Question about Toshiba 27A41 27" TV
High Pitched Noise
My TV has recently started making a very high pitched noise. It doesn't happen everytime the TV is on, but it seems to be happening more and more frequently. It doesn't interupt the TV's sound. It seems to be coming from the back of the TV. Occasionally, we can get it to stop by touching or tapping the TV in the right spot, but that's only a very temporary fix. It's starting to become quite a nuisance. Any help is greatly appreciated. Thanks!
  • 1 more comment
  • Rebecca Vanderbeck Jun 11, 2007
    We've recently discovered that the high pitched noise seems to be coming from the connection point with the coxial cable from our cable box. It's not the cable. We tried remvong the cable to swap it out, and the TV continued to make the high pitched noise when the cable was disconnected. We are able to temporarily stop the high pitched noise by adjusting how tightly the cable is screwed in.
  • Anonymous Dec 20, 2008
    I have a 27" Zenitha model b25a24z8 manufactured in 1999. I think I bought in 2000 or 2001. Anyway it has beedn great up to about a mouth ago. It started making this high pitches squealing/. whistling noise; when it's off and when I try to turn it on it shuts right back off. After a few tries it will come on and stay on intermittently. While on the vertical and horizontal hold is going crazy. Each time the screen moves vertical or horizontal it makes a loud (zzzzzzzz sound) like something being shocked and then it cuts off. After about 10 to 15 minutes off this, the tv becomes fine like nothing was ever wrong picture wise. The squealing sound is very faint if any until I turn it off and 10 minutes later (like it's gotten cold); it starts with the squeal ing sound loudly again. Please help.
  • Anonymous Apr 09, 2009
    I have the same problem. I couldn't tell you what kind of TV I have at the moment, but it's an HD and about 5 years old or so. I noticed that when I pushed the cable up a bit the noise stopped. I'm able to manage the incessant whining by stuffing a folded up piece of paper under the cable where it connects to the TV, which holds the cable up enough to cut the noise. I have to adjust it EVERY time I turn on the TV though. It seems to work for the duration of the time I have the set on, but sometimes it is more difficult to get the paper adjusted just so (it doesn't seem to be the same every time). I'm posting this because none of the proposed fixes even made sense to me. The high voltage leak solution sounds like a possibility, but I have no idea how to go about that fix. Can anyone give instructions on how to fix this problem?
    Genius:
  • 1,074 Answers
Most high pitch noise comes from the anode conection on the picture tube thats connected to the flyback anode cap thats mean there is a high voltage leak,to stop the noise you can discharge the high voltage take off the cap and clean with alcohol.if the noise continue.you will have to put some red or clear silicone both the cap and tube stick together leave to dry for about 2 to 4 hrs.this will eliminate the leaking.good luck.
Posted on Jun 17, 2007
    Novelist:
    Champion:
  • 236 Answers
Sounds like you have a coil or transformer vibrating in the horizontal output circuit. If you are experienced in taking the set apart, you may touch the circuit board in the area of the horizontal output circuit USING AN INSULATED TOOL such as a 8 inch long plastic rod. Use the rod to press on various parts of the circuit board and listen to the sound. If it changes,work to the most sensitive place and you're close to the problem. The yoke ( the coil around the neck of the picture tube) can also make a high pitched sound if the horizontal windings are lose in it. I hope this might give you an idea as to what is happening! Stargazer
Posted on Jun 16, 2007
I would check out the horizontal stage for cold solder joints or bad solder spots.
Posted on Jun 15, 2007
Tv just started making a very high pitched noise, although picture and sound are fine?
Barb, noise may be from a power supply/ transformer on it's way out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HELP what is that high pitched noise when tv is on
Is your LCD making buzzing or high pitch noise
Mar 04, 2016 | Sanyo Dp55441 TV
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
Trouble turning on tv. High pitched noise/click.
The mainboard might have some loose components, or cold solder , or may be the filter capacitors are becoming faulty. Yes it is worth repairing, bring it to the repair shop. Cheers.
Nov 25, 2008 | RCA Televison & Video
High pitched car sounds
does the noise and light occour at the same time ? another cause of a high pitched noise can be slipping drive belts, alternator,powersteering etc so check them for tightness, condition etc, does the noise happen when car staionary and just rev the engine ? if so i would say it is the drive belt/s, go back to the VW dealer re the ABS light and get them to check the OBD as should be done as part of the service , hope this helps
Mar 29, 2017 | 2001 Volkswagen Jetta TDI
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
Toshiba 27A41 27" TV Logo
932 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
