Question about Brother LS-2125 Mechanical Sewing Machine
How do you adjust the bobbin tension on a Brother LS 1570 Sewing Machine
  • Brother Master
  • 1,564 Answers
Pull the plastic bobbin shuttle out and look for a small screw tighten that.
Are you sure you need to do this? Most tension issues can be handled with upper tension.
Posted on Oct 31, 2012
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: Brother Window Matic Model HA3-B5
I believe this is the manual that you need.
http://gotoes.org/sales/BrotherSewingMachineManuals/ViewInfo.pl?Brother=1&Sewing_Machine_Model=window-matic
Posted on Jan 01, 2009
Mimito7
  • 128 Answers
SOURCE: bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
Posted on May 29, 2009
SOURCE: can't draw up the bobbin thread
I have the same problem...I have been sewing for many years, and I think I know how to thread a sewing machine! I'm with this person...IT JUST WON'T PICK-UP THE THREAD ...my machine was new, only used it a few times, then one day....it quit woking, it just will not load the bottom thread, I have tried everything, but to take it to a shop.
Posted on Dec 27, 2009
  • 1116 Answers
SOURCE: I get loops on top and/or bottom of fabric during
Top tension back to 4 and leave the bobbin tension as is.
Make sure you have a new needle for the type of fabric being sewn installed with the flat side to the back of the machine. A bent needle can sometimes go unnoticed.
Always thread the machine with the presser foot up and this will give proper tension to the stitch.
Check the manual to be sure you are threading correctly (always with the presser foot up) and that the bobbin thread is feeding in the correct direction from the bobbin spool and through the guides.
Take hold of the thread at the needle as you lower and raise the needle to pull up the bobbin thread. Take both thread ends under the presser foot and to the back of the machine.
Posted on Mar 11, 2010
Tension is loose underside
Loops appear on the surface (top side) of the fabric?
Reduce the tension by turning the upper tension control dial to a lower number. If the loops still appear on the surface of the fabric after you adjust the upper tension, the bobbin thread may be too loose. In this case, turn the screw clockwise, being careful not to over-tighten the screw, approximately 30-45 degrees to increase bobbin tension. After you adjust the bobbin thread, adjust the upper thread to match the bobbin thread.
Make sure you reset before your next project.
Apr 26, 2013 | Brother LS-2125 Mechanical Sewing Machine
Too many threads coming up from the bobbin
try rethread the machine top & bobbin
change the needle
clean under the needle plate & in the bobbin area for lint & loose
threads
Aug 04, 2012 | Brother LS-2125 Mechanical Sewing Machine
I have a Brother LS-1217. The tension will not adjust. I have re-threaded this several times, checked the bobbin and needle. Is this something I could fix and/or is it worth having repaired?
You should be able to fix this. IF it is the top thread on your fabric that is screwy you need to adjust the bobbin tension.
If it is the bottom thread you have a problem with your upper tension. Blow out the upper tension assembly using canned air, the tension discs may be dirty
Aug 23, 2010 | Brother LS-1217 Mechanical Sewing Machine
My brother LS-1520 sewing machine is having major tension problem
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
Jul 19, 2010 | Brother LS-1520 Mechanical Sewing Machine
Bobbin thread loops
If you threaded the machine with the presser foot UP and the thread from the bobbin is feeding from the spool in the correct direction and through the guides on the bobbin case and the loops are still forming, then the machine needs to go into the shop as the timing may need to be adjusted and this is best done by a sewing machine technician, preferably Brother.
Apr 28, 2010 | Brother LS-2125 Mechanical Sewing Machine
I have this machine brother ls-2125.my
You need to either adjust the tension or ensure that you have routed the bobbin thread properly.
Apr 11, 2010 | Brother LS-2125 Mechanical Sewing Machine
My bobbin thread keeps getting tangled and breaking everytime I try and sew....I have tried rethreading the bobbin, taking everything apart and cleaning out the dust and debris, I have adjusted the thread...
there is a screw on the side of the bobbin case, which needs to be turned to the left or counter clockwise to loosen the tension and also change the needle because a burr on the end will cause problems with bobbin thread
Dec 13, 2009 | Brother LS-2125 Mechanical Sewing Machine
I HAVE A BROTHER LS-2125 SEWING MACHINE AND THE STITCHING UNDERNEATH IS OK BUT THE UPPER THREAD IS LOOSE AND ALSO SKIPS
Sounds like either the bobbin case tension is too light or is not in the tension at all.
Consult your manual for how to place the thread in the tension and retry. Increase the bobbin case tension if necessary.
The top tension may be set too high.
Jul 11, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother Industrial Machine Tension
This is an answer to another person with a similar complaint. Try the suggestion below, it may fix the problem.
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Nov 14, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
57 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
