Question about Bosch HBL 755 Stainless Steel Electric Double Oven
Have Bosch HBL 755 Control panel is lighted but does not respond. Clock is flashing but unable to change it or anything. Knob turns but nothing changes. What are my options
Looks like it may have failed in the middle or during transition of the self-cleaning cycle. unable to get either oven to respond or change anything on the control panel.
5 Suggested Answers
SOURCE: Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Posted on Dec 11, 2007
barkencoa
  • 3463 Answers
SOURCE: Bosch HBL 645 oven door won't close all the way
I am afraid that the door hinges are non adjustable, and the only solution is to replace them as a pair.
There should be some kind of latch mechanism at the end of the hinge
where it is fastened to the door to compress the hinge to enable you to remove them.
Hope this helps.
Posted on Jan 04, 2010
  • 586 Answers
SOURCE: Bosch Singe Oven Mode HBL-645-A
Hello there,
All you need to do is to unscrew the screws around the top of the oven and you will have access to take off the top cover, then you remove the screws that are holding the front control panel in place, then you fix in the new one and screw it back on, then you cover the top back and screw it back on the oven.
There are lots of screws around there so please you can start from anyone.
That is the picture that carries the way the screws are on the oven. That will do the job for you.
Posted on Aug 28, 2011
SOURCE: bosch hbn 13n5.1b bottom oven temperature control knob not working
Yes they can be and if your savey they have universal oven switches that do the same thing only much cheaper than OEM parts.
Posted on Apr 07, 2012
How do adjust the clock to daylight saving?
Touch TIME then the display will begin flashing timer
Use rotary knob to change this to CLOCK
Touch TIME again and it will say ENTER TIME with the time flashing
Use the rotary knob to change the time as required
Touch START and the time is now changed
Page 12 if you need it
Bosch HBL745AUC Use and Care Manual
Oct 07, 2014 | Bosch HBL 745 Stainless Steel Electric...
Dec 10, 2007 | Bosch HBN 442 / HBN446 Electric Single...
I need to download a manual for this product. Where can i find it?
I found a users manual for Bosch wall ovens at Retrevo.com
http://www.retrevo.com/s/Bosch-HBL755AUC-Ovens-review-manual/id/925ci470/t/1-2/
Feb 12, 2011 | Bosch HBL 755 Stainless Steel Electric...
Only heats when door is open - if you turn on to preheat, nothing happens unless you open the door - the light and fan will be heard coming on, if you shut the door it all turns off
there is a microswitch on the door inner it sounds like its come loose or broken away affecting its operating tolerances should be easy to replace.
Feb 15, 2010 | Bosch HBL 755 Stainless Steel Electric...
I have a mark on the stainless steel finish on my Bosch Oven
i am in the uk and i use barkeepers friend this usually shifts anything on steel i dont know if you use something different in the u/s.its a white powdery substance which you aply with a damp clth then wipe of as it dries works superbly.
Jan 10, 2010 | Bosch HBL 755 Stainless Steel Electric...
Bosch Double oven - top oven will not open - seems like it is locked
i am not aware of a bosch oven that locks the top door usually only main oven will lock if self clean pyro oven,the small oven never has this feature sounds more like a hinge problem check nothing is fouling the lower part of the oven door.
Dec 30, 2009 | Bosch HBL 755 Stainless Steel Electric...
Bosch oven loud fan noise
JUST REPLACED BOTH FAN MOTORS ON A DOUBLE BOSCH 755. DIDNT HELP MUCH.THE FAN IS LOUD COMPARED TO OTHER BRANDS.UNLESS YOU NOTICE A DRASTIC CHANGE IN NOISE, DONT WASTE YOUR MONEY ON A NEW FAN MOTOR.ITS JUST THE WAY IT WAS MADE.
Nov 26, 2009 | Bosch HBL 445 Stainless Steel Electric...
Door does not lock when set to self clean. Why?
HI. This will occur if the door lock mechanism is malfunctioning. This could be because of a failed connection, due to welded contacts, or a separated wring harness at the mechanism, or control board. Check these areas for faults. replace the door lock mechanism if all areas stated are ok, and connected well.
Oct 24, 2009 | Bosch HBL 755 Stainless Steel Electric...
Can i replace the oven light myself on the double wall oven,hbm43b550a ?
Yes your owners manual will show how.Replace the bulb with a similar bulb{ heat resistive}
Sep 28, 2009 | Bosch HBL 755 Stainless Steel Electric...
Bosch 755 Oven resets during cooking
Hi Jim. Thanks for your request re prob with your oven.
Unfortunately, this is not a problem I have come across before, so in this instance, I am unable to help solve it for you.
Only thing I can suggest at this time is that you check all connections and plug in connectors, you never know it could be caused by a bad or intermittent connection.
Once again, sorry I can't be of more help.
Jan 06, 2009 | Bosch HBL 755 Stainless Steel Electric...
Bosch HBL 755 Stainless Steel Electric Double Oven Logo
48 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
