air screw located pointing downward on the bowl of the carb,Just start the engine,idle up high and turn the screw until it levels out and runs smooth.
May 31, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
407 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
