Question about Casio FX-115 Solar 236 Function Scientific Calculator
What does the vct d mean ? - Casio FX-115 Solar 236 Function Scientific Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
These two are unrelated. The D indicates that the angular mode is set to degrees. To change this, press SHIFT [SETUP] and select 4 for radians or 5 for grads. One of the D, R, or G indicators will always be lit.
The VCT indicates that you're in the vector mode. To get out, press MODE 1.
Posted on Oct 30, 2012
What does the code P0013 mean
The meaning of p0013
Intake camshaft position 'B' actuators circuit open bank 1
Possible causes
Variable camshaft timing (,VCT) CIRCUIT Open or short
vpwr circuit open
variable camshaft timing (VCT) solenoid open or short
May 23, 2016 | 2004 Chevrolet TrailBlazer
PO13C f 150 code
Your code means - Exhaust can position actuator circuit, open/short in VCT circuit or solenoid or open in VPWR circuit (Bank1) VCT is Variable Camshaft timing system.
Feb 28, 2015 | 2011 Ford F-150
P0010 engin light
A code P0010 may mean that one or more of the following has happened:
  • Faulty oil control valve (OCV)
  • Open or short in the VVT/VCT circuit
  • Open or short in the OCV / solenoid valve
  • Damaged computer (PCM)
Possible Solutions Some recommended troubleshooting and repair steps are:
  • Carefully inspect the Bank 1 VVT/VCT system circuit wiring and connectors, repair as required
  • With a warm engine, test the operation of the OCV, replace/repair as needed
Oct 16, 2012 | 2004 Scion xB
P0012
P0012 - "A" Camshaft Position - Timing Over-******** (Bank 1)
OBD-II DTC Trouble Code Description
What does that mean?
A code P0012 refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module, also called an ECM). That consists of a few different components but the P0012 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is over-********, the engine light will be illluminated and the code will be set. The "A" camshaft is either the intake, left, or front camshaft.
Potential Symptoms
Most likely a P0012 DTC will result in one of the following:
hard starting
poor idle and/or
stalling
There are potentially other symptoms as well. Of course, when trouble codes are set, the MIL (malfunction indicator lamp, a.k.a. the check engine light) illuminates.
Causes
A P0012 DTC trouble code may be caused by one or more of the following:
Incorrect camshaft timing
Wiring problems (harness/wiring) in intake timing control valve control solenoid system
Continuous oil flow to VCT piston chamber
Failed timing valve control solenoid (stuck open)
Possible Solutions
The main thing to check is to verify the operation of the VCT solenoid. You're looking for a sticking or stuck VCt solenoid valve caused by contamination. Refer to vehicle specific repair manual to perform component tests for the VCT unit. Notes: Dealer techs have advanced tools and the ability to follow detailed troubleshooting steps, including the ability to test components using a scan tool.
Nov 26, 2011 | 2004 Ford F150
Check engine light is lit and error code is identified as P1383 unidentified code
Hi.
P1383 is one of Jaguar's own codes. You can find the code even in other engines (e.g. Ford). P1383 means : Variable Cam Timing Overretarded (Bank #1).
Symptoms:Rough idle, engine stalling.
Here possible causes:
  • Cam timing improperly set.
  • Continuous oil flow to the VCT piston chamber.
  • VCT solenoid valve stuck open.
  • Camshaft advance mechanism binding (VCT unit).
  • Solution: the part in the Variable Cam Timing listed above must be tested and repaired.
    Regards.
    Ginko
    Aug 09, 2011 | 2002 Jaguar S-Type
    My 1997 chevy s10 is messing up I hooked up a obd2/eobd code reader and it gave me back this code......P1380 EBCM DTC detected, dada unusable? I have no clue what that code means but if you can help it...
    P1380 - Misfire Detected Rough Road Data Not Available
    The comprehensive component monitor (CCM) monitors the VCT circuit to the PCM for high and low voltage. If the voltage falls below a calibrated limit a calibrated amount of time during testing, the test fails.
    Possible Causes:
  • Open or short in the VCT circuit.
  • Open VPWR circuit.
  • Damaged PCM
  • Open or short in the VCT solenoid valve.
  • Possible Solutions:
    DTC P1380 is a VCT circuit check. Testing should include wires, solenoid coil, and the PCM.
    Jan 17, 2011 | Chevrolet S 10 Cars & Trucks
    I HAVE p0010 code Problem.CAMSHAFT POSITION ACTUATOR CIRCUIT
    P0010 - "A" Camshaft Position Actuator Circuit (Bank 1)
    A P0010 code refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module). That consists of an oil control valve (OCV), also called a solenoid valve and other components. Basically the check engine light and associated P0010 trouble code means that the voltage in the circuit has fallen below a set limit for a specific amount of time (varies by make/model/engine).
    Symptoms may include:
    * Check Engine Light illuminated (Malfunction Indicator Lamp)
    * Rough running
    * other symptoms may also be present
    Causes: A code P0010 may mean that one or more of the following has happened:
    * Faulty oil control valve (OCV)
    * Open or short in the VVT/VCT circuit
    * Open or short in the OCV / solenoid valve
    * Damaged computer (PCM)
    Possible Solutions: Some recommended troubleshooting and repair steps are:
    * Carefully inspect the Bank 1 VVT/VCT system circuit wiring and connectors, repair as required
    * With a warm engine, test the operation of the OCV, replace/repair as needed
    Hope this helps to solve it (remember to rate this answer).
    Nov 15, 2010 | Chevrolet Chevy Cars & Trucks
    1999 Dodge Caravan with a code 23. What does that
    OBD-II Trouble Code Technical Description
    A P0020-023 code refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module). That consists of an oil control valve (OCV), also called a solenoid valve and other components. Basically the check engine light and associated P0020-023 trouble code means that the voltage in the circuit has fallen below a set limit for a specific amount of time (varies by make/model/engine). Bank 2 is the side of the engine that doesn't contain cylinder #1.
    Causes
    A code P0020-023 may mean that one or more of the following has happened:
    Possible Solutions
    • Carefully inspect the Bank 2 VVT/VCT system circuit wiring and connectors, repair as required
    Nov 11, 2009 | 1999 Dodge Caravan
    P 1383 cougar 2000
    P 1383 Variable Cam timing over-retarded (Bank 1) meaning the comprehensive component monitor (CCM) monitors the VCT position for over - retarded camshaft timing . The test fails when when the camshaft timing exceeds a maximum calibrated value or remains in an retarded position.
    Cause :
    * Cam timing imprperly set * Continuous oil flow to the VCT piston chamber
    * VCT solenoid valve stuck open.
    * Camshaft advance mechanism binding (VCT UNIT)
    Hope that helps
    Jul 08, 2009 | 2000 Jaguar S-Type
    What type of quick release is in VCT-r640 SONY TRIPOD
    http://www.tripodquickrelease.com/Sony_Quick_Releases.htm
    they don't have that model listed, but they seem willing to try. Several people are thanked for finding out which plate fit which tripod.
    Dec 15, 2008 | Sony VCT-R640 Tripod
    Casio FX-115 Solar 236 Function Scientific Calculator Logo
    71 people viewed this question
    Top Casio Computers & Internet Experts
    k24674
    Piyal Perera
    Piyal Perera
    Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
