Question about Sony Ericsson K850i Mobile Phone
My k850i goes blank on boot
When turning phone on, the screen goes white n nothing appears, but i can receive call..how to fix this?
    Problem Solver:
  • 8 Answers
Dear amirul abdullah,
This problem most common due to when water goes into cell phone. Your k850i phone LCD screen have problem, you should go into Sony Ericsson service center to replace it.
Posted on Oct 30, 2012
NickBeamAA
  • 53 Answers
SOURCE: Screen went blank
There is something you can try. Using a Torx 6 driver, remove the two screws located beneath the battery. Gently pry the plastic cover loose. There will be a flex cable connecting it to the other portion of the phone. Gently disconnect it. Using 99.5% isopropyl alcohol and a soft bristled brush clean the connectors on both the cable and the circuit board. Reseat the connector and reassemble the phone. If this does not work the flex cable or LCD may need to be replaced.
Posted on Sep 09, 2007
Raysagem
  • 1017 Answers
SOURCE: Blank Screen
Try resetting your phone thus:
First turn it OFF, take the SIM card out.
Press
* 3 send at the same time and turn phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
If it works, you should update your phone software. Using Nolia PC Suite.
Posted on Feb 26, 2008
Daelmyth
  • 87 Answers
SOURCE: Blank or White screen on new Motorola Krzr k1 cell phone
If the phone still works, check to see if the left side of the hinge (when the phone is open and facing you) is loose. If you can wiggle the top 1/2 of the phone, the hinge is damaged, therefore damaging the flex cable that runs through it. If that is the case, replace the hinge assembly and the flex and you're good.
The K1 is no joke to take apart. Flex replacement requires full disassembly. I would recommend checking out www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited to have it done professionally, less than Motorola will charge you.
Or give it a shot if you want, you need a T5 Torx and lots of patience and care.
Posted on Jul 31, 2008
SOURCE: screen is now white with the text --download started--, emergency @ usb.
Holding down the camera button, (samsung a870), while inserting the battery got this one working again.
Posted on Sep 22, 2008
AldRezaine
  • 995 Answers
SOURCE: nokia 5130: blank screen, phone doesn't turn on
That means your phone got a corrupted software installed to its memory. A hard phone reset can solve this problem. Typically a nokia symbian series phone can be formatted using this code *#7370# then the default key is 12345.
Hope this could help.
Posted on Mar 26, 2010
Testimonial: "yes, it did get corrupted by a software and I had to give it to some workers at nokia to fix it, I lost the info on the phone (except memory card)"
My phone is switching on with blank scream
When the phone turns on with the blank screen, can you receive or make calls?
If you can receive and make calls, the fault should be from the screen. Maybe it is not well connected to the board or the screen is bad.
But if you cannot receive or make calls, then I think your phone has a virus. The virus might have corrupted the phone software files, thereby, not allow the phone boot. In this case, you need to flash the phone.
Best wishes.
Dec 30, 2009 | Sony Ericsson K850i Mobile Phone
The screen is blank white and the back light keeps flashing
Sounds like your charger isn't working. Meter it. Also possible, it may nt be working IN the phone.
Aug 08, 2009 | Palm Treo 680 Smartphone
Blank white screen in my Acer Travelmate 5730 Laptop
Hello Karthik,
This must surely be a problem with your monitor, because you say that you see the white screen while boot up. If this is a graphic driver issue, you may have the problem after booting up in windows. Since its been only a month old laptop, the product must be in warranty for sure. Take away any CDs in the drive, any USB drives and see if this white screen appears. Let us know.
Thank you!
Sabharish
Jun 26, 2009 | Acer LXA3706003 Notebook
Nokia N95 8Gb fell,screen is white.
The screen cable may have become loose or dislodged. You can find out how to replace the screen and also to check the cable here - http://spyda.vox.comlibraryphoto6a00d09e7ac027be2b00d41442e37f685e.html.
You can pick screens up on ebay too.
Apr 05, 2009 | Nokia N95 Cellular Phone
Sony ericsson k850i screen is blank
my problem is wen im chargen it the screen is blank but the key pad lights up an the power button is red plz help me fix it
Jan 06, 2009 | Sony Ericsson K850i Mobile Phone
Blank display
when i turned on my K750i display is recently white blank for few sec and then become black for few sec again and only so. Nothing else appear on display what i should do? Help me please!!
Aug 28, 2008 | Sony Ericsson K750i Cellular Phone
Motorola RAZR V3x Whiye screen problem
I have managed to fix the problem by doing a software update.
I stumbled across the solution..........I had the phone connected to the computer when I started it in the 'boot loader' screen as opposed to just turning it on. This time the computer recognised the phone was connected and through the motorola software update program I was able to update the software and the phone now works fine.
BTW I did lose all my address book, messages etc.
To start in the boot loader screen hold down the * + # + pwr keys all at once.
Jul 29, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Sony ericsson k850i blank screen
Ihad the same problem... It was cured by a Software Upgrade... Go to any/most mobile phone stores and ask fo help, the wil sort you out with the sony software upgrade. Hope this helps.
Cheers
Atz
Dec 22, 2007 | Palm AT&T C/PHONE PALM CENTRO S64801
Blank screen
I had the same problem, so I hit the side of the Garmin a few times. It works perfectly now. Something inside was unaligned and needed a little force to knock it into place. I didn't hit it HARD.
Sep 09, 2007 | Garmin nuvi 350 GPS Receiver
Sony Ericsson K850i  Mobile Phone Logo
71 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
