Question about Ryobi Saws
Electrical wiring diagraphm 254mm table saw
Reconnecting to on off switch ???
SOURCE: makita table saw switch wiring
After much trial and error, a little smoke, and wrecking one replacement switch, I solved a similar problem with my Craftsman Cmpd Mitre saw. Different saw, but likely the same principles are involved.
If the switch is a double pole single throw switch, with one side normally open (N0) and the other normally closed (NC), and the saw has a separate wire for the brake, this will probably work.
One side of the switch should have contacts that are normally open (NO) and only connect when the switch is ON. The Hot (Black) wire from the plug connects to the wire on the machine side (red or maybe black) through this NO side. So, connect these two wires via this NO side and the saw will run when the switch is ON but will have no brake; so far so good.
There should be another wire (Not the neutral white) which is the brake wire. This gets connected to one of the connection sites of the Normally Closed (NC) side of the switch. From the other connection site of this NC side run a short "jumper" wire (of the same guage as the other wires) to the Machine Side of the NO side of the switch (same place as that Red or Black? wire above) .
What seems to happen is this:
There's no power to the machine or the brake when the switch is OFF. Turn it ON and power goes from Hot through the NO (now closed) side and the saw runs. The brake doesn't run when the saw runs because the NC switch is now open. Turn the switch OFF and the NC switch is in fact closed and power is transfered to the brake via the jumper wire from the still spinning armature which now acts as a generator (alternator?). Once the brake has done its job and the armature stops spinning there's no power anywhere until you turn the switch ON again.
Or at least that's the theory, and in my case it works; no more smoke.
Posted on Feb 04, 2009
rockitman187
  • 2559 Answers
SOURCE: Hitachi c10fr table saw wiring diagram
Here is a hand drawn diagram
Please rate this a fixya
Posted on Feb 13, 2009
  • 12 Answers
SOURCE: on/off switch table saw
It sounds like you are wiring the switch wrong. Give me the model # and I will look for a wiring diagram for you.
Posted on Feb 25, 2009
  • 58 Answers
SOURCE: i need a wiring diagram for the switch and circuit
go here for owners manual. Or use contact to request wiring diagram:
http://www.hitachipowertools.ca/en/Products?cat=37&pid=183
Posted on Jun 20, 2009
i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
Posted on Oct 20, 2009
Hy56 replace craftsman table saw switch?
My Master Craft table saw switch quit working so i just hooked up an electrical box on the front of my machine and installed a house light switch to it. Has worked several years like this. Saved a lot of money. I rewired by using the wires from the old switch.
Apr 03, 2017 | Craftsman Saws
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
Electrial drawing for a flip over saw model COD2000FLS
Check out the links associated with these images. I suspect it is identical to an ELU
Elu tgs172 Google Search
Sep 24, 2014 | Saws
Performance 254mm .FMTC1500TK
Contact the manufacture or a local True Value hardware
Jan 02, 2014 | Saws
Switch wiring
Did you manage to get in contact with the manufacturer of your saw? They would surely help you with your problem.
May 03, 2013 | Makita MLT100 TABLE SAW FOR 220 VOLTS
Powermatic 66 wiring problem
Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
Mar 28, 2013 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
How do i fit reducing ring 16mm bore onto a30mm bore table saw blade, to use on a draper table saw
the reducer should fit right onto the shaft, if its the right size. Mic it to ensure. Then the blade should fit on no prob. I use a 30mm to 5/8" adapter on my own General 50-185 saw. Quality(sizing) of adapter is an issue.
Aug 02, 2012 | Saws
Makita table saw switch wiring
Mar 01, 2009 | Makita Saws
Saws Logo
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
