SOURCE: Frusteration with "Invalid multimedia settings" on a Nokia
Hey i had the same problem and found out how to fix it. If it sais "Invalid Multimedia settings. Check settings" then you have to follow these steps:
1. Go to message settings under messages at the main menu
2. Click Text messages
3. Go to Message center in use and select SMS settings
This is how i fixed my problem which was the same as alyluvsskitt's
If this works for you then have fun texting!!!!
SOURCE: How can I delete the mail for exchange profile e71
Found the place to delete the profile under the installed applications folder rather than the Mail for Exchange configuration folder.
SOURCE: i cant save configuration setting recieved from provider its3110c
Never configure it manually !
That means there are many settings are already saved in your Nokia device . Just discard them and try again.
If you couldn't discard them here is another solution :
Just restore factory settings and I'm sure that you'll solve the problem .To restore factory settings here is the way: Switch-off your phone.
1. Press and hold 3 keys; Green
dial key, * Star key, no 3 key on keypad and then press the power
on/off to swtich on the phone.
Remember, do not let go the 3 keys press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
then here is what to do :
Just call your service provider support center and they'll help you for
sure . don't try it by yourself . let them help you . they are the only ones , who can help you correctly .
your rating is very important for me , that's why I've helped you .
good luck .
SOURCE: I want manual gprs setting for nokia 2700c for
Hi there your must contact with your reliance service provider via customer care phone call. THey will gives you manual details. Every company have a saperated manual for different handset. So , you must call them they will fix it for your in a 5 min. Thanks
