Question about LG LRM1260SW Microwave Oven
When my microwave stops it restarts when i open door
After cooking food and timer stops when i open the door to remove food the microwave starts again,when i push the open door lever. now when i try to heat something the light comes on when i press start and i hear a click but turntable and fan do not start and it does not heat
Mark_Webber
  • 472 Answers
SOURCE: LG LMVM2055: Cooked itself?
First you will need to answer a few quick questions between yourselves.
  1. Do you have life insurance?
  2. Is it enough for the wife and kids to survive on
  3. Whats the number for 911
After you answer all these questions, then pick up the microwave, and take it for a long drive.
There are bits inside there that will happily kill you days after it has been turned off. (some even weeks)
For the cost of a replacement in this case, it's not worth it.
Posted on Apr 18, 2008
  • 958 Answers
SOURCE: if we close the mircowave
i think you have a welded controller, either a digital one or a mechanical one. microwave won't run unless you switch it to run. the door switches are safety switches to turn off the microwave once you open the door. if you have a digital controller, you could have a welded relay, if you have a mechanical timer, it could be a welded contact at the timer. another thing is that it should heat what ever you are heating. if it is not heating, check if it has a fuse and if it is busted. some fuse are installed to protect only the magnetron that is why the light and turn table are still running. if there is no fuse to the magnetron, then check the diode from the capacitor to the ground. it could be open. if not then you can have a bad magnetron. i hope i was able to help.
Posted on Jun 24, 2008
  • 905 Answers
SOURCE: would not heat, now outside gets hot
yes! , this is dangerous , be cause it sounds like the magnetron that sends out the microwaves may not be controlled , thus heating the outside and will be sending waves out of the microwave!
you will need a qualified electronic repair shop to deal with this, these microwaves are very dangerous and that unit should not be used untill it has been fixed , for the safety of you and anyone who uses or is around when in use.
these microwaves that are sent across the air to heat the food is burning it and it can do the same to you or any one who is around it while in use
even when in working normal conditions the waves still leak out some , so i always walk away when heating food in the microwave and i advise others to do the same
so the magnetron will need replaced and maybe another component but it needs to be tested to make sure nothing else is damaged also
hope my help has pleased you and that you can give me a fixya rating( all others hurt our rating) as i work on these and i know the symptoms that happen and the causes
again hope you can give me the fixya! , thanks , and if you need any other help, just ask me!
electech
Posted on Nov 10, 2008
ginko
  • 19396 Answers
SOURCE: microwave oven not heating
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diodeand capacitors can be tested. The capacitor must bealloweddischargebefore testing, or you risk to get electrocuted, evenifpower is off.Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 27, 2009
  • 289 Answers
SOURCE: microwave wont heat up
Your signs point to a failed power tube. First though, does it defrost? If it does it is an electrical control problem. If it does not defrost, do the following.... With the power unpluged you may want to remove the outer cover, ( screws at back ), and locate a shiney metal box. That box is shielding for the power tube. Get the part # from the tube and replace. You could check price and availability at www.avnet.com . Make sure you replace all of the shielding exactly the way you found it. VERY VERY IMPORTANT!!!!!
Posted on Dec 02, 2009
My microwave starts running when you open the door how can i fix that
It is supposed to. It is designed that way. It put the light on and the extractor fan to remove steam and cooking smells. Some have a timer that continues to run for a few minutes after cooking. It is not emitting the cooking radiation when the door is open. The are at least three safety devices to stop that.
Oct 06, 2017 | Microwave Ovens
My oven door will not open
Un plug it or disconect it and then switch on again
Sep 18, 2017 | Electrolux ICON Microwave Combination Oven
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Cooking doesnt start
Microwave?
Generic advice follows.
Do you open the door while the machine is cooking? Do it a lot? For a long time (months)? Check your door safety interlock switches. The microswitches can not stand that type of abuse. I have personal knowledge on this. I try not to open the door until it stops, but it is hard usually to do that!!!
If you need more help, let me know.
a
Sep 21, 2009 | Frigidaire FMV156DC Microwave Oven
MW8119SB cooks when door is closed regardless of settings
Clear the cook cycle when you remove the food. Some microwaves pick up where they left off, so you don't have to keep pressing buttons.
Aug 07, 2009 | Emerson MW8778 Microwave Oven
Clock works, timer works-but turntable and other functions stoppe
you have a bad control board . this board had 2 relays one for the magntron and one for the turntable and the cooling fan together . when the turntable goes out so does the cooling fanm and the microwave overheats ...... there is no good fix for this , the control will cost more than a new microwave . please do not use with this happening . i have see them start on fire when it overheats . please be carefull good luck
Jan 15, 2009 | Emerson MW8108P Microwave Oven
My microwave is not working and the repair in scheduled for April 3rd. This is not acceptable. Please helop me to find how I get in touch with the department that handles scheduling.
My Panasonic 1300 W Microwave will not turn off. When I open the door after cooking it restarts and when I open the door before cooking it starts. I can stop it by pressing stop/reset before opensing the door after cooking has stopped but if I press this befroe opening the door to put a meal in to start cooking it will turn on by itself. What's causing this and is it worth fixing?
Mar 19, 2008 | Microwave Ovens
Timer will run, but won't cook
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 24, 2007 | Frigidaire FMV156EM Microwave Oven
LG LRM1260SW Microwave Oven Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Will Halftowaite
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
