I have philips 26ta2800 in standby mode the blue light does not appear.
3 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: i have a philips 26ta2800 lcd, i need a this model
Call Encompass Parts Distribution 1-800-638-3328
Shopjimmy.com
UED 1-800-648-6657
PTS 1-800-844-7871
Posted on Dec 19, 2010
caroldon
  • 17129 Answers
SOURCE: PHILIPS LCD TV 26TA2800/98 VIDEO
Yes you will need to replace the faulty IC /component in this board or replace the board. Since you have got only the possibility of the board being a suspect it will be good to check if you are familiar with electronics with a signal check to determine the fault.
If not the cost of the board must be estimated before you decide to source /service at Philips.
Posted on Jan 21, 2011
Dell Inspiron 531, bottom led light below power button is flickering what appears to be a blue battery symbol. What does this indicate?
the power light is blinking blue, the computer is in standby mode. Press
a key on the keyboard, move the mouse, or press the power button to
resume normal operation
Jul 24, 2017 | Dell Computers & Internet
My tv tcl 21k77 stuck in standby mode if i press
Sounds like a power pack issue. Might be the switch mode transistor not working correctly. Either try repairing it or take it to a local tv repair centre
Oct 14, 2014 | Televison & Video
Strange codes appears on my TV screen
Contact the authorized service center for Philips. Do not make any further experiments with it, please. Gopakumar Gopalan Google
Mar 14, 2014 | Televison & Video
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Philips HTS6100 -seems to be stuck in Standby Mode....won't actually do anything! Any ideas?
Your unit maybe on protect condition that why on standby mode,,,it means theirs a truoble in circuit inside that why happened...try to consult in the nearest service cnter or a wll trained technician,,wish you luck
Feb 19, 2012 | Sony Audio Players & Recorders
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
PHILIPS LCD TV 26TA2800/98 VIDEO NOT COMING. AS PER PHILIPS SERVICE CENTER SCALER BOARD NOT WORKING
Jan 21, 2011 | Televison & Video
I have a philips 26ta2800 lcd, i need a this model scalar board pannel.
Shopjimmy.com
UED 1-800-648-6657
PTS 1-800-844-7871
Dec 19, 2010 | Philips 32PFL3514D 32 in LCD TV
The screen will not turn on, i have a blue flashing light, but it seems to be on continuos standby
remove the connection of your monitor from the cpu then wait if some message will appear on the screen it goes like:1. power saving mode check cable, 2. no signal. if this appear better check the cpu.
Sep 09, 2009 | Computers & Internet
26PF8946/37 Red light
Hey habo,
The red light you are referring to most likely is the power indicator light. On many newer TV's this light will appear red when the TV is off or in "standby" mode, and green when the TV is in operation.
Please keep in mind that some TV models may use the power indicator light to notify owners of ay potential hardware problems as well, so you may wish to refer to your owner's manual documentation if you have been encountering any problems during TV operation.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 22, 2008 | Philips 26PF8946 26 in. HD-Ready LCD...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
