Question about Bladez 320-5M/25 Clutch Belt for BladeZ Moby
I have a BladeZ Moby XS gas scooter (Engine is Tanka PF 3300, its 33cc). My recoil starter broke a few days ago, I bough a new one and installed it...I can see the engine
2 Suggested Answers
SOURCE: How do I change the clutch belt on my BladeZ Moby
there are 4 bolts that hold the engine in place on the left side of scooter when your looking straight towards the bars
then there are 3 more bolts below those tak em all all be carefull not to loose the small spacers behind the large ons there hard to notice but they are there
slip you belt over both pulleys and reasemble using the 2adjustment screws that attach to the big pulley on bottom until the belt is 110 & straight and has a little bit of play abotu half in or so should be fine you dont wat too much other wise it will break if you hit a bump or whatever an if its too loose wellit will slip as you might know
Posted on Aug 25, 2009
How do I replace the starter (pull) rope on a toro ccr2450 (model 38413)?
Although it looks like you simply un-bolt the recoil starter you need remove the whole blower (flywheel) housing as there are nuts on the back side.
  • Once the housing is off, remove the broken rope and prepare a length of rope to replace it base upon the old ropes length. Probably close to 6 feet.Don't forget to put the pull handle on the new rope.
  • Tighten the recoil pulley in the direction it normally turns as you pull the rope out until it stops.
  • Slowly back of up to one turn to align the hole in the pulley with the housing hole and hold it in that position while you insert the rope and try a sturdy knot.
  • Slowly let recoil assembly pull the rope back in and test that it is working properly before re-installing the housing.
  • Once you are satisfied that the recoil is working properly re-install the remaining covers.
Jan 15, 2015 | Toro Garden
Lawn mower recoil spring
Remove mounting nuts, pry recoil off fly wheel. Purchase new recoil assembly at mower repair store.
Jul 10, 2013 | Garden
Fixing a cord recoil on a mtd mower with a 4 hp briggs and stratton engine
The upper covers and the fuel tank needs to come off, the starter on most engines is part of the engine cover so this will have to be un bolted and removed with the starter connected
May 30, 2013 | Mtd Garden
On my echo weed trimmer the rope broke on the starter. i took it off and the spring came out. how do you reconnect all the workings?
Recoil starters can be very dangerous when coming Apart!!, And During Reassembly!! Please do not attempt unless you are a qualified and certified Echo technician!
The spring of the recoil is what pulls your rope back in, It is of high energy and can harm you during Assembly, if you fail on any one detail. The most common injury is to the eyes! Use proper eye safety when performing repairs on recoil starters!
Re assembly process as follows,,
For parts info, go to http://www.powermowersales.com
Jun 11, 2011 | Garden
Spring on recoil starter broke after using generator third time. now mcculloch says recoil starter is not available.have to purchase entire starter housing assembly for $105.00
Generic version of your starter is most likely available from small engine shop. Look for model and type of engine itself. Briggs stratton, honda, etc. model number if engine is usually on starter cover or stamped on block or tag attached. If the recoil part is riveted to housing you may need to either re-rivet or use screws to attach new rewind. Used parts are also available at small engine shops. Just take in the starter housing only for match-up. Good luck
Sep 13, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
I have bladez moby that im being able to start but not to keep running, i used the ratio of 30:1 oil mix im not sure if its ok
Ok sorry you havent had an answer yet lol , here it is , i had this same issue . All you have to do is take the plastic cover off of the motor , and once its off pull the throttle ( with scooter off ) and you will see where it leades to . Where it leads to there is a screw which can be tightened to increase its motor stength / use . So tighten it , but only a little bit , if tightened to much the scooter will go without you pulling the throttle , so a 2-3 twists on a screw driver should do it. Once done , start your scooter up , and it should run great !
Dec 17, 2009 | Tanaka 35cc Piston Kit Bladez Moby...
WILL NOT IDLE
vaccuum leak, or idle adjustment screw maladjusted.
Sep 28, 2009 | Tanaka 35cc Piston Kit Bladez Moby...
How do I change the clutch belt on my BladeZ Moby motorized foot scooter (25CC)? Do you have any instruciton manual type pictures as I can't download any from the manufacturer?
Jul 15, 2009 | Bladez 320-5M/25 Clutch Belt for BladeZ...
Brand new Ariens ST624e seized after 15 minutes of operation?
if there is oil on the sparkplug, you have blown a cylinder seal. It will need repair.
Dec 24, 2008 | Ariens 34 In. Zoom Series Riding Mower
Bladez 320-5M/25 Clutch Belt for BladeZ Moby Logo
115 people viewed this question
Top Bladez Toys Experts
ray gallant
Are you a Bladez Toy Expert? Answer questions, earn points and help others
