Question about Chrysler Vehicle Parts & Accessories
How to access the in-tank fuel pump from above
There is not a removable panel under the back seat, but if the location is defined, an access panel can be cut. I was able to find location and dimensions on-line, and successfully cut a panel on a Z28 Camaro to remove a failed pump from above. This was much simpler and safer than dropping or trying to safely empty a tank full of gas. Is information (location and dimensions) available anywhere for cutting a fuel pump access panel on a 1997 Dodge Stratus?
    Top Expert:
  • Chrysler Master
  • 15,387 Answers
Cutting from above hasn't been recommended since on most vehicles their are supports that cause instability [locations under seats not trunk ] but the biggest problem is the cutting of the fuel lines / fuel tank and causing fire or explosion and as of now seems like no one has uploaded any dimensions for setting up an access panel on a stratus you can try asking an auto body shop if they have a repair diagram of area requested
Posted on Jun 16, 2017
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Chrysler Master
  • 1,173 Answers
Can i cut an access panel under rear seat to change the fuel pump
Cutting Fuel Pump Access Panel and Removing ... - YouTube
? 13:28
https://www.youtube.com/watch?v=COOLesyiVNc
Sep 16, 2013 - Uploaded by JEG's Garage
This is some shots of me making my access panel for my fuel pump in my 86 Trans AM. The fuel tank is a 2002 plastic fuel tank. You'll notice ...
Oldsmobile Alero access fuel pump trunk Questions ... - Fixya
www.fixya.com > ... > Cars & Trucks > Oldsmobile
Oldsmobile Alero cars & trucks access fuel pump trunk questions and ... Some cars have an access panel in the trunk under the carpeting, near the back seat on the ... is there an access to the fuel pump beside dropping the tank not unless you cut a ... ...no access hole you have to take the fuel tank out to replace the pump.
Dec 30, 2015 | 2002 Oldsmobile Alero
Location of Fuel pump io
Inside the fuel tank. Most imports will have an access panel. Look at where the fuel tank is from uder the car, the right above it should be the panel. Maybe either under the trunk carpet or under the back seat.
Oct 06, 2011 | 2002 Mitsubishi Galant
Must you drop the gas tank or is there an axcess panel to replace the in tank fuel pump?
no, there is an access panel under the rear seat-remove the bench and the top part of the seat in the rear and pull back the carpet-there is a inspection plate that is screwed into place above the fuel pump.
Mar 14, 2011 | 2000 Oldsmobile Intrigue
Fuel pump removal on 2000 saturn sl2
The fuel pump is located inside the fuel tank. Unless there is an access panel in the trunk or under the back seat, you will have to remove the fuel tank to access the pump.
Good luck.
Dec 03, 2010 | 2000 Saturn SL
Where is the fuel pump and the fuel cut off switch? couldnt find at kicker panel !
well the fuel pump is located on the fuel tank,, you have to remove the back seat to get to it,, under the back seat is a panel,, unbolt it then unbolt the pump from the tank..
the fuse is under the hood in the fuse box,, its a black box with a clip on top.. under the cover is a diagram to show which fuse is which
Jun 24, 2010 | 1987 Ford F 250
I NEED TO CHANGE A FUEL PUMP ON A 2000 COUGAR 6 CYL. CAN I DO THIS MY SELF--???
If there is a access panel to the tank then yes, If not then the tank has to be dropted.If there is an access panel then it is under the back seat or under the carpet somewhere in the back of the car. Look under the car to see where the fuel tank is ,then look in the car above the tank. When removing the pump be carefull not to bend the fuel gauge float falve.Good luck
Apr 11, 2010 | 2000 Mercury Cougar
Where is the fuel pump for a 1989 honda accord located?
The fuel pump is mounted in the gas tank. If my memory serves me correctly, there should be an access panel under the rear seat bottom. If not accessable that way, you'll need to remove the gas tank.
Mar 09, 2010 | 1989 Honda Accord 4 Door
Where is the fuel filter located on a 2004 hyundai accent
The fuel filter on a 2005 Hyundai Accent depending on where it was manufactured and when, is possibly external and on the outside of the fuel tank directly above the fuel pump and accessible by removing the back seat. Or it is actually inside the fuel tank and requires removing the back seat, the metal panel, the fuel pump itself and then accessing the filter. Your vin. no. can determine which model you have and of course how much work you'll have to do
Jun 28, 2009 | 2000 Hyundai Accent
Fuel filter location
The fuel filter location for a 2005 Hyundai Accent depends on where it was manufactured and when. It is possibly mounted external, on the outside of the fuel tank directly above the fuel pump and accessible by removing the back seat. The other possibility is that it is mounted inside the fuel tank and requires removing the back seat, the metal panel, the fuel pump itself and then accessing the filter.
Help this helps and good luck.
Jan 12, 2009 | Hyundai Motor 1999 Elantra
Vehicle Parts & Accessories Logo
96 people viewed this question
Top Chrysler Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Tim Garcia
Tim Garcia
Are you a Chrysler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
