Question about Xerox WorkCentre 7120 7125 Waste Toner Container 008R13089
ATC Fail K
Getting error code 092-315
2001 jeep grand cherokee,heat and a/c do not bloww hot or cold air
Bernard,
HVAC failure
the car has 2 classes of HVAC< manual and ATC
the blower must blow on high.??? does it on high?
if not, check fuses, for blower. (if lower speeds only fail say so)
the blower is dead,
then say if dash controls are Manual or ATC<
atc = automatic temp,controls with a dash thermostat et cetra.
the diagnostic path is different.
the ATC has self test too. .with over 30 errors possible.
use comments to respond, not a new post. please.
Dec 06, 2016 | 2001 Jeep Grand Cherokee
Xerox workcenter 7345 erore code 009-383 ?
Your is an "ATC error" indicating that the density test has failed for Black. There are many possibilities, but here are the top 5:
1) Dirty or defective ATC sensor (130K63000) (difficult to reach..recommended to be done by technician)
2) Defective Developer (802k60194) (also difficult) You also need Developer Charge Powder (604K22550)
3) Defective ATC Clutch (121K23270) (also difficult to reach)
4) Drum (013R00624) not turning, or bad drum
5) Drum motor (007K88604) not turning
xerox and tektronix dell canon konica minolta qms samsung lexmark okidata...
Feb 07, 2016 | Xerox Office Equipment & Supplies
WorkCentre 7245. What does error code 009-380 indicate?
That error indicates the yellow atc sensor detects a low toner concentration. Try clean atc sensor and reset value to 0.
Nov 06, 2015 | Xerox Office Equipment & Supplies
I have copier xerox 5021 error is 092-910 what does it mean
That error is an ATC failure. It can be caused by a bad drum or MCU Board. You can first try clear the value of NVM [752-059] (ATC Fail) or NVM [752-060] (ATC Fail Continuous Count) to '0'. Enter Diagnostics, Press and hold the [0] key on the Control Panel for 4 seconds or longer and then press
the [Start] button while keeping your finger on the [0] key.
Password is 6789. And go to NVM Initialize.
Sep 06, 2015 | Xerox Office Equipment & Supplies
Sln for Xerox wc 5330 error code 092-315
092-315 ATC Fail RAP
BSD-ON: BSD 9.3 - Development and Toner Dispense Control
The frequency at which the ATC Average Fail or the ATC Amplitude Fail has been occurring
has exceeded the threshold value.
NOTE: •
Although this Fault can be cleared by turning the power OFF and ON and it will be possible to output a few sheets of printouts, when this Fault has occurred a certain number of
times, it will no longer be clearable by turning the power OFF and ON. To clear it, clear the
value of NVM location [752-022] (ATC Average Fail) or NVM location [752-023] (ATC
Amplitude Fail) to "0" (
NVM Read/Write). If the machine is not repaired back to normal
status, this Fault will occur again during the operation.
• When turning the power OFF, turn OFF the power switch first and then the main power
switch.
Procedure
Check the following:
• The connection between the MCU PWB
P/J413 and the Xero/Developer Cartridge P/
J615
for open circuit, short circuit, and poor contact
• The Toner Dispense Motor for revolution failure:
Component Control [093-002] (PL 8.2)
• The Toner Cartridge for internal toner blockage
If no problems are found, replace the following parts in sequence:
• Drum Cartridge (
PL 8.1)
• MCU PWB (
PL 18.2)
See Service Manual page 827 (2-831):
https://docviewer.yandex.ru/?url=ya-disk-public%3A%2F%2FEXv3f5bJ9f7WprcvyqxuiVsXMlmyrp4nx2LzJa50u6s%3D&name=Xerox_WC_5335F_SD.pdf&page=827&c=55716712dd0d
Xerox WorkCentre 5335 Family 5325 5330 5335 Service Manual
Jun 05, 2015 | Xerox WorkCentre 5325 5330 5335 Black...
Cyan ATC sensor failure. Error code 14. I replaced developer and did ATC sensor setup. Still having issue.
Yellow ATC Sensor Failure,Code12
Magenta ATC Sensor Failure,Code13
Cyan ATC Sensor Failure,Code14
The ATC Sensor detects an insufficient amount of developer.
Note
If this failure reoccurs three times successively, an Engine NVRAM value is set preventing further printer use until the Clear Tech Rep Fault (see pg.6-20) is performed.
Troubleshooting Procedure
Step Actions and Questions Yes No 1 Is the problem toner and/or developer empty. Replace the toner or developer. Go to step 2. 2 Is the ATC sensor clean and free of dust, toner or any other contaminates? Go to step3. Clean the ATC sensor. 3 1.Check the ATC sensor wiring harness Yellow=P/J129
Magenta=P/J130 Cyan=P/J131
2.Is the wiring harness or the sensor defective? Replace the ATC Sensor and/or wiring harness. Go to step 4. 4 1.Remove the Rear Cover and RearShield.
2.Measure the voltage at...Yellow=P405B3 Magenta=P405B8 Cyan=P405A10
on the engine control board.
3.Is the voltage between+1 and
+3VDC? Replace the engine control board. Go to step 5. 5 1.Measure the voltage at...Yellow=P405B14 Magenta=P405B11 Cyan=P405A11
2.Is the voltage+5VDC? Replace the engine control board. Go to step 6. 6
1.Measure the voltage at...Yellow=P405B2 Magenta=P405B9 Cyan=P405A9
2.Is the voltage 0VDC? Replace the engine control board.
Go to step7.
7
1.Remove the Imaging Unit Plate cover.
2.Inspect the wiring harness between the engine control board and the developer housing assembly.
3.Is the wiring harness defective? Replace the wiring harness.
Replace the ATC Sensor.
8
Run approximately 10 pages of the solid fill full-page prints for this color to ensure the error is cleared.
Mar 12, 2015 | Xerox Phaser 7750 Laser Printer
I'm getting the fault code 009-383 ATC Sensor (K)Fail
change the velue of this NVM 752-112 to 0.Record the value in NVM location 752-324, then set the value to 1. Perform ADJ 9.3. After the measurement has completed, restore the value.
Aug 25, 2014 | Cars & Trucks
Xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 776
When you have a sensor failure, you need to replace the black ATC sensor and recalibrate it. Another reason for sensor failure is you are not getting toner moved down to mix with the developer...the toner tube/auger spring could be clogged up or not functioning.
Also if you changed the developer housing when you changed the developer, you need to change the value to the new sensor # that comes with the housing.
Feb 16, 2014 | Xerox Phaser 7760DN Laser Printer
I have a 1999 chrysler 300m. i run the diagnostic on the automatic temp. controll and get code 36. can some one tell me what code 36 is and how to fix it.
Code 36 = ATC Head Command Failure (Chrysler's technical term: EEPROM Checksum Error).
Basically, this code indicates the Auto Temp Control (ATC) has malfunctioned.
If this is a stored code (i.e. not active) and your ATC appears to be working ok, then you can disregard this code. However, if this code is active (i.e your ATC is not communicating with your A/C system), then there is no simple fix you can do yourself.
Although some mechanics would suggest replacing the actual A/C Heater Control, I understand your Chrysler service agent may have a way to re-flash your system to correct this code. I recommend you contact your local service agent and discuss a possible reset of your system.
"If this has helped you in any way, please take a moment to rate this solution"
Nov 05, 2011 | 1999 Chrysler 300M
Xerox WorkCentre 7120 7125 Waste Toner Container 008R13089 Logo
418 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
