Question about Cuisinart Thermal DGB-600 Grinder
Thermal carafe clogged
My Cuisinart DGB 900 grind & brew makes good coffee, but suddenly the coffee does not fill into the thermal carafe. It simply overflows onto the counter. I have cleaned the lid thoroughly, but still does not fill. Is there a problem with a vacuum seal? How would I fix it?
  • Eric Pollins
    Eric Pollins Oct 18, 2014
    The problem is the float valve in the top center of the lid. With normal use it will get caked with coffee residue, and after a time it will become too heavy with these residues to float properly when coffee comes in .. and then it overflows without filling. Look carefully through the slots on top with a bright light and you'll see the residue buildup. Yuk. The lid pries apart easily when firm pressure is applied from the spout end .. just get your thumb in there and pull. It snaps right back together when you're done. Soak the whole contraption in hot soapy water and then give it a thorough hot rinse. That should remove the gunk.
I was once able to disassemble the top of the carafe and clean it thoroughly. I've had these clogging problems before, and it has not been the filter chamber that is the problem, but the vent in the carafe being clogged. When the air from the inside of the carafe can't be displaced faster than the coffee is draining in, the coffee stops draining into the carafe, fills the top, and spills over the side.
Will probably end up buying a replacement lid, as I can't figure out how to open the top without destroying it. I must have gotten lucky the time I was able to take it apart.
Posted on Jul 19, 2012
  • 8,596 Answers
The filter basket is probably damaged - get a replacement filter basket from Cuisinart, or call Cuisinart to be sure. Something is probably preventing the element in filter basket from pulling up to the open position.
-Tha Mp3 Doctor
Posted on Jan 07, 2009
I need instructional video for the Burr Grind&Brew 12C 900 seriesDGB
Here you go. this link should do the trick
Oct 03, 2017 | Coffee Makers & Espresso Machines
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here:
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Problem with a Cuisinart Coffee Maker
Hi I have a dgb600bc coffee maker the beans do not grind all the way and it makes a funny noise when grinding. thanks
Nov 28, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee in Cuisinart grind and brew ends up all over counter
once and a while the filter door will come ajar and make the coffee leak all over. (allways try to jigle it open after closing, because fine grounds will make the door not close right) Also if the carafe is not in all the way you'll geta mess too!
Jun 29, 2009 | Cuisinart Thermal DGB-600 Grinder
Cuisinart Grind & Brew DGB-600 fills up water in goldtone filter;
Some fine-grain coffees are too fine for the Gold Tone Filter. If this is the case, remove the Gold tone Filter and use paper filters only. You may have to wash excess grinds out of the black filter basket, since there may be a few stuck in there now - don't take the filter basket apart - just rinse it out with water.
Also, don't use a paper filter and the gold tone filter at the same time.
-Tha Mp3 Doctor (also loves Cuisinart)
Feb 20, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Definitely do the vinegar/water cleaning. It will almost undoubtedly resolve your issue.
Nov 22, 2008 | Cuisinart DGB-300 Coffee Maker
DGB-600 Will no longer grind coffee
I am having the same problem, can someone please help?
Oct 09, 2007 | Cuisinart DGB-600 Coffee Maker
Cuisinart DGB-300 coffee maker brew pause valve
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Aug 30, 2007 | Cuisinart DGB-300 Coffee Maker
Cuisinart Thermal DGB-600 Grinder Logo
1,038 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
