Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Replaced lamp and still no picture
I have a Panasonic PT-50DL54. Was getting replace lamp message and i ignored it til it went out. Replaced the lamp and still no picture.
  • 50 Answers
You need to reset the lamp timer.
Hold the volume down button AND the Mute button on the remote for 5 seconds.
Posted on Mar 10, 2010
I got the 'lamp needs replacing' message. Ignored it. Now my tv screen is black when you try to turn it on and the blue button on the power button flashes?
You haven't replaced the lamp at time. Replace a new lamp along with its ballast and make a lamp time reset. If you wish to get more details about the lamp replacing procedure to Panasonic PTVs, check this link.
Feb 05, 2013 | Panasonic PT-44LCX65 Television
PT-50DL54 50 in. Rear Projection HDTV-Ready Television: started to get dimer and dimer and finally picture...
You should have received a message on the screen about replacing the lamp. Also, the LAMP led on the front should be lit in red.
You can replace the lamp assembly easily for about $150 - $250.
Don't try to replace the bulb only.
A new Panasonic Plasma TV will cost about $1000 and good for another 5 to 6 years.
May 05, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Replace lamp flashed today, how long til i lose picture pt 50dl54
It's a timer, it counts the passing of time. The timer does not indicate the condition of the lamp. You may have a day or a year. Best advise would be to have a lamp on hand for when the lamp failure does occur.
Apr 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Removal of the lamp unit from the tv
sometimes lamp is replaced in the front of tv.If so the panel under picture pulls out revealing lamp housing which is held in with a couple screws.replace lamp housing assembly
Feb 22, 2010 | Panasonic PT-50DL54 50" Rear Projection...
I am about to replace a DLP lamp. How do I reset the lamp time on a Panasonic PT-50DL54J, using a TY-2004 lamp?
This all probably comes a couple years too late, but when you install a new lamp, you’ll want to reset the hours on the counter your television has. Doing this will allow you to avoid getting any messages about the lamp needing to be replaced despite you having a new lamp inside your set.
If you need to get into the service menu, you can do so by following these directions:
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
Jan 31, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Replaced lamp; still have no video yet have audio
Did you replace the lamp because the picture went out (black)?
May 21, 2009 | Panasonic Televison & Video
Replace lamp led light
Have you reset the lamp timer?
Was the lamp module sitted properly?
Remove the back panel and vacuum all the dust.
Also use compressed air to blow out the dust from the inside.
Do not blow into the fan on the right as that will get the dust inside the lamp housing.
Nov 22, 2008 | Panasonic PT-50DL54 50" Rear Projection...
LAMP REPLACE FOR PANASONIC PT-50DL54 INSTRUCTION
Pull off the panel below the screen.
Remove the two screws hold the 2nd cover from the left.
Remove one screw from the lamp module and pull it out.
Buy the lamp module. It is not worth it to try replacing the lamp. You can damage the bulb easily.
Aug 08, 2008 | Panasonic PT-50DL54 50" Rear Projection...
PT-50DL54 panasonic 50" DLP
to get rid of "replace lamp" push the blue action button on the remote and the volumn down on the tv set for a couple of seconds. this has to be done at the same time, good luck.
Bob
Dec 09, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
408 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
